Go Back   Honda-Acura.net > Auto Forums > Integra & '97-'01 Integra Type-R
New! Use your Facebook to securely log into this site, click logo to login
Thread Tools Display Modes
Old 03-02-07, 12:36 AM   #1
Toy Civic
Toy Civic's Avatar
LS/VTEC definition?
The definition of LS/VTEC can be looked at in a couple ways. I want to see what the Honda community thinks?
Scenario #1: B18A/B LS block, 89mm LS crank, VTEC pistons (cast or forged), VTEC water pump, VTEC oil pump, DOHC VTEC head of your choosing, VTEC oil squirters for cast pistons, and all the other hardware WITH LS/VTEC oil lines etc.
Scenario #2: B18C1/5 GSR/Type R block, 89mm LS crank, VTEC pistons (cast or forged), VTEC water pump, VTEC oil pump, DOHC VTEC head of your choosing, VTEC oil squirters for cast pistons, and all the other hardware WITH NO LS/VTEC oil lines etc.
Can both be considered LS/VTEC?
I've been told that scenario #2 CANNOT be considered LS/VTEC and is just a stroked GSR motor, and that a true LS/VTEC has to have B18A/B stamped on the block.
I personally have scenario #2. I prefer a perfect fit between the block and head and no oil line hassles. It also looks like a normal GSR motor, but has the different internals. The other huge benefit is that you will visually pass a California smog test. If a legit smog ref or tester sees a VTEC head on a B18A/B block, it is not legal, and you won't pass.
What do you all think?
      Registered and logged-in users don't see this ad!
Register your free account today.
Toy Civic is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-02-07, 12:41 AM   #2
lstteg
Banned
The b18c1 is not an ls motor so its not really a ls/vtec. Isn't the whole purpose of the ls/vtec to vtec a non vtec engine anyways?
lstteg is offline   Reply With Quote
Old 03-02-07, 12:50 AM   #3
Toy Civic
Toy Civic's Avatar
Notice how the only difference between scenario 1 and 2 is the engine stamp, and the additional oil line for the B18B. Other than that, the two setups are structurally NEARLY the same. Same bore, same stroke (same rods and crank), same deck height, yadda yadda yadda.
In the arena of the B18 motor, why go with a B18A/B block when you can get a B18C block for less than $500? To do a LS/VTEC properly, you have to yank and disassemble the motor ANYWAY. Why not just have a B18C ready to go and avoid any chances for problems?
The B20B/Z CRV block is exactly the same as the B18A/B block except for the 84mm bore size of the B20 motor. They both have the 89mm crank. So I can understand turning that motor into a VTEC if you don't have the funds to sleeve a B18C block. But a CRVTEC WILL NOT pass smog in California.
Old 03-02-07, 12:55 AM   #4
TheOtherDave™
Keeping the faith...
TheOtherDave™'s Avatar
So as not to confuse the issue... the overwhelming majority of LS-VTEC discussions follow this formula:
* A stock or near stock non-VTEC bottom end (B18A1, B18B1, B20B, B20Z)
* A VTEC cylinder head.
* The modifications, plumbing and wiring required to adapt the VTEC cylinder head to the non-VTEC bottom end.
Toy Civic: While your build is devilishly clever for passing CA smog.... IMO it does not fit the commonly accepted definition of an LS-VTEC motor build.
david :: supermoderator
:: HAN Integra FAQ:
Borderline antique, but still useful.
TheOtherDave™ is offline   Reply With Quote
Old 03-02-07, 12:57 AM   #5
lstteg
Banned
^^Agreed^^
Old 03-02-07, 01:20 AM   #6
Toy Civic
Toy Civic's Avatar
I know I am just asking for opinions, and I respect those opinions.
But I will continue to stand by my assertion that scenario #2 SHOULD also be accepted as an LS/VTEC definition. Yes I understand that on the surface, that the two setups cannot be named the same thing.
I maintain that the defining factor of LS/VTEC SHOULD be the 89mm crankshaft and nothing else. Like I said the only other differences are the engine code stamp and the extra oil lines. I say scrap the engine code for the LS/VTEC definition.
Like I said, why bother with the extra work of mating a VTEC head to a non-VTEC block when you can find good condition bare B18C blocks for less than $500? You have to spend hundreds anyway to get the extra quality hardware for the non-VTEC block. This is functionally better than a B18A/B block.
Old 03-02-07, 01:32 AM   #7
TheOtherDave™
From a practical approach, your setup is brilliant.
I agree with you that from an engineering standpoint, retrofitting the LS crank into a B18C1 motor is a better solution.
But the process by which you've built your motor is entirely different from the process that most people define as an LS-VTEC motor.
When it comes to issues of semantics, it comes down to majority rule.
The pattern of building an LS-VTEC setup has followed the "wrong" route for so long, that method has become the standard definition.
But instead of trying to convince the masses that your method should be the new definition... just enjoy the fact that you've beat the CA smog bastards at their own game.
:: HAN Integra FAQ:
Old 03-02-07, 04:11 AM   #8
OldSkoolF22
I'd hit it =P
OldSkoolF22's Avatar
so why bother doing anything to a B18C? I agree the whole point of putting a VTEC head on al LS block is to achieve VTEC... but a B18C already has VTEC.. so how does it fit into this post of an ls/vtec?
88 Lude
B18C1 from 97 GSR
12.4:1 Carrillo rods and pistons
Skunk2 Pro Stage 2 cams
OldSkoolF22 is offline   Reply With Quote
Old 03-02-07, 09:05 AM   #9
primetime
primetime's Avatar
Quote:
the reason why it fits is because he is acheiving the point of what an ls/vtec is for which is the large displacement combined with vtec. But at the same time it can be considered a stroked GSR. In Cali his visual should pass because on the outside everything matches although internally it is modified.
Here in Connecticut when they do emissions they don't do a visual, so a "true" ls/vtec will pass based on emissions alone.
a.k.a THE MADBOMBER
primetime is offline   Reply With Quote
Old 03-02-07, 06:48 PM   #10
g290ls
they call me tater salad
g290ls's Avatar
http://www.sportcompactcarweb.com/te..._vtech_engine/
everything you need to know about the ls/vtec conversion my friend
and to be honest i would rather do a gsr swap then to do the hassle of a ls/vtec convo, it will cost the same amount roughly
what it is wit it vanilla face- borat
team chaos member #1
g2 making her comeback
www.clubintegra.com
www.utahacuras.com
g290ls is offline   Reply With Quote
Old 03-04-07, 06:03 PM   #11
Snoopy
currently in IDGAF mode
Snoopy's Avatar
Send a message via AIM to Snoopy Send a message via Yahoo to Snoopy Send a message via Skype™ to Snoopy
why does it matter?
you have a stroked b18c1. it didnt start out as an ls engine.
05 BOM RSX-S / injen / eibach / yokohama / hybrid-racing
hell hole crew #1
Snoopy is offline   Reply With Quote
Old 03-04-07, 11:00 PM   #12
2001TEGGSR
DC2 v.2 - SSBP
2001TEGGSR's Avatar
Send a message via AIM to 2001TEGGSR
http://www.honda-tech.com/zerothread?id=1910203
99 Integra GSR - SSBP Build Thread| 97 Chevy 4x4 Bilstein.Vortech
Wise men speak because they have something to say, Fools speak because they have to say something.
2001TEGGSR is offline   Reply With Quote
Old 03-05-07, 03:48 AM   #13
sherwood
I missed Sean
sherwood's Avatar
Send a message via AIM to sherwood
your motor is better
it will achieve a much higher comp ratio and therefore higher power output, it's no so much the displacement as most people think, its how much closer to the head the piston is due to the taller strokes
1.8L Acura Integra GSR: Back where it belongs.
3.2L Pontiac Tran-sport Montana: that things about to go.
2.2L Honda Accord EX: Sold to my sister
232CI Mercury Sable: Sold to some lady, by my father, while i was on a camping trip. IMM232
http://imagegen.last.fm/minimalDark/..._vigilante.gif
sherwood is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Honda-Acura.net - Code of Conduct - Archive -
Top
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
