| New! Use your Facebook to securely log into this site, click logo to login |
Thread Tools | Display Modes |
#1 | |||||||
Integra 92 ls part swap
| Sponsored Links | ||
#2 |
only way you can swap a cam is if you bring the head with it... The LS is a non vtec engine.... GSR is a vtec, having 3 cam lobes... it will not fit into the LS head... Everything but the engine should swap over fine though
Logan 2001 Acura Integra LS-traded in 2006 Mazdaspeed6 GT Last edited by Driverman5777; 12-21-06 at 10:37 PM. |
#3 |
currently in IDGAF mode
vteconly the 92-93 gsr had a b17a. everything from 94+ had a b18c1. things that can be swapped from a b17 to your b18a: - head and everything that goes along with it (with proper preperation) - pistons - tranny - header things that cannot: - crank and rods (unless you want to majorly destroke your engine)
05 BOM RSX-S / injen / eibach / yokohama / hybrid-racing hell hole crew #1
#4 | |
Quote:
Give me a break I had spelt it right the first time... and the C and X are right next to each other...
Logan 2001 Acura Integra LS-traded in 2006 Mazdaspeed6 GT |
#5 |
ok..well...my real question is...can i swap GSR parts into my 1992 LS? I think i can right? I also thought that there was a VTEC version of the 92 LS...
#6 |
yes there was a Vtec version... It was the 92 GSR... and you need to specify what parts you want to swap... some do and some dont....
#7 |
you can swap pistons and tranny. anything like cams, you would need an entire vtec head.
#8 |
so has anyone here done this before? Swapped a GSR head to a regular B18 motor?...if so, did you run into any complications or was it fairly easy?...i also have anpther question...and yeah, i feel like a dumbass asking this, but is there anyways to get "Free"(as in costing no money) horsepower?
#9 |
free hp? remove ac and ps belts. that will "free" up power being taken to drive those components. doing some weight reduction also helps.
search for lsvtec. you'll find more than enough info.
#10 |
I reccomend reading up alot on LS/vtec if you are considering it... It involves a lil bit of work...
#11 |
yeah, i will have to get some info on the ls/vtec setup...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
