Cam seal plug broken, easy to fix?
Cam seal plug leak is normal. While you have the valve cover off though, you should look at ALL the seals (plug tube seals, valve cover gasket, etc...) and probably be prepared for a valve adjust. I believe there is a kit with all the gaskets you need (not including the cam seal plug).
