Results 1 to 2 of 2
Thread: Direct-Fit Cats
  1. #1
    Join Date
    Jun 2006
    Posts
    11
    Direct-Fit Cats
    Hey guys (and gals),
    The catalytic converter on my recently bought '01 GS-R is dead (after a week), so I'm in the market for a new one. I've been looking around the forums and it seems like the majority of people think highly of Catco and Carsound cats. Unfortunately, Carsound doesn't make a direct-fit for my year GS-R, and it seems as though Catco doesn't either.
    The two most common direct-fit cats for the '01 GS-R coupe are Eastern and DEC. I was wondering if anyone could offer some insight into these cats, whether they may offer performance gains or not, or if they are reliable/long-lasting. I'm most likely keeping the car stock until I have saved enough money to mod it properly (we're talking a few years from now).
    However, I wouldn't mind putting in a little bit of extra money should I need to replace parts. From what I've gathered, using a universal Catco/Carsound cat with 2.5" Kteller pipes is the way to go (along with the RSR or Apexi WS2, since quiet is good). Unfortunately, that's going to run several hundreds (close to a grand?) and that doesn't seem worth it to me right now, especially for only a few extra ponies. I'll consider that once I've turbo'd her =)
    If anyone has any other suggestions, please share. I was quoted $1019 for OEM >.<
    Any input would be appreciated. TIA.
    edit: I forgot to mention that the reason I wanted a direct-fit was to save money and also because I enjoy DIY jobs. However, I've never welded before so I'm not comfortable doing so on the GS-R quite yet.
  2. #2
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Try searching around honda-tech for a used cat that will fit.
    If you want direct fitment, measure your current cat and have a machine/exhaust shop weld flanges on to make it the same size. It shouldn't cost more than $150 for the cat and welding. Also, make sure that you get both O2 sensor bungs welded in.
  3. #2
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
