99 GSR Shift Linkage Very Sloppy Please Help!
I just got back from a road trip and during the drive, my shifter got very sloppy and extremely loose. I think it has to do with the shift linkage and have heard that there are some nylon inserts that usually go bad on Integras. I was wondering if anyone had any input on how to go about reaching these to install new ones and also where the best place to purchase these would be. Any input would be greatly appreciated.
I got worms.
Get under there and check it out.
99 Integra GSR
06 TSX
duck squad member #00003
it looks like the problem might not be the busings that are in the top of this post...they look like two little washers that are rubber that are right at the bottom of the linkage...anyone know what these are called?
I'm a living organ donor.
Originally Posted by
poomanshoe89
I had the same problem with my B&M shifter. I also got the B&M with aluminum bushings kit which makes a solid feel. It does transmit some "vibrations", but I can deal with that. The problem that I had was when the shifter became extremely loose. I took a look and disvovered that the little rubber "o-rings" that hold the shifter in place were not doing their job anymore allowing the shifter to move side to side a lot. I put a little oil on the "o-rings" to expand them to lock shifter handle back into place. That only lasted for a little while. Those little rubber "o-rings" seem to dry out. So my simple solution was to place a tie-wrap on each side of the shifter handle to lock it back into place and there is no more excessive side to side movement.
'95 Pontiac Firebird Formula: 771 rwhp/682 rwtq
'01 Acura Integra GS-R: 148 whp/120 wtq
'91 GMC Sonoma 4x4: 165 hp
'05 Kawasaki Ultra 150: 180 hp
'96 Arctic Cat Cougar 550: 90 hp
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
