exedy clutches and flywheel.........
Is exedy clutches and flywheel ok or are they junk? I just purchased a lightened flywheel (9.46 pounds) and a stage 2 clutch. Is this a good buy?
SDSU Basketball
i think so
exedy clutches are pretty good
sounds like a good set up to me..
Benzino: Any mother f**ker who wants to write something bad about me, I’m f**king coming to their doorstep.
Excedy is the largest manufacture of clutches in the world .
great, thanks for the info. I didn't want to be putting some p.o.s. parts in my teg.
WHAT OK YEAH!
Exedy are one of the best clutches out there
I want to be a Wal-Mart Mechanic
www.ufc.com
Tuner Transformation slapped one on a 4 or 500hp something Supra, so I'll think you'll be ok. These shows usually don't give plugs on crap.
"Time Makes Everyone Tap."
ACT is better, but Exedy will work just fine for a mild build up.
www.ufc.com
Also, I forgot to mention that I personally like Centerforce clutch products. Just thought I would put that out there.
anyone else wanna comment?
Be Quiet and Drive
I've got an ACT clutch and Fidanza Flywheel. absolutly love them both
95 Integra DC4... AEM SRI, ACT HDSS, Fidanza Flywheel, Skunk2 Short Shifter, Skunk2 Knob, Pioneer Headunit, Pioneer Speakers, Sony Amp, Bazooka 12" Sub, B/F Goodrich Tires
Life is short.... drive an Integra
i have an exedy stage 1 clutch w/ the 9.46lb flywheel. it works for me!!! stage 1 should be ok until the car has moderate mods.
'96 GSR: Exedy Stg. 1 clutch, Exedy 9.46lb. flywheel, AEM SRI, B&M FPR + gauge
d16z6 parts: denso iridium plugs, alt + PS pump, headlights, corner lenses, and then some...name ur price!
I have an Exedy stage 1 in my 95 GSR and it performs great. It was not worth going for an ACT or Exedy stage 2 with only a header and exhaust on my car.
exedy makes good clutches but if you are building a high hp motor i would opt for a act. i have an act in my teg and a exedy in my 01 vic. the vic isnt very modded just intake header cat pipe exhaust and clutch and flywheel. it holds the power nicely but then again i am not making a lot of power
I also have an Exedy Stage1...I haven't had any problems, I love it. I kinda wish I had something a little stiffer but anything is better than the stock Honda clutch!
*Emily*
99 Integra GSR
03 CL-S
Not sure if your going with a six puck but if you are going with a stage 2 clutch that might be a six puck dont do the lightened flywheel. lightened flywheels and 6pucks dont make good daily driveable setup's go back with a stock flywheel. i ran into this problem before, and the car likes to jump alot with that setup when letting out slowly at times
Originally Posted by
Shooting411's
It would be wiser to go with a full surface disk and a lightweight flywheel than the other way around. The drivability problems aren't from the flywheel...it is from the crappy engagement of the 6 puck.
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
