sinking brake pedal...
Old 04-12-2006, 05:47 PM
R_Squared
LEVEL UP
R_Squared's Avatar
Default sinking brake pedal...
I was driving today and I noticed that at a stop if I kept my foot on the brake with some resistance, it would slowly sink down toward the floor. It would never actually hit the floor completely but this is definitely a new problem nonetheless. What could be causing this issue? Is my master cylinder on the way out, or could it be something else?
Old 04-12-2006, 06:05 PM
jdmeg6hatchy
i
jdmeg6hatchy's Avatar
how are your fluid levels?
Old 04-12-2006, 06:23 PM
bnuk
bnuk's Avatar
one time I failed to tighten down one of the connections between the hose and caliper and I had that problem. Look around your brakes for a wet spot.
Old 04-12-2006, 07:15 PM
R_Squared
LEVEL UP
R_Squared's Avatar
fluid levels look ok. no leaks that i have noticed so far.
Old 04-14-2006, 03:00 PM
auslander
auslander's Avatar
Sounds like either the master cyl or brake booster (or the check valve on the brake booster). Never had to buy either for a Honda, but for other cars you can get a master cyl/booster combo for not too much.
Most times it's the master cyl. The fluid under pressure leaks past the seals to the unpressurized side and back to the resevior. Since the leak is internal you won't see a loss of fluid or any wet spots. I bring up the booster since I've seen them do some really funky stuff.
FWIW, I've seen the sinking pedal problem go on for years and just be an annoyance, YMMV.
Old 04-14-2006, 03:38 PM
Brar
Brar's Avatar
brake master cylinder, $50 at autozone.
Old 04-15-2006, 09:15 AM
g290ls
they call me tater salad
g290ls's Avatar
yeah a had a accord had the same problem ended up replacing both master cylinders and boosters in the rear
Old 04-15-2006, 11:43 AM
Brar
Brar's Avatar
the same thing happened in my Integra, that's why I know the price
replace it ASAP before you can't stop anymore... I almost hist someone if it wasn't for the hill slowing me down :sad:
oh and pump your brakes, nvm you have ABS
Old 04-16-2006, 10:53 PM
Phateless
S2K compatible
Phateless's Avatar
my accord has done that for years. never been an issue. i've even heard of some new hondas doing that. aparently, it's normal. very alarming at first, but apparently not a problem...? at least according to the techs i've talked to...
Old 04-17-2006, 12:16 AM
R_Squared
LEVEL UP
R_Squared's Avatar
well, i've noticed that it only sinks when i push down on the pedal with a good amount of force after I have already come to a stop. So I don't think it's going to be a major issue, at least not for a while. h:
