3rd gear popped out
Driving today and while accellerating in third gear--> it just popped out{what caused this?}I was able to shift back in no probs and didn't have the problem the rest of the day {only happened once<and yes i pushed 3rd up all the way when it occured.any suggestions?
Hey i might be a 1st Gen.
though we had to start somewhere
wat do u mean u pushed 3rd up all the way?
RZA.GZA.Ol' Dirty Bastard.Method Man.Raekwon.Ghostface Killah.Inspectah Deck.U-God.Masta-Killa
ASE Certified
Originally Posted by
[Damnit]
meaning he put it all the way in gear....and i don't know....did it grind at all or did it just go into neutral?
1996 Integra Special Edition 5 speed
*SOLD*
2007 BMW 328i
Yes pushed all the way into gear{ NO grinding} and yes it just slipped back to neutral.
2001 GS-R
did you have the hand on the shift knob? if so maybe the weight of your hand just pulled it back into neutral, thats happened to me before, even w/o clutching
Resident Ninja-photo'er
there is a point on ur revs that will make it very easy for that gear to come right now... it's not a huge issue... were you cruising (like holding at a single rev for a while), im not sure what inside, but i know it's a little tranny issue... possibly someone else can shed more light on it for me as well
How do my taillights look
i know that when giving it gas you can not, and wouldnt want to, ull it out of gear. but if you let off on the gas u can pull it outa gear w/o pushing in the clutch. The RPM at which it poped out is I BELIEVE the RPM you can shift into 4th w/o using the clutch. Ive done this all the way up to fifth. Start out using the clutch but from 1-2 2-3 3-4 4-5 it is possible not to use the clutch. It slides right in. I DONT RECOGMEND IT cuz you will here grinding but i knew i was getn a new clutch so i didnt care. BTW what is the grinding, the clutch plate right.......not the gears?
Certified Rice-Rocket
when the syncro's line up at a certain rpm in the tranny, the tranny can be shifted without clutching
JDM SiR-G Swap
1999 Civic Si
LS/VTEC
For the Best in the NorthWest visit:
www.NWstreetracing.com
It could be just an isolated incident. If the problem occurs again and becomes progressively worse, you can probably count on an overhaul of the transmission.
3rd gear
hey i dont know if you've ever heard of your direct drive gear, but all standard trans have them most are usually 4th gear but some are 3rd. Possibly urs. It is possible for ur direct drive gear to pop out when accelarating and hit the smallest bump that it will pop out like you explained. If it is that direct drive popping out like that than its not a problem at all. Basically can say sh*t happens. Now if it keeps happening, you may want to get it checked, possibly ur blocker rings or clutching teeth or even ur synchronizer assembly. All 3 of which(along with other parts of course) make it possible to shift and hold in gear.
I reccomend doing research on figuring out what gear is your direct drive. If someone tells you there isnt a direct drive, dont believe them. They are simply dumb! Hope this helps--------------Tony
oh by the way, direct drive is also called final drive. Also i did more research and found that chances are its your motor mounts are bad or simply loose. Or your external shift linkage is bad or out of adjustment. Since i believe almost all FWD cars are cable linkage instead of hydraulic, the cables do strech and make em outta adjstment.
I missed Sean
sometimes freak stuff just happens... if it does it again, then be concerned
1.8L Acura Integra GSR: Back where it belongs.
3.2L Pontiac Tran-sport Montana: that things about to go.
2.2L Honda Accord EX: Sold to my sister
232CI Mercury Sable: Sold to some lady, by my father, while i was on a camping trip. IMM232
http://imagegen.last.fm/minimalDark/..._vigilante.gif
borass07
Integras don't use cable shift linkages.
borass07
not nearly all cars are cable. At least not nowadays.
Logan
2001 Acura Integra LS-traded in
2006 Mazdaspeed6 GT
I've had that happen to me once. On a drag strip too, bad timing.
'04 Civic EX Coupe :::: Cusco, CCW, T1R, ASR, Wilwood, Hotchkis, etc.
'92 Accord EX-L Sedan :::: JDM H22A AT->MT Swapped California Shelled Sleeper
'76 Accord Hatchback ::: 70,174 miles, Restomod Project, H22A Swap Dreams
LEVEL UP
happened to me once as well. but only once. next thing i knew, i was revving to redline in neutral.
2009 Mazdaspeed3
2007 Civic Si
IMMDC2
oh see, i was wrong. But that is why i said almost all are cable. I should have said not newer ones are cable. Didnt know integras didnt use cable. Thanks for updating me.
Hey thanks to everyones' reply,i think it was just the certain Rev point,Haven't had it happen since.Currently i don't have 5th gear so i'm just babying it until i get the new tranny up and in.
borass07
G1 and G2 Tegs use cable but not G3.
Logan
2006 Mazdaspeed6 GT
Driverman5777
You must be confused. We are talking about the shift linkage, not the clutch. No integra has a cable linkage.
Yea sorry. Just smack me.
Logan
2006 Mazdaspeed6 GT
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
