• Integra Tech: [Read and post your basic questions here.]
#81
LEVEL UP
Originally Posted by red94teg
could the FITV be the culprit for a low idle at startup/when the car is cold? Also, are all the brake calipers the same for 3rd gen tegs, or is there a difference between trim levels (i.e ls vs. gsr)?
#82
On permanent hiatus
Originally Posted by Phateless
lizzie - yes.
red94teg - not sure, but i'd say worry about your leak first, then be picky about what fluid to use. better to run the wrong fluid than to run it dry.
anybody? still gotta figure this stuff out...
Here is the testing procedure right out of the Helms manual for the FITV:
1. Remove the intake duct from the throttle body.
2. Start the Engine.
3. Put your finger over the lower port in throttle body and make sure that there is air flow with the engine cold (ECT under 86 degrees F).
If not, replace the FITV and retest.
#85
S2K compatible
leave the wires on when you remove the cap. pretty straight-forward. switch the wires onto the new cap, then re-install. i like doing it this way so i don't have to worry about mixing up the wires.
#86
Originally Posted by cruserfier
Can any-body help me? i bought a 2000 teg LS, it had a (SRS) light on. i took it to the shop they told me that they coldn't reset the light or find what was wrong with it. That the scanner will not give them a code. They also try mannualy by glove-box adapter and the light would not blink. what else can i do?? this is really crazy.
#87
nelson rules
brake fluid flush
99 integra gsr
what needs to be done?
what kind of brake fluid do i use?
step-by-step instructions would really be helpful!
thank you
99 integra gsr
thank you
no sig
no sig
#88
S2K compatible
go to autozone and buy a vacuum bleeder for $30. just bleed each caliper until you have clear fluid coming out, starting with the farthest one out (right rear) and working your way closer. do a search for more detailed info. pretty easy. search for "bleed brakes"
#89
Replacing fenders/bumper
I just got an 87 Integra and it needs bumpers, front and rear and fenders on both right and left. I'm having trouble finding them and the ones I did find are so expensive I could buy another car for the prices. Are any of these parts interchangeable with other models that might be more common?
#90
S2K compatible
86-89 integra... check junkyards...or check your local tow-yards. sometimes people abandon cars and the yards sell the cars for nothing...you might be able to score an entire parts car.
