Thread Tools | Display Modes |
#211 | |||||||
| Sponsored Links | ||
#212 |
I have a bad brake master cylinder. Anyone has instruction on how to replace it as well as anything I need to pay attention while working on it? Where can I get it, Auto parts store is ok or I must buy from dealership. Thank You.
AEM SRI, Focus Cat-Back,16" Enkei on Bridgestone potenza,Homemade clear corner and bumper lenses,20% tinted windows, Blue under-seat L.E.D, Panasonic receiver, Polk audio db650. |
#213 |
Chubbie Bunnie
hello my name is KAtie .. im looking for some help on removing my stereo and installing a new in a 2001 integra gs.. please can anyone help
#214 | |
Keeping the faith...
Quote:
http://www.honda-acura.net/forums/audio-and-security-30/ You'll need a philips head screwdriver to remove the center armrest and the interior panels that surround the shifter. After that, it's a matter of removing the factory stereo, wiring up an adapter harness for your new stereo deck and putting everything back together.
david :: supermoderator :: HAN Integra FAQ: Borderline antique, but still useful. |
#215 |
hi
i need help here about spark plugs... i have DC2 HONDA INTEGRA TYPE-R 1996 model and i want to know what spark plugs are the best for my car. if anyone knows please tell my the type and the code so i can buy them... thnx in advance
#216 |
Tegger Too
Bosch Platnium +4
I don't have anything to recommend per say, and I don't have a '96 R, but I have a '92 GSR and I went with the Bosch Plat.+4 plugs and I haven't really noticed anything in smoothness or fuel efficiency. The only saving grace is they're good for 60K+ supposedly. So, if you don't want to change them as often as conventional, then go for it, but I didn't notice any difference.
#217 |
I'm looking at the issue of getting in lots of trouble with buying a used car. Thankfully all of the issues have been fix at the expense of around 1.1k. Its a 95 GSR and it runs perfect thing is before the repairs the car idle'd at 1700. After the next fix it dropped to 1100 and after all the repairs were done it dropped to 700RPM on idle. Am I looking at to low for RPM? Could someone tell me the normal idle set for RPMs on an 1995 acura integra GSR? Thanks.
#218 | |
Quote:
By comparison, 750 rpm (±50 rpm) is the correct idle speed. You don't need to adjust a thing.
#219 |
B18C1
Wiring Harness
Does the wiring harness need to be changed, as well as the ecu, when you switch from an LS to GSR? The LS and GSR are both OBD ll
Two cams are better than one... |
#220 | |
Quote:
I've commented on your thread in the Engine Swaps forum. When you can, follow up on it and reply in that thread, please.
#221 |
Brake Cailper Bolts....
i have a 97 rs integra and had taken off the whole drivetrain off while i did an engine swap for some odd reason.... well now im tryin to replace the brake system and cant find the bolts for the calipers... my question is wut size of bolts do i need to connect the caliper bracket to the caliper? if i remember correctly they are 2 different sized bolts but im not sure...they mite be 12mm
but if anything also if anyone can tell me the pitch size |
#222 |
my brake lights and interior lights?
I've checked the fuses confused and are still good. what do i do next?
#223 |
ĺhhhhh
Hi guys.. weird thing happened to my 95 LS this morning... here are the series of events that occured...
1- passenger side blinker went out, so when i go turn right the dashboard light indicator blinks really quick. 2- made a left turn the blinker there works fine. 3- went to make another right turn, blinker doesnt come on. 4- test the left blinker.. nothing. 5- try to turn on the lights.. nothing. 6- its like my signal lever thing isn't working at all... 7- put on my hazards, and these seem to work... not sure if my brake lights are coming on.. as i was in a rush to catch the train. dashboard lights don't come on, since i can't turn them on with the signal lever thingy. update: dashboard lights dont light up. blinkers work when i turn my hazards, but not when i flick the turn signal. what can the problem be? a blown fuse? short curcuit?
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ Equally different, yet, uniquely the same. ![]() 2009 Hyundai Elantra GLS - in debt again ![]() 2001 Acura 1.7EL - winter car now 1995 Acura Integra - "project car" Last edited by ĺ; 01-08-09 at 08:44 PM. |
#224 |
93 integra won't start
My 93 integra 1.8L all of a sudden won't start. I replaced the fuel pump and fuel filter, main relay, and the distributor, still just cranks. Doesn't seem to be getting spark or fuel. Occasionally it will start and seems to run fine, but turn it off and it won't start again. Could this be the ECU? My next step is to have it towed to repair shop. Any help is appreciated.
Thanks, Mark |
#225 |
help with idle!!
I recently bought a 93 civic with a ls vtec 95 ls block and 94 gsr head 1.8 doch. it wouldnt start for a while and i put new plugs and wires, distribitor and external coil, map sensor. finally got it started and now its idling at 3000 rmp. i have been told new intake manifold gasket or throttle body gasket?? anyone...
also can anybody tell exactly what kind of ecu i should have? Last edited by B-Rizzle; 02-27-09 at 06:18 PM. Reason: adjustments |
#226 |
I got a question... i baught my 94 ls sedan and found out they did a trany swap to it, everything works ok, so I thought, my reverse light is not working, got under the car and found the switch being missing. now it is replaced and it still doesn't work, there is power going in and out of the switch when it is on reverse... anybody have an idea, also what is the rev limiter suppose to be on a swap trany ls? email me back asap?
#227 |
Light for Drive position in dash
I have a 97 Integra AE (automatic) and recently the light that displays around the D (drive) does not work. For all other position it works. I've read that if it's flashing that can indicate a transmission issue, but it's not flashing, it just doesn't light up. I was thinking the light is probably an LED, and they're known to last for a long time, so I'm doubting that it burnt out. Any ideas how to track down where the issue is?
TIA |
#228 |
i dont know if im writing this in the right place... just found this website... ok i have a 97 integra and i did the paper clip thing for my check engine light and from what i counted i was getting an 81 and an 83. does anyone know what those are? my abs light is on too but i didnt check that code yet.
#229 |
starting problems
My 94 gsr has fired up every single day with no problems, until recently. When I try to start it now it begins just normal and then it kinda just slows down and i have to re-crank the engine. It has only done it twice, taking about three or four times each time before it cranks. After the car starts it runs as good as ever. Nothing ever dims either so I would assume it is the battery but I really am kinda clueless. Any help would be GREATLY appreciated. Thanks
#230 | |
Quote:
#231 |
question? i have a 94 ls stock and i recently purchased a thermal exhaust but the damn thing is too loud i got it from a buddy of mine for like ten bucks which is great, than i spent another $120 for the tubing and welding from the manifold all the way back, now i want to get rid of the noise and get something with a nice racing tone and purr to it for a decent price but i really don't know what to get for about $350, if there is anything on that price, i would really appreciate the help thanks.
#232 |
have to forfeit my block 2 CHP
Best way to go about getting new b18c1 block for 96 gsr...where/cheapest used vs. new etc etc **PLEASE HELP/ADVISE***
this is why... Bought a salvage title 96 gsr from a buddy. The car is great\ quick. He had the vin verification scheduled with the chp already(good intentions)so that I can register it once it passes. I take it down (without him) and the second the CHP inspector pops the hood say's "uhhhh, theres gonna be lotsa problems with this car." Great!!! After a thorough inspection i have to forfeit the block b/c the #'s were grinded off, and the rear bumper(numbers illegible). HE said the vin tag on the tranny was missing as well, but made no mention to hand that over to them. He was nice enough not to impound car right there. He did make it very clear that he could have..Thanks bud!! Best place to get a new block? I live in hayward, CA |
#233 | |
Quote:
Consult our engine swaps forum for more info on where to purchase a new motor. http://www.honda-acura.net/forums/en...and-tuning-33/ Unless a court has ruled otherwise, I would assume the CHP will seizing the entire engine and probably the transmission, not just the block casting. Trafficking in stolen parts (whether you know they're stolen or not) is a serious crime. Be thankful that they're letting you keep the rest of the car.
david :: supermoderator :: HAN Integra FAQ: Borderline antique, but still useful. Last edited by TheOtherDave™; 08-25-09 at 02:34 AM. |
#234 |
new wiring harness, car wont start
so the guy i bought my 95 integra from, screwed up the wiring harness, so i replaced it, everything is plugged in there is power, but the car wont turn over?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
