Why won't my gas light ever come on? Please Help!
Old 07-18-2005, 07:41 AM
tony852
tony852's Avatar
Default Why won't my gas light ever come on? Please Help!
All my lights come on except my gas light. Every time I am low on gas, the gas light never comes on, and I was just wondering if someone could please explain to me how to fix this. Is it a bulb, a fuse or what? Thanks
Old 07-18-2005, 08:03 AM
squee
squee's Avatar
Mine is the same. It will come on and stay on for maybe a mile when I have 1 gallon left.
Old 07-18-2005, 08:41 AM
Oldschool
Boondock Saint
Oldschool's Avatar
my light has never come on, even when past e...but then again, I have always been able to get to a gas station BEFORE my car stopped running, so who knows...have you ran it completely empty and still had no light?
Old 07-18-2005, 08:49 AM
bluetwo
Relevance is irrelevant
bluetwo's Avatar
It could be that the bulb is burned out. Like half of the lights in my gauge cluster needed new bulbs when I got my Civic. It takes patience to replace them, but I love my lights so it's worth it, IMO.
You have to take the cluster out, pull the face off (carefully), take all the harnesses loose - obviously it will be easiest when you take the gauge cluster out, then pull the back off. At that point you should see all the bulbs and you can replace them with bulbs from Autozone or whatever.... theoretically. I don't know what year your car is so about all I can tell you is how my own experience went.
Old 07-18-2005, 10:06 AM
tony852
tony852's Avatar
My car is a 97 integra gsr...My gas light has never came on. No I have never drove it untill it TOTALLY ran out of gas. People have told me to just carry 5 gallons of gas with me and run it out just to see if the light would come on, but I would rather not do that because I was once told that when you get to the bottom of your gas tank you begin to suck up debri. What kind of bulb is behind those little symbols? I think it might be a bulb, because there are 3 symbols in the same spot, and 2/3 work. If anybody else has any ideas please let me know...and if it is a bulb how hard is it to get to? Thanks!
Old 07-18-2005, 10:10 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
The bulb is probably burned out.
I don't remember the model # .... but any competent auto-store clerk ought to be able to look it up. The bulbs are quite small.. about a 1/4 of an inch in diameter and maybe 3/4" tall.
To replace the bulb, it's a 15-minute job at the most.
Remove the instrument panel, turn it around and remove the little bulb holder by twisting counter-clockwise. Swap in a new bulb, reassemble and you're done.
Old 07-18-2005, 10:45 AM
tony852
tony852's Avatar
What exactly is the instrument panel? How do I remove it?
Thanks
Old 07-18-2005, 11:12 AM
TheOtherDave™
Apathy Kills
Thanks
By "instrument panel", I'm referring to the single unit in the dashboard -- directly in front of the steering wheel -- that houses the water temperature, tachometer, speedometer and fuel gauge (and all the tiny "idiot" lights).
To remove it, you'll need a medium sized Phillips screwdriver.
1. Lower the steering collumn to it's lowest position.
2. Remove the 2 screws that hold the black trim panel in. These screws are recessed into the top of the panel.
3. With the screws removed, pull the black trim panel directly towards you.
4. Remove the 4 screws that hold the instrument panel in place. They're located at the top and bottom corners of the panel.
5. With the screws removed, gently pull the instrument panel towards you and unplug the 4 harnesses that plug into the back of the panel.
6. With the panel removed, turn it over and you'll see cluster of small knobs that plug into the circuit board on the back.
7. Somewhere close the bottom, on the side nearest the gas gauge, you'll find the bulb socket that corresponds to the low-gas "warning" light. It's a trial and error process; I don't remember which one it is. Basically, the point is to check the bulbs to make sure they aren't burned out.
8. [Like I said earlier...] The bulbs plug into a knob-like plastic holder that screws into the back of the instrument panel. To remove them, twist clockwise about 1/2 a turn or so.
Once you've found the burned-out bulb (if there is one), remove it and buy a replacement. Plug the new bulb back in and reverse the instructions to reassemble the car.
Old 07-18-2005, 12:02 PM
tony852
tony852's Avatar
Dave, Thanks a million for your time on this...I appreciate it.
-Tony
Old 07-18-2005, 02:24 PM
tony852
tony852's Avatar
kay I took out the gauge cluster and everything, I went to replace the bulb, but come to find out the bulb is still good! So It's not the bulb, I mean I let the meter go pasted "E" I don't know what it is. Maybe integras wait till you only got one mile to go before the light comes on.
