Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
Thread: Lower balljoint problems
  1. #31
    Black Pearl Hondaman's Avatar
    Join Date
    Oct 2002
    Location
    Wisconsin
    Posts
    2,516
    No problem, I wish I could be of more help...
    The tool in the kit I used that seemed to work the best I've circled below. If you can find one like that, you are golden. It's actually a pitman arm puller, but it was very effective in seperating the balljoint. Any autoparts store should have one for around $10-$50 depending on the name brand.
    Edit - Well, I can't attach a photo for some reason, but it is the one in the middle on the top in the photos of the kit I posted earlier.
    Or kind of like this.
  2. #32
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Quote Originally Posted by Hondaman
    You are a lifesaver. I was looking at those when I went to get the new balljoint and thought they would work, but I wasn't sure, so I passed. If the big ass hammer doesn't work and I can't get the separater at the stealership, I will pick one of those up.
  3. #33
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    I finally got it. It took a big ass hammer and about 15 minutes of whacking, but it finally came out. Luckily I found a machine shop open on Saturday, so the bearings are being pressed out and the new ones are being pressed in right now. I can't wait to hear the silence of good wheel bearings.
  4. #34
    Working on project CRX Si DiAbLo3785's Avatar
    Join Date
    Feb 2005
    Location
    In a van down by the river
    Posts
    278
    when in doubt....use a big ass hammer
    FORD- Fix Or Repair Daily
    CHEVROLET- Cracked Head Every Valve Rattles Oil Leaks Every Time
    GMC- Goddamn Motor Cracked
    DODGE- Drips Oil Drops Grease Everywhere
    FIAT- Fix It Again Tony
    PINTO- Put In New Transmission Often
    VW- Very Worthless
  5. #35
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    I put it all back together tonight and the difference is night and day. I can actually hear the exhaust again and everything is smooth. Thank god for that big ass hammer!
  6. #36
    Seni honura's Avatar
    Join Date
    Aug 2003
    Location
    N.Y. Queens
    Posts
    3,401
    Quote Originally Posted by Shmoo
    Ehhhh See I told you. BIG AZZ hammer and your good to go. Im happy you got it running.
  7. #37
    Join Date
    Oct 2002
    Location
    Wisconsin
    Posts
    2,516
    Good job man!! A BFH always does the trick.
  8. #37
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
