Need help with valve clearance!
Old 03-06-2005, 01:38 PM
MaxOctane
MaxOctane's Avatar
Default Need help with valve clearance!
I've got a 91 teg and the timing belt broke. I am trying to replace the head, but I don't understand how to set the valve clearance. The rocker arms cup around the valve stem seals, not allowing me to put a feeler gauge in there. How am I supposed to set the valve clearance with this setup?
Old 03-06-2005, 01:39 PM
teg92
WHAT OK YEAH!
teg92's Avatar
what head are you using?
Old 03-06-2005, 05:54 PM
MaxOctane
MaxOctane's Avatar
I dont know, how can I find out? I know I have the B18A1 engine.
Old 03-06-2005, 06:54 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
You stick the feeler guage between the camshaft lobe and the rocker arm. The screw that is tightened by the bolt adjusts the clearance. This page will tell you how to adjust valve lash: http://www.c-speedracing.com/howto/v...alveadjust.php it is for a vtec head but it is still the same premise.
