Integra bad clutch or tranny?
I have a 96 Integra with a 5 spd. I'm having issues when I try to shift gears. Sometimes it wont let me put it in gear at all. I just replaced the clutch master and blead the system properly. Then a couple months later, I started having problems getting it in gear.
The clutch doesn't slip AT ALL. The throw out bearing is making noise. Do you all think I can just replace the TO bearing and call it done?
TIA,
Tony
TIA,
Tony
On permanent hiatus
TIA,
Tony
TIA,
Tony
poor hungry dirt kid
Or, you could just buy a used itr tranny and call it a day? BTW, it sounds like the pressure plate. How many miles does the car have? My pressure plate went at 125k. Had to replace pp and clutch... and i got carried away and replace the flywheel too. Good luck
