What are some symptoms of worn Axles
Old 03-03-2005, 12:39 PM
bmonty
bmonty's Avatar
Default What are some symptoms of worn Axles
... a reverse question! Usually I give the symptoms and ask for the cause.
Have had this 1997 Integra for all of the 116k miles on it. Around 60k, the road noise in the cabin got loud and has been getting significantly louder. Though it was the tires --- changed them with no difference. Had a front wheel bearing with a ton of play - changed it - still loud.
I'm thinking the CV joints are worn but have no real experience with FWD cars. The car sounds a little bit like a truck with mud tires and kinda pulsates with speed. I recently changed the manual transmission fluid too - no change. Definately not the brakes either. I'm hoping it isn't a bearing in the transmission but this does not sound like a nad bearing.
The noise is very hard to explain- best I can do is mild version of a truck with mud tires. CV boots are intact.
Any ideas?
thanks,
Brian
Old 03-03-2005, 01:58 PM
c_rogue69
wtf goes here?
c_rogue69's Avatar
Yeah, sounds like CV Joint...is it like a "Wah Wah" roaring-type noise...kind of deep in tone?
Old 03-03-2005, 02:28 PM
nsxtech
nsxtech's Avatar
Bad wheel bearings...
Outer joints will make a noticable clicking sound when cornering.
Inner joints will usually create a nasty harmonic vibration in the
car at about 40 mph in third gear....
Old 03-03-2005, 04:53 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
What about an alignment?
Old 03-03-2005, 05:59 PM
nsxtech
nsxtech's Avatar
chopped (cupped/scalloped) up tires will make the sound you describe as well as wheel bearings
Old 03-04-2005, 04:56 AM
newgsrdriver
newgsrdriver's Avatar
Did you check the rear bearings as well?
Damaged tires will most definitely sound like that, but you said you replaced them.
Old 03-04-2005, 05:03 AM
bmonty
bmonty's Avatar
RF wheel bearing is new and the others have no noticible play. I should have a dial indicator soon so I can be sure. The new tires didn't change the sound at all. My brother had a probe with a torn outer boot and a trashed CV joint and that thing clicked - this Integra doesn't click like that. No noticible increase in noise while cornering.
Is there any scientific way to measure axle and CV joint wear? With U - joints I simpy wiggle the shaft.
^^This is a good description^^
Thanks,
Brian
Old 03-04-2005, 08:18 AM
nsxtech
nsxtech's Avatar
Just because a wheel bearing has 'no noticible play' doesn't mean it isn't bad....
Old 03-04-2005, 09:55 AM
Eclypz
Eclypz's Avatar
Doesn't a worn CV joint makes a ticking noise?
Old 03-04-2005, 08:17 PM
nsxtech
nsxtech's Avatar
See above:
