fuel requirements for gsr?
i recently found a gsr ill probably buy. ill end up selling my gs which isnt a problem, but i do have a question. some places ive looked say the gsr "requires" premium fuel. is this for optimum performance, or will it just lose a few horsepower with the lesser grade gas?
Both are true. Timing would be retarded with lower octane fuel, which would degrade performance and potentially damage the engine.
GSR engine is 10:1 compression ratio so I would use premium. In a vehicle driven 12,000 miles a year that averages 14 mpg, you're only looking at $171 additional fuel cost annually. The Integra, of course, gets much more than 14mpg. I think the whole premium fuel thing is blown out of proportion as far as causing engine damage. Take this quote from Porsche, for example:
All Porsche engines are designed for premium, too, but it's not available everywhere. "Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches.
Apathy Kills
Use premium whenever possible. I don't know why this question keeps coming up. The owner's manual specifically states that premium fuel is required. Why second-guess the manufacturer?
When you run a lower octane gasoline, the ECU will retard ignition timing, reducing power output. Also, you run the risk of engine "knock" or detonation, which will damage piston rings and even connecting rod bearings if allowed to continue.
And sorry if I'm blunt, but that quote from Neusser is pointless. We aren't driving Porsches here. h:
No we're not, unfortunately. I was just going on the idea that octane requirements are driven by the compression ratio of the motor and if a Porsche motor with a higher compression ratio than a GSR can run on regular octane without damage, so can a GSR. I've seen some posts where people freak out because they accidently put a few gallons of 87 octane in their GSR and they think their engine will be damaged as a result. But anyways, use premium.
