How many miles should a an OEM clutch last?
Thanks everyone. I feel better now. Thinking about replacing the axles and wanted to fight off project creep as much as possible. You know how it goes............
On the other hand, I just pulled a clutch on another car after 500 miles. Aparently I used too much grease on the splines and it flung all over and ruined the disc and turned the flywheel and pressure plate blue in spots. Thank god it is a '60s RWD car and was easy.
Brian
Brian
The clutch actually wears ONLY while it's slipping. So if you launch at 5k rpm all the time, or you have to slip a lot because of your ... 'skills', then it won't last as long.
If you rev-match when you shift, then it doesn't even wear during shifts. Only during launching.
