b18a1 and b18b questions for you
RacinMasonC
Just wondering if i used a B18a1 block, will the b18b head bolt right up to it??? what timing belt would i use and would the compression change any and also will the dizzy bolt right up to the head or no??? let me know!
The timing belt and the headgasket are the same...You might want to clay it first to be sure but I don't think you should have much of a problem, the only difference I noticed between my '91 and the '94 I have is that the cams are different the ones for the b1 seem to have a slightly higer lift.
Your Powder Coater
dizzy will depend what obd you want to run.. your 91 is obd0 stock, but would be nice to upgrade it to obd1 & run uberdata on! theres tons of write-ups on it out there.
