90 integ floorboard
90 integ floorboard
What's up?
I've got the wet passenger floorboard issue common to Gen2 tegs. I did replace all the 8 little rubber grommets under the cowl, et cetera et cetera, but it still leaks! I cleaned the area surrounding it when i put it in, and everything was sealed up properly. Any clues as to what causes this? The car has about 138k miles.
Mine is leaking through the window seal and through the automatic seatbelt track. You might not notice it right away but the water might be running down the door pillar and into your carpet. Just something to check, it took me a while to figure out where my water was coming from.
