Oil coming in from floor
Old 11-23-2004, 01:29 PM
Inacurals
Honda Hoar
Inacurals's Avatar
Default Oil coming in from floor
93 LS
I removed my floormats to find small streams of what looked to be oil every where on my carpet. I looked thru a hole in the carpet to see oil that looks to be seaping in small areas around the floor. What can be doing this? Clutch master cyl. ? My clutch is a cable i believe. Help Pleez.
Inacurals
Old 11-23-2004, 01:31 PM
redteg
redteg's Avatar
That would be your Clutch Master cylinder leaking dot 3. You're gonna need to get that replaced.
Old 11-23-2004, 01:43 PM
Inacurals
Honda Hoar
Inacurals's Avatar
i cant find the clutch master cyl. in my Honda Motor Co. repair manual.
Old 11-24-2004, 08:10 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
It's also possible that your brake master cyl. is leaking..h:
If that's the case, then I'd park the car until you've got the brakes back in proper working order.
Old 11-25-2004, 12:28 AM
RpG~^_^~LauRnO
RpG~^_^~LauRnO's Avatar
clutch master cyl is under the dash just follow your clutch pedal and you will find it.. on the firewall
