When to replace water pump?
The deer had to die!
w/ timing belt @ 90K miles (and 180K, and so on) or when you notice your engine running hotter while idling, but its not because of low coolant or malfunctioning thermostat.
www.ufc.com
Originally Posted by teg92
you replcace waterpump when you do timing belt
Truth is that it may last just about forever but everyone replaces it when they do their timing belt because its about a $25 part and it takes about 20 minutes to do while you are doing the timing belt. However, to just replace a water pump alone you would still expend the same amount of labor because you have to remove the timing belt to do it.
