Car shakes at low RPMs
Old 11-09-2004, 04:43 PM
Nosh_Dir85
Nosh_Dir85's Avatar
Default Car shakes at low RPMs
I just recently have had a problem with my beloved Teggy. It's a 95 LS, with 86,000 miles. Recently, when it starts, it idles really rough. Its manual, so when i start to release the clutch, it shakes even worse, and on until about 3000 rpm. then when i shift up, it shakes until about 3000 again. there is no clutch problems, and it still sticks well. it doesn't go away even after it's warmed up. It feels like a cylinder isn't firing, or misfiring, but today i pulled out the plugs, and they all looked fine, and they were all gapped the same. I've read some other places that it could be the fuel system, ie the filter and injectors, so i might try to buy some injector cleaner. I also change the oil at regular 3000 mile intervals. I need to take it on a trip thursday, so i hope to fix it before then. Thanx in advance
-Dustin
Old 11-09-2004, 04:51 PM
bluetwo
Relevance is irrelevant
bluetwo's Avatar
If you haven't changed the fuel filter in a while go ahead and do it. It's not expensive and it only takes a few minutes or so, depending on your abilities.
I'm not saying it's a fuel problem, but it could be I guess.
Oh yeah, welcome to HAN.
Old 11-09-2004, 04:58 PM
will94integ
will94integ's Avatar
Agree... sounds like it could be the fuel filter...
Old 11-10-2004, 12:03 PM
ADRONICUS
www.ufc.com
ADRONICUS's Avatar
or the pump (hope not) that cost more...
Old 11-10-2004, 01:02 PM
dubcac
I
dubcac's Avatar
Fuel filter, distributor cap, plug wires, vaccum hoses. Have you checked all cylinders for spark?
Old 11-10-2004, 01:40 PM
Meguel24
Platinum Plus Member
Meguel24's Avatar
sounds like the problem I'm having as of this morniing too. My 95 teg is bogging so sever that I couldn't even drive off (even though I attemped). Each time I started to slow to a stop it would bog again.
Old 11-10-2004, 01:48 PM
OregonHusker
OregonHusker's Avatar
My '95 Teggy had roughly the same problem. Does it bog down when you try to accelerate?? My did that and it turned out to be the ignition coil.
Old 11-10-2004, 04:25 PM
Meguel24
Meguel24's Avatar
yeah bogs as i accelerate, and once I reach a constant speed, if I accell some more I'll hear/feel it bog once again.
Old 11-10-2004, 07:19 PM
dubcac
I
dubcac's Avatar
My old prelude had the same problem after having the motor replaced. The tools hooked up the vacuum hoses wrong.
Old 11-10-2004, 10:57 PM
Nosh_Dir85
Nosh_Dir85's Avatar
Well, i seemed to have solved the problem. I figured it was just the injectors, and i ran some lucas oil through it, and now it runs good. thanx for the help!
