Key won't take its turn...
Hi
I have a 94 Integra LS, My problem is when I go to turn the key it won't turn...regardless of when the wheel is locked or not. I fix the problem by shaking the steering wheel back and forth while turning the key...any simple ways of fixing this issue? or do I need to buy something.
Thanks.
Thanks.
It is maybe a problem with the ignition lock. Also, if there is pressure on the wheel, it will keep you from turning key, like if parked on a hill witht the wheel turned
