Difference between High lift cams and turbo cams?
Old 10-29-2004, 08:11 PM
EK9
EK9's Avatar
Default Difference between High lift cams and turbo cams?
I am wondering what is the difference between turbo cams and high lift cams??
Old 10-29-2004, 09:59 PM
dubcac
I
dubcac's Avatar
High lift all motor cams create valve overlap in order to make more power. Valve overlap bleeds boost because the valve open duration is longer, so turbo cams use more lift without the longer duration to make power, without bleeding boost.
Old 10-29-2004, 11:28 PM
Kai
Rotorphile.
Kai's Avatar
Turbo cams typically are high lift. You are confusing lift with duration.
High lift means exactly that, the valves are opened higher then factory spec.
Duration is how long they are open. N/A applications tend to be high duration with a good bit of overlap for better flow. Boosted applications use short duration cams to prevent the boost from seeping out the exhaust valve (little to no overlap.)
Normal: moderate lift, moderate duration
N/A street: higher lift, longer duration
turbo: very high lift, short to moderate duration
N/A race: very high lift, very long duration
