Relocating IAT sensor
10-28-2004, 11:14 PM
Would it make any difference if I relocated my IATS from my last intake manifold runner to my intake tube?
10-28-2004, 11:47 PM
I
Why would you want to do that?
10-29-2004, 12:00 AM
I have an AEBS intake manifold and the spot on it for the iat sensor is different than my stock one. It gets in the way of my fuel rail
10-29-2004, 12:01 AM
I
I would assume that the temperature reading it takes would be different, because the air inside the intake manifold will be hotter. I guess it's worth a shot to try it though.
10-29-2004, 12:25 AM
gracias. i think ill try it as close to the intake mani as possible.
10-29-2004, 07:26 AM
Your tuning will be slightly off, because the sensor itself as well as the temp readings will be significantly cooler.
Stock ECU? Programmable?
10-29-2004, 10:28 AM
10-29-2004, 10:30 AM
Keep it in the manifold. Temperatures in the manifold will be different than the reading in the intake, enough to make a difference and limit any tuning capabilities significantly in the future.
10-29-2004, 10:35 AM
how should i go about doing that? there is no spot on the new manifold for it
10-29-2004, 11:13 AM
Edit: re-reading your original post...
Can you shave any part of the sensor or fuel rail to make it fit?
