Removing the ECU from 99 GSR
OK, my last car got stolen so I am really paranoid about this one getting jacked, especially since it is a GSR and there have been some car robberies in my area recently. Is it difficult to take the ECU out so noone can just start the car and get off with it? Can someone please explain how to do it? I have to leave my car parked for up to 8 hours sometimes in a lot and I want to make sure it is safe. Thanks, any help is appreciated.
The deer had to die!
dude, honestly....pulling the ECU out when you park and reinstalling it over and over again will get to old and tiring you'll stop anyway. just get a good alarm.
however if you want to do it....pull out the passenger kick panel, unbolt 2 or 3 10mm bolts and disconnect the harness. mind you....you'll probably have to pull the negative battery cable to prevent surging the ECU.
I do got an alarm.... its just that I gotta park it for long periods of time at a college campus when I am in class/work. It could take me 20 mins to walk back to my car so a good alarm would be useless anyways. I'm paranoid as hell and I ain't tryna have my car jacked again.
Originally Posted by noteful
Which one is easier? Can you tell me how to it?
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
I
Fuel pump switch, starter kill switch, hidden in the car. Or, you could remove the ECU from the stock location, and just tuck it under your floormat. Then all you have to do to remove it is unplug it from the harness...but you'd have to carry it around everywhere.
WHAT OK YEAH!
Originally Posted by honlscoupe
wire in a swtich to your fuel pump so that when the go to start it there is no fuel
