integra electric hatch stuck?
Old 09-06-2004, 09:00 AM
brothalynchhung
brothalynchhung's Avatar
Default integra electric hatch stuck?
Yo, I got a integra with the electronic hatch u know the little lever in the back that u move to the side and it opens anyway i do that i can hear the relay and possibly the motor trying to move its just not poping the latch, Any ideas??? if the latch is broke or the motor how do i even get the damn thing open to change it?
Old 09-06-2004, 09:20 AM
carta79
Life after death
carta79's Avatar
I don't have a hatch, but if I did I would stick my key in and turn hard.
Old 09-06-2004, 10:47 AM
brothalynchhung
Heh, nahh its electric all the key does is lock or unlock the locks... its electric has a switch in the back under the hatch the relay clicks and the motor does something but no open... is weird shii
Old 09-06-2004, 11:06 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
I could have sworn that from the factory, the 94-01 Integra had a cable-operated remote trunk release.
All you had to do was lift up on a small lever near the drivers seat, and the cable would trip a lever, unlocking the trunk.
Now, if someone installed an electric solenoid as part of a keyless entry system, then it's certainly possible that the solenoid itself has failed. Also, the cable may have snapped or disengaged from the lock.
Open the hatch from the outside using your key, then remove the trim panel that covers the back of the trunk. The lock is bolted to the inside - obviously - and you'll be able to visually inspect the lock and related components.
Old 09-06-2004, 04:36 PM
brothalynchhung
No, this is a stock feature. Not added, the fuel is the only in car lever its big and takes up the whole area where on older integras had both trunk/fuel. I can take a picture if you dont understand. But im certain its a stock feature. it is absolutly cable less and i can hear the motor doing something i think its jammed
Old 09-06-2004, 10:03 PM
Tobra
Tobra's Avatar
What year is the car?
Old 09-06-2004, 10:07 PM
FA9S8U
FA9S8U's Avatar
My '01 Integra has that...I was shocked when I first saw it, it also has the key lock I would try and unlock it useing the key and see if you can remove the trim and see what is up!
Old 09-07-2004, 07:30 AM
brothalynchhung
its 2001 integra type r
Old 09-07-2004, 12:06 PM
1funride
99 Integra LS
1funride's Avatar
I have the same prob with my 99 LS. I have taken out the side and back panels to see what's up. Everything is connected. Although I saw there is a little black box mounted on the side where the antenna is and am wondering if that part could have gone bad. I think it is an acuator, but not sure since I don't have a repair manual. If any body does have a repair manual your help would be greatly be appreciated
Old 09-07-2004, 06:30 PM
brothalynchhung
Yeah its pissin me off, someone has to have had this problem so POST U BASTAGE =P
