Caring for GSR
I use my gsr as a daily driver for the most part, and i tend to rev in the 6k-8k rpm range probably 10 times a week. Is this a lot for a dd? Anything i should be especially aware of when maintaining my teg? I love the gsr, and I get so addicted to the upper rpm range, but I don't know if i could be imposing any sort of damage to my car by doing this so much (or at least a lot to me).
4500rpm hesitation
6k shouldnt hurt it. Do you know what block it is? 8000 might be abit much for some. Anyway high revving wont hurt it usually, just dont run 7000+rpm *everywhere* and you should be fine.
4500rpm hesitation
Let me clarify abit more. my B16A2 can rev up to 8200 stock, any higher probably wouldnt make power anyway. With some of the other B series they rev lower.. so you might want to figure out what engine exactly you have and then go check out what the redline is on it. Thatll give you a pretty good point to stop before, as its never good to redline constantly.
u also waste more gass everytime u rev it up for the vtec to kick in.
The deer had to die!
if you are gonna be rev-happy with it (and i don't blame you), you may want to use a better oil. for instance, mobil 1 synthetic....provides great protection and wont breakdown in that RPM range.
When you change your oil, look for any metallic color or shavings to see if you aren't damaging your block.
Well, it is the 95 gsr, so it is the B18c1, with redline at i believe 8100 and fuel cutoff at 8200-8400 or so. Yes, I have been using quality oil, and i replace it every 2500 or so, just to be extra cautious. As for mpg, when i do rev it quite high, i usually baby it for a little bit after that, sort of compensating. I still get about 28ish mpg most every time. thank you
Hondas love to rev, your car is designed to rev like that, just don't drive it like that all the time.
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
CHRISTMASTIME IN IRAQ
Originally Posted by
LT6916
Great protection and such, but burns off like a bitch in the higher RPMs.
I like my 5w30 Honda OE oil... Works fine for me!
2009 Manual Fit Sport with Navi in Taffeta White
Epoch
i hear that...it hate the "VTEC evaporation" of oil. but i was getting the same thing with my LS motor too...
LT6916
When was the last time you checked you valve lash? After making sure all the valves were completely to spec, I noticed a marked decrease in VTEC oil consumption... but then again, mine were way off
Seni
I had a bullsh1t 70hp cx motor in my 95 coupe and one thing I have to say. I NEVER DROVE IT UNDER 3K unless I needed to stop. I beat the hell out of that motor and only changed the oil like 2 times a year. Man I miss that baby. No power but a hell of a tropper. I have an ls now and I beat on it and everytime I do it seems to act a bit funny. I blow 2 motors and broke a tranny once I have parts falling off and creating a trail behind me. Ohh man that was a funny night. Car made it about 50 feet away from my house so I pushed it up the driveway.
Ohh yeah your GS-R will be fine at that RPM Just keep up to date with all the parts and stuff and you should be ok. If you blow it send me a PM and I will be happy to sell you a motor
Epoch
i did the valve lash before i installed the motor (3 months ago).
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
