Will jdm dc 4-1 header fit my stock CAT???
Old 07-26-2003, 01:18 PM
YelZnkr
YelZnkr's Avatar
I am buying a jdm dc 4-1 header. It has a 2.5" collector. Will i have to change my stock CAT to fit it???? or will it just bolt on??? Is there something i can buy to make it fit???
Old 07-27-2003, 12:54 PM
otb2000itr
otb2000itr's Avatar
It will not fit your stock cat...you will have to buy one with a 2.5" collector to fit...might I suggest a carsound cat. They are the preferred cat of most Type R owners, including myself.
Old 07-28-2003, 03:55 PM
kabob
kabob's Avatar
Not only that, the header collects further back than the stock catalytic converter. You will need one that is shorter than stock w/ a 2.5" collector. I'd recommend getting a Carsound cat through http://www.testpipe.com
Old 07-28-2003, 05:18 PM
98 CW ITR 322
98 CW ITR 322's Avatar
So kabob, with the JDM header and carsound cat,do you then have to modify stock R exhaust, or does cat bolt up on exit side?
Old 07-30-2003, 01:36 PM
Type R 98
Type R 98's Avatar
I need a Test pipe that'll have a JDM collector with a USDM end to it... do you think this is complicated to get?
Old 08-01-2003, 05:16 AM
kabob
kabob's Avatar
I'm not sure, yet. I've been having a hell of a time getting a proper-fit OBD-II compliant (yes, someday I'll go Hondata but I'm a broke bish right now :P) Carsound cat from Hybrid Garage. They sent me one that didn't fit on the header side (had to angle the bolts which leads me to believe it would leak exhaust) and no hole for the rear O2 sensor. I sent it back to them in April and Dawn just now told me that they're sending me another one. Long story but she's been pretty nice about the whole fiasco
Right now, I have a test pipe that I got from testpipe.com that I'll try installing this weekend. I'm a little wary of it since it's not resonated at all (just literally a straight section of pipe with flanges welded on either end) but I'll see how it works out But if I ever get that Carsound Cat, I'll be installing that, instead.
Old 08-01-2003, 07:49 AM
Trey
Guest
Posts: n/a
Look at www.hybridgarage.com for custom made cats to fit your application for great prices. Good service too.
Old 08-03-2003, 11:14 AM
98 CW ITR 322
Does anyone sell a 2.5" cat and exhaust that will bolt up to Honda JDM header?
Old 08-03-2003, 09:58 PM
kabob
kabob's Avatar
I'd just recommend you buy them seperately. You'll probably get a better deal that way.
Old 08-04-2003, 12:34 PM
Type R 98
Type R 98's Avatar
Yess Used JDM at passwordjdm.com will get you a cat for 125$ and exhaust for like 350$
