View Full Version : '92+ Civic/EL & Del Sol
  1. brake lines again
  2. 98 Civic LX IAC Valve Help.
  3. 98 civic barely start
  4. Car issues: any ideas / help?
  5. Air filter box the same on all 7th gen?
  6. hella overheating prob
  7. vtec swap?
  8. E85
  9. Interior fabric glue?
  10. Erratic idle at start up
  11. HELP squealing noise after car sat for 1 week!
  12. 92 civic si help
  13. Car running cold.
  14. Changing head gasket
  15. taillight wiring harness
  16. Where is the radiator fan switch? or what ever makes it engage
  17. obd2a to obd1 jumper harness pinout please
  18. Heater core question
  19. Strange problem with squeaky brake drum 7th gen
  20. swap question...
  21. Recommended clutch kits and flywheels
  22. jdm eg doors
  23. best size tires for my civic suggestions please
  24. Car broken into now hazards come on when any door is opened
  25. A New Build
  26. tire leans in on top after wrecking car what could it be.??
  27. Noxious fuel smell in cabin
  28. 98 civic OEM injectors
  29. power door panels
  30. Need help I have no brakes!
  31. I know, ?WTF Swap? i have questions
  32. fuelpump?
  33. need a crank!!!
  34. Need help with Super over heating motor
  35. Learn from my mistakes - Civic HX
  36. Alternator Overcharge + The Aftermath
  37. The 6th hatch is dead. Here is a history of my all my Hatches
  38. Please help. (LONG POST)
  39. '92 vx fuel pump fails after short trips.
  40. HELP, Rough Idle After Car Warms Up
  41. Your Professional Lighting Adviser
  42. Please help! 2001 Civic suspension problem
  43. Honda gurus help my bogging issue.
  44. Timing Help
  45. suspension help
  46. Type R style lip for an EK hatch? Where to buy?
  47. looking for a little help with my hatch
  48. 99-00 Si Suspension?
  49. 92 Civic Part Out
  50. Trans/clutch noise??? Throwout bearing???
  51. Seeking parts in and around phoenix 90 crx si
  52. 2000 honda civic ex and sub?
  53. 1st OR 2nd gen b16a for my EG6
  54. 96 Civic Turn Signal Won't Cancel After Turn
  55. 97 Civic LS-Driver Door Won't Open
  56. Strange overheating problem
  57. 94 civic coupe suspension overhaul
  58. timing belt change
  59. 93 hatch service manual
  60. need help
  61. 93 Hatch Rear Disc
  62. Brake light on dash stays illuminated
  63. Fuel pump overheating?
  64. 2000 civic Si
  65. front bumper from ebay
  66. P2P ecu help
  67. tach wont go up to 6000-7000 rpm
  68. camber wear
  69. p0132 code
  70. 2002 Civic Si
  71. D15B7 Compatible Crank
  72. 00 civic si test pipe
  73. Does GSR Side Mirror fit 2000 CIVIC SI?
  74. 96 Civic at 4k while going 40mph??
  75. 92 Civic Si cruise control help. . . please. . .
  76. need help on my Y8 swap
  77. 96 Civic Lowering - Questions?
  78. Transmission or just a CV joint?
  79. D16z6 build Help please..
  80. help.... my 95 civic wont start
  81. What do i need for a reliable B20 vtec turbo swap?
  82. Aftermarket alarm deactivation?
  83. stuck in 2nd gear
  84. 95 Civic No Start
  85. new here
  86. 94 EJ1 D16z6 (What would you do?)
  87. Best brakes for daily driver
  88. Oil leaking.. where is this coming from?
  89. Car will not go over 25mph Sometimes
  90. Dual gauge cluster bezel dash pod
  91. intake manifold & Throttle Body
  92. Speedometer and Odometer not working
  93. Rear disc conversion question
  94. Can I add keyless entry to a '99 GX with junkyard parts?
  95. '95 Sol Speaker rattle/vibration
  96. tranny just went out??
  97. Need 00 Civic Shock recommendations
  98. Car dies when clutch depressed :(
  99. 92 Civic DX Starting Issues....HELP!
  100. JDM B18C in 1992 Civic Hatch (+ brake upgrades?)
  101. question about oxygen sensor whats the best
  102. Alternator or water pump? Video Included
  103. Getting brake drums back on
  104. alternator help and check engine light
  105. Help me? Transmission + other problems
  106. Axle and transmission fit???
  107. nice
  108. painting headlights
  109. speedometer stuck
  110. no start civic
  111. quick coilover/strut question
  112. 97 Civic Lover Looking For New Car
  113. Window Troubleshooting
  114. Video of my Del Sol at the track (1 pass)
  115. Reverse lights won't turn off Eg 5-speed
  116. Gauge cluster lights do not work...AC controls do...help?
  117. Drum Brake Swap
  118. Muffler for '96 Civic
  119. Tony's 09 Thread
  120. Re-using ATF(filtered)
  121. No Fuel but runs?
  122. Led taillight civic coupe 96-00
  123. No Start Probled WEIRD!?!?! Help Please
  124. ITB`s and stand alone
  125. cam crank seal hard to replace????
  126. So it begins!!
  127. '98 Drum brakes... problems... I give!
  128. Crank Fluctuation Sensor neccessary to change?
  129. D series chatter or ping noise question
  130. New to forum
  131. 94 civic hatch w/ ls swap havin issues
  132. New Member. Hello!!! and I have ?? turbo?
  133. intake
  134. Tune Up
  135. d15b vtec motor.. any opinions?
  136. 97 Civic Tail light part # for coupe vs 4dr
  137. swapping from d to b series
  138. big problums
  139. well, that's interesting v.axle problem
  140. Frustrating '98 Honda Civic EX stall issU
  141. install side marker
  142. << Helppp my stolen civic [Bronx / NYC] >>
  143. d15b overheating problem
  144. starter relay location 99 ex?
  145. something WAAAY different
  146. brake light not working
  147. How DO YOU Identify?
  148. help with windshield washer on the hood
  149. Check Engine Light
  150. Intake Manifold
  151. del Sol GS-R swap motor mount help
  152. b16a swap question!!!
  153. 03 civic tach wire location
  154. How to install powersteering on 95 Honda Civic Hatch
  155. noob stumped on map sensor issue
  156. Buzzing sound under dash when turn signal on
  157. what is this green hardness?
  158. main wiring harness connector
  159. need help about fuel injectors and fuel rail
  160. Need help on a 2000 CIVIC SI
  161. suggestions please!
  162. 1998 CX D16Y7 stumbling on hills
  163. Help please, b16A2 cam seals replacement
  164. New
  165. hey guys need help
  166. 2001 Civic EX Lowering. . . .
  167. California Smog Test
  168. Normal?
  169. Overheating while conected to obd2 inspection machine
  170. Circlip wont go in Ball Joint
  171. Rear brake adjusters won't work
  172. Side Mirror swap?
  173. just got my motor need with with harness
  174. how to bleed the clutch
  175. how to change cluctch
  176. Helpppppppppp plzzzzz!
  177. leaking cv joint
  178. 99 si won't turn over
  179. code 4 crank angle sensor 92 civic
  180. Civic wheel stud knurl size?
  181. HELP: Battery Light comes on then goes off...then on then off
  182. My 93 DX Project
  183. How many mpg for a tank?
  184. ITR Front Upper Strut Bar on a EK civic?
  185. just want to make sure
  186. Starting Problem Still!!!
  187. ITR Front Strut Bar on EK?
  188. 94 honda civic
  189. Tony's Hatch Project
  190. New Here
  191. Need Help Choosing Turbo
  192. ECM/PCM internal circuit failure
  193. Starting problems
  194. My dad and I want to build an EG...
  195. 95 Trunk Lid?????
  196. 93 civic ex coolant leak/long post
  197. Help brake hose leaking
  198. Need some help getting my civic back together!
  199. Need some help getting my civic back together!
  200. I fail!!!!!
  201. del sol axleback fit on an EG???
  202. recommend me
  203. turbo d16y8 simple question
  204. pvc valve draining oil????help needed....
  205. engine check light
  206. Ej8-what is that- looks like an EM1
  207. Power Window Poblems in 99Si
  208. civic radio backlight
  209. Upper Control Arms Help
  210. Exhaust vs Intake Valve Stem Seals
  211. vtec probs, still!!!
  212. halo install
  213. Intermittent Vtec
  214. Map Sensor + Speed Sensor FS
  215. 93 VTEC Question
  216. Quick question on suspension civic/integ
  217. Yay! I deeed it. AIR tools.
  218. Tire size question need answer quick!!
  219. need help civic 96 hb idle problem
  220. Hesitating at low rpms?
  221. 97 civic headlight replacement
  222. Obd ii
  223. Where to find High Output Alternator
  224. Timing Belt 1995 Honda Civic Ex 1.6L
  225. How much oil 99 HX?
  226. At a stop, the rev meter and car will rumble.
  227. Headlights
  228. Shift light in 96 DX
  229. Lost keys for Civic 1.5 Vtec -96 {3 doors}
  230. Frustrating Idle/Stall Problem
  231. 1993 Del Sol stalls, then runs fine:
  232. wiring help needed
  233. Repairing Coolant Drain Plug Threads,, Help?
  234. 96 SI SWAP need help.
  235. Noob question ; 94 Dx Hatch
  236. Dash dimming problem
  237. Mudflaps that will fit my EG hatch...
  238. My HX has alot of issues!
  239. need help on new swap..
  240. I seriously want to cry. Worst day of my life. (56k no no)
  241. KOni/ Gc custom spring rates???
  242. ride is crappy, shocks or springs?
  243. supercharging CTR engine pros/cons
  244. Code 15 HELP
  245. starting problem
  246. 97 civic and a 2000 civic problem deck
  247. Turbo crew: B16a2 GT3037 Turbo....what injectors?
  248. pull deck out, something burn and now no power? help please
  249. need help idle problem!
  250. help me ID this part
go
