- 2006 Honda Civic Lx Immobilizer Problem
- Calling SRS airbag experts........
- how can i buy these things?
- Check Engine Light
- strut problem
- Foglights
- wiper problem
- Vtec Wiring
- Pressure question
- oxygen sensor
- 99EK Swap - 99-00 si error code p0113 need help
- need help 99-00 honda civic si
- barometric sensor - code 13-please help!!!
- 2000 Civic Idle problems
- D15Z1 into Del Sol?
- what is this???
- AM radio not working in civic
- shifting problems
- question about 97 honda civic 4 door dome light
- How much would some of these parts cost?
- Firzt Post - '92 Civic Ferio
- head swap d15b8 with d16z6 ???
- Civic won't start, battery...
- Civic Leak
- Keyless entry 02 Civic
- Hmmm...
- Should I pick this engine up? Junkyard engines, low miles still risky?
- HX to EX trans - gas mileage?
- Changing out a Dx cluster for an Ex one.
- b18c1 vs b16a vs b18c5
- 97 honda civic
- leaning the mixture
- Help!
- I want more...
- Bad Gas Mileage!!!! why?
- stolen honda emblem
- bodykit
- Anybody rig up a quick-release rear strut bar?
- anyone with an eg, need a favor
- Master Cylinder / Slave Cylinder
- help mee
- Suspension On An EK9
- exhaust smoke
- heavy breather air
- 96-00 DX catback onto a 99 ex?
- Auto Service Manual
- ok someone please help me...
- Wondering if it will have enough power....
- ZC DOHC obd1 Trany ?
- EG/EJ Speedo cluster questions........
- 2007 Honda Civic Hybrid review
- swap help
- who wants a free carfax report
- power locks
- Car Quit Need Some Suggestions
- Just wondering.........
- green honda with gun metal rims?????
- Help?
- Leaking tranny fluid
- 99 Civic SI Problems...
- can someone please explain what top hats are
- Is this everything I need to add SI swaybar?
- Recommend some plugs?
- catalytic converters
- Traction problems
- accelerating problem
- Cleanser Ideas???
- spedo problem
- gas mileage in 1992-95 si?
- ek- b series help
- thinking about buying this
- Civic Si IACV trouble codes
- jdm prices?
- engine swap
- Too much of a drop
- Huge Problem Need Help!!! Please! Anyone!?!?
- suspension opinions
- weight differences of 1992-1995
- Turbo pistons?
- annoying clicking sound and very weird problems with power windows/sunroof
- So my car has 112K miles on it, whats some mantainence i should do on it?
- Resetting ECU for error code in Lambda probe?
- Got a new EG hatchy !!!!!!!
- 87 CRX Si.......
- Natural
- I need some info on this....
- Japan D15B
- Pro series + or Classic?
- New Clutch
- 2006 Honda Civic Problem!!!
- Car wont start
- I need Help with a ZC DOHC 92-95 Swap
- Help With Turbo Set Up Please!
- code 9 help
- Running925's 2007 Build-Up Thread
- 92civic and 91civic distributor wiring help/diagram
- Wont go into gear.
- questions for people with illuminas
- So what do i need to do my car to accomplish this...
- Blower problem - only hot air coming out of vents
- *Pics*current update*Pics*
- 105000 miles routine maintenance ????
- help with custom magnaflow
- LED Fog Lights!!
- Question on tires
- Help ASAP...
- Jacking points 05 Civic LX
- 94 hood fitment?
- Looking for a Good Shop in OREGON
- brake noise
- hx engine, revs up and down while driving..
- rear disc brake conversion...
- anyone know where i can get...
- Question..For The Pros i guess.
- PowerLocks/DomeLight/Keyless Entry ?
- a little confused here
- Have springs, struts - need anything else to replace suspension (245K on 96)
- Online Parts Supplier?
- Clutch/Transmission problem on B16 del Sol
- 95 civic acting up...
- Blow Off Values
- my POS failed smog
- couple mods coming up....
- Exhaust problem
- Brakes scraping noise
- #*&%(#% Toyotas
- D15b7
- 95 civic door frame
- Good low-profile jack and spring compressors?
- gauge cluster swap
- Pictures of a wide body kit install?
- Window
- help me with a couple of problems...
- MPH Gauge
- Best place to get clutch put in?
- Removing the Door Panel
- tear-out problems with front sway bar?
- rattle noise when clutch released
- scratching noise
- answer me this?
- extended wheel studs???
- Honda Civic Start button with Bugatti Veyron effect !!!
- Cel Code: 54. P1337. CKF SENSOR HELP!!
- should i upgrade?
- Shoud I get this flywheel? ($140 for 11.9 lb ACT)
- HELP! losing power between 3k and 4k
- Brake Questions
- SI Lip Kit
- any suggestions???
- head rest
- can someone do me a favor please? (simple wire and speedo question)
- Sell the HX for a VX?
- omni power?
- HID's On Projectors?
- Newb with Questions
- Slow 1st Gear
- Will headlights from a 2000 bolt on to a 96?
- Tokico Springs didnt lower
- wheel stud replacement
- 100k miles, vibration ..can anything be done?
- my blinkers dont work when hi/lo beams r on
- air intake
- Orange County/LA Transmission Shops
- Window now moving up and down by itself?!
- 95 civic surging
- vss wtf! i have no clue what to do now
- break-in time for f1 stage 1 clutch
- 93 dx problem
- Wtb
- Intake Question
- Temperature gauge below C
- Whine, only at 3K RPM?
- New Head
- Blown Engine!!
- How much should I pay?
- need wiring diagrams
- tein springs instead or eibach prokit?
- integra el seats
- turn signal help
- Left front turn signal
- burnt valve question
- engine swap question
- getting ready for paint
- Passenger side window - no movement at all, as if switch is dead?
- 1994 civic si axle install problems!!!
- Almost finished. Bought it for $300... of course not the way it is.
- axle problem again
- Dielectric Grease
- o2 sensor question
- NEed help wit new swap!?!!?!
- help with GSR swap into 99SI
- 02 Civic Engine Bearings worn (why?)- problems with warranty! HELP PLEASE
- Ignition Timing question
- Code 19 Help..
- Whats the tire size?
- Hurry Please I Need Fus Box Layout
- 2000 Civic DX Hatch AT TLC
- Suggestions for suspension
- I need your help guys....
- Steering wheel change
- What size spacer?
- 92 civic dx swap
- Hey guys, is this a good deal or a possible money pit?
- copper spraying head gasket
- what dyou guys think?
- B18C1 valve seal replacement question
- gas
- 1996 Civic Hatch CX
- help
- Final Drive gear set for JDM J4D LSD
- aftermarket radio & interior light issue
- 94-95 EG/EJ Air Conditioning
- Chassis code thinker
- crower cams ???
- Possible dying alternator?
- HELP! cant make ANY aftermarket cd player work in my hatch
- wiring up vtec, only has 1 wire comin out of it :(
- Possible brake light switch problem '95 civic
- d15b head ?
- i want dished wheels dammit for my civic hatch.
- Anybody run Tein H-Techs? Good shock combo?
- 98' civic v-tech won't crack
- ? on replacement flywheel, clutch for 96 HX
- Considering these wheels
- new to civic area.
- 5th Gen. Brake Pad Retaining Clips
- Difference between manifold and header
- noob question
- distributor/timing help on swap
- Need your help here!
- Honda Civic 97 EX/Sedan
- XM radio
- anyone have a pic of b16 idle screw?
- Help deciding which wheels? (56K)
- can anyone tell me the d series code
- CEL code 41
- type-r tranny
- anybody know where to find these?
- Del Sol Tranny swap
- Intermittent problem on starting
- Quick engine Fit question
- Another programming question
- ek trunk swimming pool
- starting problems.
- no spark
- Question on FI
- quick question
- very hard decision and wanted opinions
- Heater Core Replacement
- lights
