View Full Version : '92+ Civic/EL & Del Sol
  1. Which Brake Pads and rotor should I buy ?
  2. Can I use STP Power Stering fluid or HG fluid only?
  3. wheel well
  4. Blown driver's side motor mount bushing.
  5. noisy interior
  6. one-piece headlights
  7. bye bye white wheels
  8. black hood pins anywhere???
  9. Haven't been here for a while But im back.. w/a TURBO D16 :)
  10. Getting rid of power steering?
  11. Hiding my nitrous kit,...
  12. ok need advice (suprise)
  13. Used dc headers?
  14. what engine...
  15. Red Indiglo Gauges
  16. i got another car...
  17. Turbo sol!
  18. Suspension advice...
  19. Is this a good deal...
  20. tein ss height adjustment
  21. another pic of a civic
  22. OMF! My engine>update
  23. Should i Fix it or Sell it??
  24. down gear from 3rd to 2nd
  25. Rims
  26. Knowledge on Engines
  27. pics of my rotas, intercooler, and wing
  28. You 6th gen Si owners will like this
  29. Guage Cluster Swap
  30. Own a Civic Jordan???
  31. why are b18c5 motors so expencive
  32. Trunk release question
  33. I want a nice muffler
  34. Gauges in progress...
  35. LED Bulbs
  36. just got my car dropped<= with pics!
  37. first pic of my car and a photo shop request.
  38. rota grids installed pics...
  39. new toy from JDM land
  40. Screw you guys, I need some mirror suggestions
  41. Oil Pan Size
  42. Dyno Results w/ pics (1MB)
  43. Pin Stripe Removal..
  44. Spark Plug Question
  45. SSR rear control arms
  46. Water pump?
  47. *night pics* found those yellow turn signal bulbs.
  48. 97 HX gearing similar to EX trannys?
  49. tanabe is killing me
  50. umm can you help me?¿
  51. Civic Intake...
  52. glamour shot rip-off thread
  53. need help on 2003 civic ex
  54. Cooling Fan
  55. have you heard of this?
  56. worth how much?
  57. Paintjob questions
  58. Glamour Shots of white_n_slow :oh:
  59. Hey guys Post your Steering Wheel pics
  60. DIY exhaust question
  61. what would cause the muffler vibration?
  62. Looking for gauge pod or holder.
  63. hey check this out!
  64. b16a
  65. *PiCs* Return of the X *PiCs*
  66. Which cat exhaust to get for my car?
  67. short shifters
  68. DC Style header
  69. Clutch Master Cylinder
  70. what is a good price?
  71. hood lever snapped. how can i fix it?
  72. Drag strip for the first time.. and my time!
  73. Need Help!
  74. Check dis out !!!
  75. Lowering a civic
  76. Koni Yellow Price
  77. Which Plugs Are Best For N/A?
  78. Updates on my Ferio wannabe.... no 56K
  79. head unit stoped working
  80. -Mileage?-
  81. AEM Alternator pulley 2000 Civic
  82. FYI: Rota rims and camber washer trick
  83. Does anyone have these oem wheels?
  84. really bad luck :(
  85. Junkyard Turbo setup D16Z6
  86. Custom Rims:bye narib_16
  87. CAI for a SIR II (b16a2)
  88. B18A1 into 5th gen questions
  89. Good spark plugs and plug wires for stock DX?
  90. Building turbo setup for cr/vtec Civic hatchback...
  91. ahh! axle won't budge!
  92. Fitting an FMIC in a 99 EX. Help!
  93. I can't make up my mind =\
  94. Conversion
  95. new to forum has two cars which should i work on?
  96. altezzas ?
  97. Many options I need help with.
  98. 93 civic climate control
  99. just giving you civic owners a heads up...
  100. Counter Act electronic rust prevention.
  101. question on shipping cars
  102. Removing Rear Speakers in 2000 civic
  103. Strut Bar?
  104. Help picking an exhaust
  105. more toys
  106. New wheels and brakes
  107. streering wheels and airbags?
  108. tanabe racing medallion powered by dog
  109. tein s-tech VS eibach sportlines
  110. RPMS going too low
  111. swap update *pics*
  112. Anyone have any info on the 2006 8th gen civic?
  113. HA HA! I know what I am gonna do this weekend!!1
  114. What yall think of this deal
  115. Will 18's fit on a 97 two door civic?
  116. got the new skunk 2 cam
  117. will 00 si struts fit on 92hb?
  118. Warped Rotor
  119. Anyone have experience with...
  120. Lug Nut Question
  121. turbo y8 cooling problems
  122. b16 A short block
  123. can't find these wheels
  124. i like these fog lights (ferio)
  125. Somg
  126. first oil change
  127. Replace clutch if running zex kit?
  128. thermostat
  129. 17" or 18" Wheels or VTI Hatch (160Bhp)
  130. do u think this color is gay?
  131. which rims and tire size
  132. Swap DX cluster for EX cluster?
  133. Enkei GTV spec
  134. 15s / 16s / suspension ????? HELP!
  135. few questions for my 03 Civic Ex
  136. tein ss height adjustment
  137. 95' civic motor problems
  138. New Engines for Del sol
  139. pics fo my rims and tranny
  140. so i've decided (for the coupe)
  141. Aftermarket Struts on Stock Springs
  142. 2002 Silver Coupe
  143. Painting
  144. hatch struts leaking??
  145. Exhaust Opinions for 98 Ex
  146. What gas in SIR ?
  147. Check out what I just got :oh:
  148. Arite, this one is about Swapping motors.
  149. $450 for a D16 P&P head worth it?
  150. Rocker ARM - HELP
  151. Widest rims on EG?
  152. Good Places To By Civic Stuff
  153. 'Where to start...
  154. is this a good offer/combo?
  155. So I weighed my car
  156. ride adjustments for new bushings
  157. what should I do First?
  158. blower motor
  159. How much do new air bags cost.
  160. another lip question
  161. dx tranny leak...but where?
  162. b16 wiring help
  163. Type R lips
  164. hatchback interior
  165. I want SOL
  166. Ground controls :up: instructions :down:
  167. rear right shock squeaks???
  168. what mirrors will fit a civic hatch 92-95
  169. where can i purchase?
  170. Weight and racing
  171. ABS Plastic / Urethane / Fiberglass???
  172. my car, finally
  173. my new engine
  174. FF Squaderages.... (56k go away)
  175. popping sound when i turn...
  176. screwed up paint
  177. I Was Bored.......
  178. My Lips
  179. 00 2dr Thin Side Moldings
  180. Best turbo for custom kit?
  181. I need help on my civic hb
  182. Mugen Lip Painted
  183. Replacing axles..
  184. newbie
  185. Engine Swap
  186. Air Intake Sensor?
  187. when to let off the clutch
  188. Using washers for camber correction?
  189. cylinder head question.
  190. Anyone build an engine from a Dart block?
  191. Vis Evolution
  192. My Messed-Up Suspension
  193. Gas Station Pics.....lol
  194. nice lights
  195. Tranny question
  196. any ever rebuild a tranny?
  197. what do you think?
  198. Type-R lipkit pics?
  199. Torque Converter
  200. headres & exhaust
  201. civic custom turbo kit
  202. 92-95 Civic HB
  203. Got these in the mail today.
  204. Who here has painted their stock SideSkirts?
  205. :eek: cooked brakes! Fluid?
  206. Fabricating Exhaust
  207. quick question about port and polishing
  208. Its birthday time.
  209. Finally: 13's!!
  210. Did everyone reuse bushings when changing shock?
  211. itr red valve cover?
  212. as aked for (pics of the lights)
  213. Got my subframe fixed
  214. My hatch got stolen on friday morning, today they just caught the Fuc*er!
  215. Cold Air Intake for Civic LX 03
  216. new guy and new car
  217. Solers in the Tokyo area?
  218. sneak pic
  219. Simple questions!?
  220. EG Bulb Applications
  221. Civic Si rims same as 2001 EX rims?
  222. Exhaust Install
  223. any good websites
  224. remove rear seat
  225. Rear Brakes conversion
  226. Hemi
  227. YELLOW not AMBER front turn blinkers??
  228. EG JDM Climate Control Conversion
  229. What fuel pressure do you guys see?
  230. upper ball joints & tie rod ends
  231. Rocketz Headers
  232. Bright/Dark amber corner bulbs?
  233. Poll: side mirrors
  234. Where'd you get ur RS*R
  235. grounding wires
  236. header problem?
  237. Cat Converter length and flanges
  238. anyone heard of Champiro tires??
  239. body kits experts
  240. LSD tranny?
  241. Good place to buy a transmission?
  242. Question about Upper and Rear lower Strut bars
  243. Wut yall think of this?
  244. gsr strut bar holes...
  245. WTF!?!?!? WS discontinued?
  246. Konig Heliums
  247. Failed emmisions.
  248. Getting an Exhaust..Greddy Evo?
  249. battery
  250. IMMferio already. :wtc:
go
