- timing off
- 98 Civic: CEL & ABS Lights Flashing
- Civic si
- Where is the fuel filter on a 2003 civic EX?
- Any reason to choose a 2003 civic over a 2001, or vice versa? sedan vs. coupe?
- 92-95 Front End Conversion To 96-00
- car starting problems
- Car having trouble starting
- B-Series Valve Covers
- A/C Compressor Pulley
- DIY windshield install?
- Radiator Hose-that was close!
- tranny drop
- Universal parts
- clutch or tranny
- Dummy Keys
- Having Trouble finding this info. B16A ECU...
- Painting Rims. Suggestions
- Code 14
- vtec question
- how serious of a job is an iacv
- VIN search?
- my civic has wierd symptoms
- Buying Hondata?
- B18c5 Wiring into a 95 ex EJ1
- Now I gotta bypass my heater core
- ....Eg6 Proper fittings....
- troubled engine
- overheating on long trips only, help?
- Check engine light
- Radiator Core Support How To Please Help!!!
- Boost gauge question
- Rack And Pinion How To...please!!!
- what's the weight difference between the EG hatch and coupe?
- Problems with my 99 EX
- paint for wheel resurfacing
- 95 del sol - dies when i come to a stop-
- Problem Starting
- Oil recommendation?
- NGK vs bosch spark plugs
- 92 civic hatch extreme tire wear
- need help asap!!
- Car overheating WTF?!?!?!?
- New Oil Pan
- Trick to getting injector connector off?
- Auto to manual tranny swap
- Nice Shoes !!!
- rims for sale
- hey guys new to civics
- which engine is better for a turbo set up in a civic?
- driver and passenger side window
- camshaft question
- Do they even make gauge plates for 99 civics with a tach?
- HELP with car wont start
- friend needs some help....
- integra type-r conversion
- 98'y8mani on97'y7
- For sale;Nokia N95,Sidekick 3,P.s 3,Nintendo wii,Xbox 360 and more
- Wanli tires any good?
- Deal or no deal?
- anyone installed a skunk2 throttle body before?
- idle problem
- Control Arm problem
- engine swap help
- 01' Civic SRS computer install
- identifying d series lsd tranny
- wont start when raining?
- HELP H22A EK .. shift linkage problem
- lowering on sleeves
- 95 del sol --replaced distibutor cap- no spark
- clutch doesnt fully disengage
- Acura EL?
- Jerk Jerk Jerkin
- Help! Lowering 96 civic
- cluster bulbs
- Weird Suspension damage
- Problem Starting
- glass pack
- Radiator Flush
- quick coilover question
- It's running...sort of
- Pad Change - Bleed Screw?
- Now figure out this problem.
- Whining???
- HELP w/ fuel pump strainer for 92 civic si
- car has trouble starting on mondays
- Air conditioner works but not correctly
- 05 Civic Parking Brake
- how hard to fix
- question about window regulators
- Help...is't a good deal???
- obd2 to obd1 dizzy timing
- Where to get longer breather hose for intake?
- Slim ratiator fan wiring
- DJM parts 88-91 Honda civic hatch!!
- Heating Control - Civic Tropica 2000
- A/C Noise
- b18c1 rod ratio
- auto to manual swap
- 1992 honda civic alternator output
- obd2 to obd1 having issues with knock sensor and the vtec and more
- DIY axle question re: upper control v. ball joint
- d16z6 oil dipstick length
- what do i do to get the most proformanceżżżżżżż
- D16z6 turbo build
- need help with td04h......??
- After a couple years of waiting.......I get to start my GSR build
- Need help how to replace cv boot.
- Programming Remote Key
- b18a question :(
- pissin me off
- help!!! engine swap problem
- interoir paint
- What is this???
- Speedo, hazards, blinkers NOT WORKING! HLEP!
- Oil on plug threads (OMFG)
- 96 civic
- Let me try this again - CEL problem!!
- oil on threads of sparkplug.
- Check out this BAD machine....
- Valve Cover Gasket
- Keyless Entry and Alarm Not working
- Civic 98 coupe please help
- eg hatch spoiler
- HELP 95 gsr CANaDian GAUGE cluster swap into 1992 honda civic si hatchback
- body parts swap
- Cold start, starter sounds bad, won't start, warm no problems
- Blow-by, idling problem
- Intakes Question/Opinions
- Nothing
- Ugh...maybe someone can help me again..
- Please Help Me!!!!!
- 99-00 civic headlights
- elusive vibration. need some brake gurus here.
- Can Anyone Help Me
- Side Markers & Shift Boot Help!!!
- Update
- ac
- which valvetrain to run?
- >>>>>>best side skirts 4 EG6<<<<<<<
- Stainless steel header maintenance
- 93 civic mirror Q
- Calling SRS airbag experts.........
- 96 civic questions
- LED wing mirror wiring
- do they make 96-00 civic sedan m3 trunk spoiler
- WTB: B16 or B18C full swap or whatever you got
- As my luck continues on that steep slope.
- B16 Alternator in EG
- throttle cable problems
- 97 Honda civic factory alarm overide.
- '95 Honda Civic Del Sol Speedometer cable bad?
- Aftermarket Tail lights
- Help with "how to" on replacing Ignition Switch on 94 Civic?
- JDM del Sol Parts
- 00 Si acceleration trouble
- Bad Oxygen Sensor?
- Aftermath of changing the cv axle and lower control arm ball joint.....PLEASE HELP!!
- Civic Tranny Swap
- head gasket... crap..
- F/S 99-00 Si Wheels
- idling
- Wtb Or Trade Del Sol Seats
- idle problem
- rims?
- turbo people... read this please.
- radiator leak
- CEL issue - Help!
- '92 vx brake light/horn problems.
- Installing new springs,, how to tell the difference?
- The best seats Honda ever made!!!
- H22a or H23a
- Wiper Skipping!!
- Is it in fact possible?
- What can cause rough idle and almost stalling?
- Irregular accelarator
- Power Probs
- installing rotors and pads on 2000 civic si
- Need advice on fixing my eg :(
- b18a1 into 94 civic EX soupe
- part numbers for 1993 civic ex
- tell me more about hondas
- 99 civic auto to manual?
- Slight hesitation when starting car?
- Jumping around idle problem
- Struts
- Speedometer kicks on and off!
- Mail relay??
- EGR VALVE anyone?
- Integra front end
- Integra front end
- Intake manifold
- coolant reservoir..
- 94 civic SRS light
- headlights nee some help
- Question about Civics and Integras/acceleration difference
- Horsepower
- Need assistance change fuel filter 94 civic ex coupe
- need paint job on eg6
- B16 swap quick Question
- Alternator Brand
- 06 electronic throttle questions
- Help needed for Stoping AC leak
- 94 civic brake pressure
- 94 civic cv change Q
- HOnda accord 95 ex help needed
- ITR Cluster into EC CX Hatch
- Quick question about transmission mount
- Sedan CF Spoiler
- buddies car wont start
- Squeaky noise when pushing in clutch pedal
- bad luck last night.
- My New Del Sol: Please Vote!
- brand new clutch making noises???
- Weird sound while driving. Goes away when clutch is engaged.
- car stalls (or doesn't start) after sitting
- HAN need your HELP. H22 swap in 97 Hatch.
- boost to fuel pressure ratio
- Replacing gauges
- Civic 96 Dials gauge swap?
- Honda civic lx
- 00 Civic stumbling on acceleration
- cluster
- Primary O2 sensor help
- Carbon building up in the throttle body and idle valve?
- 98 Civic EX w/ b18c5 what exhaust to get
- How much of a perf gain with new headers and intake?
- hydroplane = curb
- Road Trip Pics...........
- Fresh Paint! 92 civic hatch
- help anyone
- 1994 Civic Ex Sedan... 4 Door Love!!!
- b20 swap into 94civic ex
- engine swap help b18a1 into a 95 civic dx
- effects of adding intake manifold
- I have a problem!
- automatic shifter getting stuck
- removing old gasket from intake maifold.
- Tony's Weekend Track Video
- Has anyone ever made an intake?
- need more speed
- turn signals dont work, need help!
- 1998 Civic is jerking
- b16 with turbo >?
- 92 Civic hatch OEM side skirt issue.....
- civic interior
- 95 Civic Dx
- anyone in the columbus ga area??
- CAI question
