- A little problem w/new Clutch
- New Plumbing v. Fix that air flow problem!
- Where is a good place to order a new OEM coil from?
- Speedo it TRIPPIN!
- 98 Civic Keyless Help needed!
- Water pump keeps failing - Third one
- car shakes??
- need ssome advice to swap brake drums with rotors?
- Roll Cage
- Fuel gauge problem??
- Car just dies
- b18c gsr or b18c
- b18c gsr into civic 92 help
- head gasket blown? need help figuring this out
- New Member - red yr2000 ex - opinions nessesary
- hot car
- exhaust comparission
- help with idle
- Manually lift power windows?
- Fix Sean's Car, It has the Clickity Clickitys!! OH NOES!
- Rear Camber Kit Install
- new to H-A.net
- MAP sensor upgrade for Turbo EG
- Wheel Studs and lost Lug Key
- best place to get an o2 sensor
- trailing arms issues
- best ecu for 95 civic with ls swap
- 94 Civic - New engine but no spark or injector pulse.
- new timing belt, no idle?!
- How To: Ceramic Coat a Header
- which engine bottom can fit?
- windows and wipers no worky wtf?
- 92 Civic distributor, ignition, coil
- Vtec question?
- How to seat half shaft seals
- eg6 with 94 up gsr brakes
- cv axle and tire wear
- Wiring Apexi VAFC-II
- I got a bad deal
- Thinking about getting MSD, any suggestions?
- few b18 swap questions
- What Is This Noise
- Need A Honda Bad
- getting lower timing belt cover off?
- 98 civic seats in 92-95
- 92 civic city lights
- Any tips on istalling white indeglo overlay on my gauge cluster?
- Tune-up, now bad mileage?
- Will 1998 Civic remote work for a 2000 Civic?
- Civic 98 Keyless Entry problem
- b18a swap-> eg
- Del Sol (Skyline conversion)
- Alignment
- oil weight
- 2008 Honda Civic MUGEN Si High Speed at $29,500
- gsr engine
- Fuel cutoff or inertia switch?
- Speedometer not working
- cv axel
- crakling sound when accelarates
- Problem one of rear windows..HELP?!
- Security System Problem
- Help! No Vtec
- keyless entry
- cluster problem :(
- Scoobies 08 project EK thread.
- need help wiring air/fuel ratio
- no led light on computer?
- Tires rubbing on a 99 Civic.
- Starting trouble, not due to main relay.
- 99 2-dr springs... photos wanted!
- S40 And S4c
- Should the inside of my civic's motor look like this?!?!
- underdrive crank pulley question
- How to remove sticker from bumper?
- There anything to put on this plastic headlights?
- civic passenger airbag
- Oil Gasket for 2001 Civic LX
- My car is sick :(
- Pkg
- I'm on ur trak breakin mah car!!!
- how much hp
- Help me pimp my car!
- Clean Engine Bay
- Charcoal Canester
- my 95 civic with integra front end conversion project pics
- D16Y7 ECM A/C Compressor Cycling
- Steering Rack for shorter turns?
- Uh-oh!!!!!!!
- Winter tire size recommendation - 2002 Acura EL
- Skunk2 Mani ?
- frame bent?
- Power window/door swap.
- automatic JDM-B16a2(obd2) 96-98spec
- Spherical Upper Control Arm Rod Ends Integra/Civic
- spark plug wires b16 and b18 interchangeable?
- care leans? any help wb great
- 1990 honda civic 4 sale
- Plumber's tape on radiator drain plug?
- speaker size in 1992 Civic
- air bag questions
- tail lights question... help
- Need some info on a ZC SOHC VTEC
- AC diagnosis
- want to get coilovers for my 00 civic! any recommendation would be nice
- Da - > Eg
- LS conversion on my EG coupe.
- Team Redline
- need to paint my rota slips
- Heat Wrap Header??
- 96 EX Project
- Pt cruiser
- Amp problems, it might be nothing new but can't get help on audio forums
- Temperature sensor
- Pulls to the left, only when on the gas.
- Suspension
- Can I turbo it?
- 96 ex transmission problems
- B18C1 w/ '00 Si Engine harness prob
- How did it blow? Pix & Explaination inside!
- 1996 civic ex Oil Pan question
- civic automatic trans questions
- how to replace struts?
- How do i replace strut bars?
- Accord starting problems
- Will 4dr gsr rear seats fit 99 civic 4dr?
- Best lsd to go with for a b16?
- Climate control lights 00 Civic Dx SEARCHED
- 94-01 Acura Integra Drive Shafts for 89 Civic?
- catalytic converter cat SEARCHED
- Idle problems - jrsc gsr
- totaled my honda civic
- non
- WTB Rims for a 98 civic
- How Do U connect Angel Eyes???
- B18B smoking.
- HELP! can't get the LCA holes to line up to put the bolt in
- 6th gen EX intake same as LX/DX intake?
- Wheel Bearings going ftl
- 93 civic white smoke out the back
- will a garett t3/t4 turbo spool with a d15b7?
- enigine swap
- head gasket blown?????
- D and B series turbo kits
- hatch with boosted gsr
- How low should I go?
- Worth fixing a 95 Civic coupe w/ 198k miles?
- eg side moulding question
- Idle Problems on D16Z6
- 02 civic P0171 trouble codes
- Radiator Fans
- Quick question, need new battery
- 98 civic transmission??
- B18b needs A/C
- Mounting/Balancing
- Ek4 SiR front lip!
- Need A Eg6 92-95 Motor, Tranny, Ecu??
- 17" rims on coupe
- Need help again...with paint!
- No Spark, solve this problem!
- EG6: rear springs on front?
- "L" Brackets??
- Passenger Window Problem
- Spark Plug Question
- Car Stolen. 97 Civic Hatch Roma Red
- 94 hatch vtec B20b
- gauges and radio shut off
- 2007 Civic Si wheels for $625 shipped? Seems like a decent price?
- 440cc injector
- WANTED Honda civic hatch
- Valve Adjustment with head off??
- throttle body strike two, spacer wrong size
- Flickering lights while driving?!
- si grille insert
- Need Help With Rims/Tires...
- power steering
- to paint or not to paint
- newbie
- Fathergoat's Official Build Thread '07
- stepping on brake at stop light, loses pressure goes to the floor
- 93 Si burning oil
- Speakers went out!
- master cylinder
- D16Y7 W/99 EX ECM Trouble.
- Radiator Troubles, del sol B18 Swap
- I want to get a short ram air filter...
- Project Lexus IS350 HID Retrofit on '00 SI
- Goat needs slicks :(
- fitment of my GSR IMO on my civic ex
- Civic 95 transmission problem (rattling noise)
- Map Sensor Problem?!?! Help?!?!
- Stock D16 sleeves
- How much gas is left?
- 2000 civic 1.6 motor
- Alternator or Alternator Cable??
- spark plug gap and torque specs?
- vtec? again
- 1995 Honda Civic LX Exhaust system
- vtec-e?
- Modifications to Newly Acquired Civic HELP
- 95 civic power window problem
- 1993 Civic Power Window issues
- Timing belt install on 94 civic ex help/question
- Driver Side Door Jammed/Won't Unlock
- Need Help
- speed sensor.
- clutch goin? reverse clunk? and noisy 1st gear
- Door swap wiring harness
- Rear Bumper mods to make it flow better
- JDM del Sol Headlight Harness
- 97 civic
- 94-01 acura fuel rail
- Clutch Bleeding Problem
- eg knocking sound
- gsr trans
- Turbo Question For D15
- Question about Distributor cap/Rotor replacement??
- LCA problem
- What would you pay for an EG with a K20?
- Clutch/flywheel replacement question.. In the process w pic
- window regulator
- Steering wheel and SRS airbag swap???
- what would be the best b18 gsr swap...
- Lambo door problem
- Brake Repacement
- 94 integra front end conversion on a 95 civic coupe
- Transmission noise, input shaft bearing? video included, please look
- Honda Civic EX
- B16 with nitrious. Need some help
- 96 Honda Civic headlight bulb replacement
- Please Help.
- need help taking this part of headlight out...
- how to test hid ballasts???
- Radio Flashing
- cv problem?
- turbo gsr
- car dies when i turn hard right.....
- Exhaust fitment question
- Idle surge, I've tried a bunch of things...
- rear disc conversion
- Changing Si Rims?
- 2000 Civic SI Keyless Entry and Stock Alaem
- 2000 Honda Civic Si V.S 1999 Honda Prelude SH
- 99 Civic sedan mirror question?
- How clean does a block have to be?
- CX TO DX swap
- turbo question
- pass window stuck in up position, moves by itself
- Overheating dilemna solved.
- hissing at the theromestat
