View Full Version : '92+ Civic/EL & Del Sol
  1. Coilovers or lowering springs?
  2. front bumper removal
  3. B16a2 head on b18b block?
  4. Maybe n00b question
  5. Helping out a noob with a 95 HB
  6. Pics of EK mugen ferio kit
  7. My Ther. Read hot?
  8. Tranny compatibility
  9. "ensure" wheel brand, any good? is it light?
  10. Jacking up the car
  11. Drag Turbo Kits
  12. cv boot gone bad, is this a common problem
  13. what the hell is this...
  14. Driver's Power Window Jumping Out Of Track (Take 2)
  15. D-series Si trans grinds when
  16. double checking
  17. LS Block
  18. K20A in a 93 Civic (without dreams, we are nothing)
  19. whats the next step up
  20. dumb question
  21. Spark plugs
  22. super uber n00b question :eek3:
  23. D-series tranny questions
  24. how much $$$$
  25. d16z6 head
  26. installing tach in 92 civic si
  27. Bypass Valve foam?
  28. REBUILTING T3 GARRET How to?
  29. motor swap Help
  30. Bye Bye Converter/manifold
  31. Bolt or Weld On
  32. B16A Civic VTEC 97 Model HELP!!!
  33. Two things..........
  34. Head light problem...
  35. What engine do I have?
  36. delSol camber problem
  37. Sub Box stability
  38. Turbo a d16y7
  39. Josh brought me back....
  40. Should i.....
  41. Lowering back to spec
  42. new stuff installed...:woot::yay:
  43. b18c1 GENERIC Question
  44. 100i.e. BP Ultimate Petrol(gasoline)
  45. Got my car weighed...
  46. b18a
  47. civic wiring problem
  48. Head Unit Install on 01 EX?
  49. So, just had my alignment done
  50. D16z6 Greddy Turbo Question
  51. ATTN: WestCoastStyle
  52. D15B2 engine?
  53. yokohama avid h4s....what do you think about this tire?
  54. 1992-1995 Civics Only
  55. how much gas on idle???
  56. turbo kit suggestion?
  57. Bent rim - possible to repair?
  58. have some fun with this (fomula for HPQ)
  59. intake mani torque specs? ASAP please
  60. O2 Sensor question?
  61. Am I going to have Immobilizer problems??
  62. Best year of civic?? WTB one...
  63. EK Ash Tray Option question
  64. Problem with window
  65. Aftermarket fog light wiring. (question)
  66. The future of Hondas and Civics
  67. Car handling questions
  68. Does grinding and not going into gear
  69. D-Series Potential
  70. New 1/4 Mile time
  71. What can I expect
  72. yeahh...
  73. B18 EG's
  74. Is This A Good Deal........?
  75. Low Fuel Light
  76. Q for b16 civics
  77. quick question ...for a bet.
  78. alright guys gettin ready to install some stuff.
  79. Engine & tranny mount for '92 CivicSi cost?
  80. fuc**** Honda Dealerships!!!!!
  81. My engine likes to drink a lot of coolant>???
  82. my lsd is being intalled today a few ?'s
  83. Hey...Newb Here
  84. Where can i find the Honda MTF tranny fluid?
  85. my EG is a curse
  86. H22a B18b
  87. suspension problem
  88. Added a new DIY: Ingalls camber kit
  89. They put motor oil in trans!
  90. what do you guys think about nitto tires?
  91. [D15B VTi] or [B18B]
  92. spring break project update...:yay:
  93. stereo crisis
  94. pulled head from d16z6
  95. SiR2 Thermostat ?
  96. D15B Civic VTi engine?
  97. upper control arm - need quick answer please
  98. B18 Intake Manifold Vacume Line Digram??
  99. I just hit a huge hole
  100. Intakes
  101. VAFC wiring pics
  102. EG Sedan Disc Conversion
  103. tranny choice
  104. Ok might get a d16 from a friend some advice needed...
  105. guess who mite be gettin a ferio :rick:
  106. Does this fit?
  107. Ground Control vs. Skunk2
  108. deciding on which longblock
  109. spring break project....whew
  110. Where did they go?
  111. Dyno Results
  112. Sir-G (Automatic!) Swap
  113. Q on Lowering Springs
  114. Autocrossing
  115. Help! Flickering lights
  116. AHHHHH...Just did it. I'm stoked.
  117. Drum to disc conversion...97 civic
  118. Peeps w/ Swaps <<CLICK>>
  119. Neeeed Help Quick!!!
  120. Y8 still overheating!!
  121. Civic Type R 98 ek9 performance?
  122. Do I have to reset ECU??
  123. Exhausts
  124. Strange problem: Lights don't work, don't know why?
  125. need advice
  126. moon roof noise
  127. Vacum line
  128. brake disc rotor
  129. sound when turning the wheel all the way
  130. what is this? ASAP
  131. New car help.
  132. AFC owners: install and keep stock ecu settings?
  133. kyb agx's, with what springs
  134. Hello Hydrolock
  135. how much you think...
  136. How to drain/fill radiator of '00 Civic EX coupe (auto)?
  137. b20 BS thread....
  138. What turbo?
  139. Location of tranny drain/fill plug in '00 Civic EX coupe?
  140. Fuel Filter for 97 Civic DX
  141. factory code for a civic stock radio?
  142. Hood Stuck
  143. d16z6 turbo fuel set-up
  144. Sun Roof Tilt...?
  145. flywheel
  146. could I make these work?
  147. hmmm how would these look on a black 95 coupe?
  148. Don't know if you guys already know or not, but TSB
  149. where can i get a B18C1 from does anyone have one?
  150. Alignment steering problem
  151. b18c Swap Complete *Pics*
  152. New Car ..has Issues....
  153. How to take appart interior door handle?
  154. Help, disconnecting the shift linkage from tranny!! And axle problems.
  155. what and where is the speed sensor?
  156. 97 civic ex front bumper
  157. cali
  158. natural aspirated b16a
  159. Mugen side skirts
  160. Keyless entry remote
  161. can't get axle out of drivers side spindle!!! Need help
  162. what is a good engine to install in my 93 civic
  163. Basic Maintenance on a 2000 Civic SE
  164. where do i put in subs?
  165. how do u get hp cheap?
  166. Engine Mods
  167. D16Z6 Dyno base line
  168. new car...
  169. B18 Swap into 95 Civic Ex & Auto to Manual Conversion.. Shift Linkage??
  170. Guage Cluster Needles
  171. Track Day @ Willow Springs
  172. DAM at least PM me with why you deleted my thread.
  173. will this work?
  174. engine swap with serious problems
  175. 96 civic gauge light bulbs
  176. found a deal on type r style front and rear lips.
  177. Big Boost!!!! Need Help
  178. B18 swap into 95 Civic Ex -FRONT MOUNT???-
  179. TSI Turbo Kit
  180. 2001+ Civic rear disc brake conversion?
  181. Something I Found
  182. what is this
  183. check for ABS?
  184. oh yeah...one more Q.
  185. V8 in a 94 Civic?
  186. Driver's Side Door
  187. other than azenis
  188. mirrors
  189. Rims
  190. help me decide between 15" and 16"
  191. h22 HP
  192. my honda break.
  193. sylvania silverstar.... how are they??
  194. Gas Pedal Pressure
  195. What now? adding nitrous...
  196. Need help with VAFC
  197. Fuel pump problem...
  198. URGENT HELP NEEDED! car rpm going up and down
  199. just installed...
  200. Need HELP quick SWAP QUESTION
  201. D15 vs D16 Help!!
  202. 02 Simulator
  203. Trunk Light in 95 Civic DX
  204. Is 3 inch piping too much?
  205. alternator replacement
  206. What is wrong with my suspension?
  207. ••• N E E D A L A R M H E L P Q U I C K ! •••
  208. D16Y5 Specs?
  209. cant get my SRS light to turn off
  210. Skunk2 coils?? anyone...
  211. seat swap for my 96 civic?
  212. Where To Find?
  213. my car wont start, i need answers quickly
  214. are these worth a couple hundred bucks?
  215. ran across..
  216. O2's
  217. anybody know..
  218. Lowering problem...sides not even
  219. manual to auto conversion 95 civic
  220. Update on repeated transmission failure in 2002 LX
  221. Changing steering wheel - Civic
  222. Exhausts - 97 Civic EK
  223. Cam seals
  224. Eg Civic EX instrument cluster
  225. Excellent Job
  226. attn: 93hybridcx
  227. retrofit jdm EK city lights?
  228. Where can I find Si headrests?
  229. dynamat
  230. What Solers are still here?
  231. Featured Ride Perhaps
  232. sedan to coupe will these parts work ?????
  233. ground effect/lip protector?
  234. new here
  235. What could I get for my Civic?
  236. i hate rust
  237. power windows diagram ! !
  238. Boom!
  239. civic interior paint
  240. s-techs or sportlines
  241. Strange alignment numbers after my rear disc conversion/SPC lower arm install
  242. Just wanted to announce
  243. ASAP HELP, D16z6-d16y8 SWAP
  244. quick delsol seat info needed
  245. Tapping noise
  246. new to site
  247. Amature able to do a stock 96 civic to b18c5 swap?
  248. do i need to get a camber kit?
  249. I installed a rear disc setup and Specialty products control arms
  250. Suspension package help?
go
