View Full Version : '92+ Civic/EL & Del Sol
  1. Dropzone SPRINGS thats right SPRINGS
  2. ek ferio side skirts fit on ek coupe?
  3. Red or Black seats in EBP Si ?? quick comment please
  4. balljoint tips?
  5. Gen What Civic?
  6. New Civic owner - need help, suggestions
  7. Need 96-98 civic vacuum diagram
  8. Shifter Linkage Pin...
  9. Motor ticks a lil at idle...
  10. head lights and window motors
  11. teach me and supermac new stuff v 1.0
  12. stock Dash needle
  13. Tire Size on rims
  14. clutch trouble
  15. 1/4 turn only on the zex dry bottle?
  16. engine swap
  17. Volks and Rays Center Bore
  18. Coilovers For the Del Sol ? Help ?
  19. Turbo Question?
  20. 1992 Civic CX with a H23A DOHC VTEC Swap----->Exhaust Question...
  21. Bent valve?
  22. Sound Clips
  23. more on my turbo problems
  24. 03 Si Parking Brake is Weak
  25. Exhaust
  26. What kind Of :Coilovers: for a :Del Sol: help?
  27. Dome light
  28. What Brand for Ignition Parts?
  29. rear brakes locking up
  30. Question?
  31. Tyre Size for Honda Civic 14"or15"or16"
  32. Cracked exhaust manifold
  33. GSR or H22
  34. car aligned.. pics inside
  35. widest tire on a 15 inch by 6.5 rim ASAP
  36. Mugen Chip for ecu
  37. ok...its crunch time babay
  38. Jdm D15b
  39. need a wiring diagram
  40. Need an ECU
  41. front and rear lower tie bars, same?
  42. what causes a spun rod bearing?
  43. Insurance Questions (Theft)
  44. Fuel Pressure regulator help
  45. valve cover
  46. I have a lot to do today
  47. smog problem
  48. Gram Lights 57C ??????
  49. No Cam Gear Key
  50. Honda Civic HX problems?!?!?!
  51. Pics of Clean 2002 Honda Civic Sedans
  52. Question on catalytic converter
  53. inner fender liners
  54. Weird Noise???
  55. Alternator Replacement Q's
  56. RHD conversion
  57. oil in cylinder
  58. Check engine light blinked once
  59. What are my options for seats in a 95 civic
  60. Turbo and Keep A/C
  61. 03 cd player
  62. ITR intake hose same as B16?
  63. center dash from a 99 to 96??
  64. Holy Shizzzzzzle!! please give advice..
  65. will I be safe with this offset?
  66. Anybody Ever Heard Of This...
  67. 1992 Civic Si D16Z6 - Max Boost
  68. Tenzo Venturi Muffler Section
  69. having a lowered car rocks!!!
  70. Turbo Piping Question...
  71. quick question on Tein SS coilovers on an 01 Civic coupe
  72. Need advice for my del sol
  73. Iacv
  74. turbo issues
  75. Car fax, anyone?
  76. cat converter question
  77. Where is this ???
  78. what would you choose? wheels or nitrous
  79. the epic battle, j-running dog v honda civic
  80. what is is a safe amount of nitrous to run
  81. coilovers
  82. Seat Questions
  83. Striped Oil bolt
  84. Del Sol "check Engine light"
  85. what's that damn rattle?
  86. Motor mounts are a pain!
  87. Flywheel install!! HELP!
  88. blue interiors
  89. camber help
  90. USDM EH vs JDM EG bumpers
  91. help!! installing racing seats into a 95 civic
  92. na tuning
  93. 2003 civic head unit
  94. Quick LSD question...
  95. Side effects of a turbo D16Y8
  96. Squealy belts in the morning
  97. 94 Civic Ex B18C5. A new beginning.
  98. Transmission
  99. Request: Blue Civic Sedan 5thGen
  100. Unadjustable Castor
  101. coasting in neutral... bad???????
  102. Finally
  103. d16y8 crankshaft bolt removal
  104. Anyone Heard Of?
  105. OBD and Emissions Testing
  106. just bought a 97 civic ex, What next?
  107. How to install intake kit for 2003 civic lx
  108. Suspension Tech Rear sway with lower tie bar? 98 Ex
  109. Questions about stuff
  110. tsudo?
  111. Fuel System Suppy Code
  112. apexi wsII
  113. whats the best motor to put in a 93 [B]vic[/B] si
  114. Going into park ..
  115. is it possible to put teg. rear seat in EK??
  116. 2004 Civic Ex!!!
  117. 99 EK B18c1 vs Stock S2000
  118. kyb gr2 and tein s-tech
  119. How do I remove this interior piece?
  120. Plz tell me about these bulb
  121. Anyone find fix to rattling w/short shifter?
  122. d15b boostin, dangerous?
  123. uneven suspension :confused:
  124. Buyin a built motor!!!!
  125. Anybody know how much shorter gsr shifter is than civic
  126. TYPE R & MUGEN LIPS
  127. Cat-back to get?
  128. gettin a b18b
  129. B18C1 To EK
  130. Random CEL light goes on and off
  131. Who makes this front bumper
  132. camber kits? do i have to get them?
  133. 99-00 bumper on 97 ex civic
  134. alignment question
  135. Good deal on SI wheels?
  136. 96-98 civic help
  137. VTEC Del Sol?
  138. AEM 92-95 Civic Intake
  139. What's a fair price to pay for head gasket replacement?
  140. Gas tank size
  141. Which is better?
  142. OBD System Check HELP!
  143. Expensive header but i don't see how it will work.
  144. Went over 100K yesterday
  145. do i need both?
  146. ANNOYING problem! CV AXLE OR BRAKES? Input Wanted Plz!
  147. Shocks, Struts, Coils, Coil Overs, oh my
  148. Brake Kit ?????????? Brembo
  149. which cat back is better?
  150. fuel injector ticking
  151. power window help
  152. 6th gen Si vs LX suspension
  153. JDM 02 sensor wiring
  154. New car question...
  155. Can I swap a d15b2 into d15b7?
  156. Instrument Panel Shutting Off
  157. Shake, Rattle and... well shake
  158. Accident "Help"
  159. Pictures of a....Green 96-98 Sedan with Bronze Rota SLips.....????
  160. Swap
  161. Buying new car????
  162. Check CEL
  163. another rim question
  164. stalling
  165. BP Visco5000 10w40-how many kms in a Honda Engine?
  166. the "washer trick"
  167. Camber Kits
  168. do these look ok/right?
  169. Broken Window Motor?
  170. help with maintenence light
  171. 215/50r17 tires on a civic
  172. Civic to EL conversion...
  173. For you turbo d series guys
  174. Keep Modding? or Save for more $$ car?
  175. Civic ?
  176. My plans
  177. clunking from coilovers
  178. Storing an engine
  179. Whats the best Generation civic?
  180. Type R sway install on civic
  181. I think i F*cked up Tranny
  182. wiper arms
  183. 96 civic ex-coolant problem
  184. What oil should I use?
  185. how to adjust AGX's
  186. Ask simple and basic questions part IV
  187. Door Won't Open!!
  188. Hit and run
  189. Help!! Code 08 With new cap and rotor.
  190. Hidden Kill Switch.?
  191. swaping question
  192. Leakin tierod boot...easy to change out?
  193. how do i...
  194. Skunk 2 Cam Question
  195. Adding a tach because not having one is annoying
  196. Rear Camber Question...
  197. does low engine oil cause bad start
  198. Flush Mount Spoiler:dunno:
  199. HKS Hi-Power Exhaust: Yah or Nay?
  200. Fender
  201. Dyno Costs??
  202. so my dome light and intermitant wipers stopped working....
  203. is this net parts store reliable
  204. Q on P/S with B16A swap
  205. help! codes after header install
  206. Clutch Size For Civic Jdm
  207. my 99 Si is sluggish sometimes
  208. Lowering road noise
  209. Hatch/cargo area light question
  210. 91 civic with D16yz swap quetion!?!
  211. JDM? Yay or Nay
  212. 99 civic ex
  213. Time for new rotors...
  214. to trade or not to trade....
  215. brakes
  216. What do you think of this car?
  217. what stock rims fit on del Sol VTEC?
  218. honda el?
  219. Just saying hello
  220. Glowing Gauge needles / Dash LED's
  221. 95 Civic EX sedan temp needle...
  222. 98EX with JDM EK4 SiR-II B16A WHAT FUEL LINE DO I USE?
  223. 2001 EL: leaking struts...!?
  224. 1996 Civic?????'s
  225. gauge cluster question
  226. My ebay experience.............
  227. High pitched whine from aftermarket intake/airfilter
  228. could a bad MAP sensor
  229. Need to get a cat-back..... help!
  230. Where to buy turbo kits for a decent price
  231. engine code
  232. how to adjust the fast idling screw?
  233. Online manual for changing a timing belt
  234. 99 civic si or 99 civic ex
  235. oil in distributor
  236. Z6 head's Y7 block?
  237. CEL problems
  238. BP Ultimate 100 ron use in Honda engine
  239. Time for new shocks and...
  240. Well, my suspension is done
  241. Decisions decisions...
  242. Need Help! Intake Manifold Vacume Lines??
  243. skunk2 manifold dyno results?
  244. new to HA.net
  245. What's new
  246. dumb question #2,345 from me..
  247. 96-98 vs 99-00 civic alarms
  248. Door Sill / Carpet
  249. HMO Engines
  250. do shocks effect drop?
go
