View Full Version : '92+ Civic/EL & Del Sol
  1. help, big problem!!
  2. MY Car wont Start!
  3. Coiloverkit, suggestions?
  4. HID on 93 DX
  5. 99-00 si gears
  6. This is why icicles suck!!!
  7. 98 Civic LX Idle
  8. gsr cluster into dx
  9. Wireing up XM is 7th gen civic
  10. 97 civic w/busted keyless
  11. whats a b16a's top speed?
  12. Loud Muffler Question
  13. A/C question. Help it's hot here
  14. A quick few Questions
  15. 205/40/16 please help!!!
  16. smog question
  17. sir clusters
  18. air conditioning question
  19. Greddy Timing Belt ???
  20. 5 Lug
  21. 04 Civic LX Help!
  22. Whats this all about?
  23. clutch question
  24. anyone did jrsc themselves near NYC??
  25. Help with a code
  26. HASport Mounts?
  27. sol headlights??
  28. Pads
  29. Whats is this and Does it work ???
  30. Peeling Clear Coat? What's goin' on!?!?!
  31. 02' civic from 91 integra
  32. What civic is what?
  33. Megan Exhaust Manifold....Any good?
  34. DX Cluster (gauge)
  35. Replacing Motor Mounts/Inserts (98 Ex)
  36. 2003 EL - Maintenance Sched for Canada
  37. Header/Cat Help?
  38. my car got owned today :(
  39. Decisions, decisions...
  40. question about engine
  41. Car stolen today in WA...PLEASE help!
  42. brake problem
  43. rotor compatibility???
  44. TENZO-R Coilovers ???
  45. OBDII-OBDI check engine light
  46. parts falling off my car= good
  47. HELP!! options for removal of rusted/striped bolt
  48. shock/spring combo question
  49. Anybody use that A/C repair stuff at pep boys?
  50. Camber Kit
  51. Keyless entry doesn't work.......
  52. best place for oem si center caps (99-00)
  53. to turbo or not to turbo
  54. '99 Civic EX Tranny
  55. Best Header for a B16a
  56. Can a D16Z6 5-sp tranny bolt up to a D15B w/stock auto tranny?
  57. weird idle
  58. schematics for window controls
  59. Which Hatchback
  60. help installing a tach
  61. Prob With Oil Light!!
  62. what do u guys think about this lowering?
  63. Dont know if this has been posted before
  64. jdmshit lips and grill questions...
  65. Auto Tranny indicator light problem
  66. 94 civic EX camber kit...do I need it?
  67. quick CEL question
  68. ??
  69. What should i do to my car???
  70. change of heart.....
  71. my single cam quest
  72. Time for a new thread!!!
  73. Will this fit my car?
  74. leak in passenger when ac on
  75. coilover problem
  76. Tach not working with my hybrid setup
  77. Car shakes after installing alarm system???
  78. Keyless entry and alarm
  79. 2002 EL door speakers
  80. Replace Windshield ????
  81. H22a + Fi
  82. Fill bottle in MN
  83. tire suggestions
  84. Programming new keyless entry remote
  85. 4-1 Headers VS 4-2-1 Headers
  86. Need a Motor!!
  87. tire size on stock 15s
  88. power window in my 96 EK?
  89. Wire Diagram / AllData access??
  90. try this on your car
  91. question abot ex intake manifold
  92. Engine whine noise
  93. Need wiring information quick! Please!!
  94. best rims?
  95. Iacv part number, need a new one
  96. oil filter (wow that sucks)
  97. near empty gas = longer crank time
  98. I'm going to install my short shifter tom, any tips?
  99. shock questions
  100. Guys with 96-2000 civics, with GSR front leathers check in here
  101. question
  102. TPS pinout on ecu, please help
  103. what is supposed to go here?
  104. turbo from rx7 ?
  105. Is 40 too old for a civic?
  106. 96-97 LX/DX/HX exhaust manifolds! (read me if yours is cracked)
  107. tranny fluid change
  108. Say your 2cents about engine companies
  109. clear distributor cap
  110. clicking clutch pedal
  111. how do you remove...
  112. Nagano in Montreal...
  113. Finally starting to come together!
  114. Will "universal 10 lugs" fit my car?
  115. civic rims
  116. Why isn't this ecu working?
  117. Removing A/C - what else?
  118. Power DL and Windows
  119. power steering question
  120. should i buy this?
  121. 18 month old oil with 1700kms - OK?
  122. Pic request...
  123. trunk help
  124. Gas Mileage
  125. lower ball joint removal question...no need to remove knuckle?
  126. What I Picked Up Tonight?
  127. noob question about civics
  128. 95 hatch with LS swap for sale on ebay.....
  129. b18b or b16a2?
  130. picked up a wreck
  131. rust resistant hood pins..
  132. Switches in Civic EK
  133. anyone remember me? got a new whip
  134. b20z question
  135. 98 Civic Coupe Si (US EX model) A/C? 5spd
  136. quick muffler question
  137. What type of drop?
  138. is this B18 sleeved?
  139. independent honda mechanic
  140. exhuast manifold heat shield remove?
  141. ever heard of this?
  142. 94 civic hatch rear speakers and road noise
  143. Are there any good links for timing belt replacement?
  144. apexi n1
  145. TPS experiment
  146. ok...new scenario...
  147. jdm eg9 headlight question
  148. Body work
  149. Type-R shiftknob
  150. What is this and where does it go?
  151. How to do a compression test?
  152. obdIIa or obdIIb?
  153. Timing Belt
  154. Some autocross videos for your Civic guys :)
  155. once again I bent my rims
  156. Buying a '95 civic hatchback ex questions>>
  157. RPMs jump at idle and car boggs down when accelerating
  158. 99 Hatch CX Auto. Is this a problem?
  159. VTEC issue? THANKS!
  160. Cheap horsepower, please help
  161. exhaust
  162. D16z6 mods help
  163. Kumho 712's or 711's
  164. Starting Problem: Fuel pump or relay?
  165. Power loss
  166. 96 ex auto 2 5speed iac valve?
  167. Megan Racing
  168. Is it at all possible?
  169. oil filter
  170. 01 Civic SI (US EX) service bulletin
  171. My feriod got raped !!!
  172. What color is this civic?
  173. how much can i spray?
  174. changing rotors - check
  175. Sand blasting or something...
  176. Questions-95 Honda Civic LX - Backrest Adjustment
  177. idle problems. please help
  178. ordering a SiR-G motor
  179. Civic Oil Pan Thread
  180. Catback piping...
  181. smoke
  182. o2 sensor ?
  183. Vtec
  184. Differences between 2dr and hb rear seats
  185. Disc Conversion in EK civic
  186. Head 'n stuff is back from machinist (pics)
  187. vtec
  188. Swaybar bushings
  189. Rpm jumping up and down
  190. SIR or GSR
  191. Undercoating for the interior?
  192. Rust on my ek =(
  193. Really Stupid Question
  194. Crappy radio reception and loose center mirror
  195. Turbo a d16y8 engine?
  196. A Dumb question
  197. some opinions?
  198. 99 Civic Type R Headlights
  199. is it possible......
  200. cone filter + stock air box
  201. Good Exhaust
  202. hatchback suspension woes
  203. Anyone have this problem?
  204. cheap struts
  205. My new website and server
  206. New Clutch Is Slipping
  207. d15b JDM Vti Boost?
  208. Bedding new brakes...
  209. CEL Misfire
  210. floor harnesses interchangable from 96-00??
  211. quick question
  212. Help buying something
  213. CEL.... again
  214. thrown rod bearing
  215. Turbo?
  216. more questions about 95 civic outer door molding.
  217. Need some advice
  218. oil pressure gauge install
  219. Del Sol won't rev past 2500? WTF?
  220. fuel pump and alternator lifespan...
  221. Advice for 04 si owner
  222. 98 Civic vibrations
  223. need help from diagnostic experts (92 dx sedan)
  224. Swapping a Ls into a 90 si
  225. Getting a 00 Si
  226. 95 2dr. civic ex question
  227. 98 prelude doch vtec _vs_ 97 integra gsr
  228. annoying stutter....
  229. carfax report please?
  230. New Spin-Flow Oil Filter
  231. Rods?
  232. Wierd High Pitched sound
  233. Muffler problem
  234. how much would you pay for greddy sp
  235. project GSR radiator :yay:
  236. Struts
  237. Turbo D15b7 has anyone done it?
  238. VTEC on D16
  239. Would this VIN work on carfax? Car is in Canada.
  240. PCV Valve
  241. Just curious..
  242. Vtec D15b
  243. after market tach help
  244. Clutch = timing problems
  245. Rear Lower Tie Bar
  246. Brake issue
  247. 95 civic drum brake adjustment
  248. invidia?
  249. Overdrive Pulley Kit For 92 SI
  250. so sad:(
go
