View Full Version : '92+ Civic/EL & Del Sol
  1. Idle Control Valve
  2. Help.. ICM?
  3. Axle Back size?
  4. Where should i start???
  5. Little hybrid question for my 94 hatch
  6. primary and secondary o2 sensors
  7. shift linkage question
  8. Coilovers
  9. Cant remember
  10. Lowering springs question
  11. civic owners....97-00 read this
  12. Best price on Optima yellow top???
  13. car just got stolen, philly ,pa
  14. 1998 civic hatch a few questions
  15. ^ Del Sol Rims, what ones would you get? ^
  16. Clutch Pedal question
  17. don't let me screw this up
  18. Will it fit?
  19. 99 Civic CX making knocking sounds
  20. Clearcoat
  21. Got motor swap estimates
  22. Whats faster
  23. will a 205/55/14 nitto 555r fit ok on a stock civic steelie?
  24. injector help
  25. help: airbag block-off tray for EG?
  26. GSR Rear sway bar on Civic
  27. locked lug nut????
  28. Stock Rev limiter RPM on d16z6?
  29. What should my budget be for basic mods(suspension, lights, rims)..Reliablity?
  30. Fast Help Please Cant Keep Coolant
  31. does zex make a good cam for the d16y8?
  32. Still Random Check Engine Light
  33. lighting problem
  34. 5G hatch front conversion?
  35. Car start.. but when rev.. it dies
  36. Matchup game.. abreviations?
  37. headlight
  38. hood pins? hood locks? need help finding them
  39. Need help, my engine stalls
  40. Need to buy Shocks/Struts/Coilovers
  41. A/c
  42. Need Help with HMO.com
  43. any ideas?
  44. Momo Jet
  45. How to Change Headlight Bulb
  46. *HELP* JDM Starters for b16a
  47. ACT or Exedy clutch? Act pro or streetlite fly?
  48. Stainless exhaust system
  49. Still having Problems with Wiring HELP
  50. Heat Sheild on Muffler
  51. P07 ECU Chipping/Modding
  52. Civic...Del Sol Lip...???
  53. 04 civic apps
  54. shifting feels notchy
  55. which boost kit?
  56. should i do it?
  57. RSX engine into a 92-95 civic
  58. could you please price these turbo stuff?
  59. Removed AC & got CEL...
  60. jdm b16 4-2-1 or 4-1 header
  61. Could i get away with a 205/50 R16 tire on my 16's
  62. Bosh Oil Filter
  63. you gota listen to this
  64. Anybody done an F series swap?
  65. Here's Something I Think Is Cool.
  66. HELP wiring problems
  67. What do I need to prep for a turblow??
  68. 550cc injectors on a T25?!?!?!?
  69. Spraying?
  70. What is this?
  71. Aftermarket Mufflers
  72. Manual Transmission Problem
  73. LS Engine with a DX ECU
  74. Rear Upper Strut Bar
  75. question about CEL
  76. Tranny Problem???
  77. Carbon Fiber Gas Tank
  78. 4spd '02 Si?
  79. Any Suggestions
  80. Question regarding 5thGen
  81. d16z6 question
  82. Best Coilover setup
  83. Adding A/C to a 96 CX Hatch
  84. tranny problems NEED HELP
  85. goin to check out a 93si tomorrow..:rick:
  86. D16z6/d15b
  87. tokico illumina suspension
  88. what engine for an EG hatch...
  89. Really low TPS voltage
  90. Help to install a cold air intake
  91. Rear Door Handle Install
  92. Might have found another car :oh:
  93. Beater Died :(
  94. aftermarket shock install question
  95. idle?
  96. which is this?
  97. Aftermarket mufflers?
  98. noise from my del sol :\
  99. tenzo R racing seats
  100. Help Anoyone?? Fuel problem
  101. How much is it to replace a clutch?
  102. Will an LS Catback Exhaust fit on a 1998 Honda Civic HB
  103. Rear Lip and Exhaust
  104. Suspension Goodies
  105. AC Quit on 92 Civic
  106. Where can i get a lug nut wrench?
  107. were ABS optional on 99-00 ex coupes?
  108. 93 Civic Gas Gage Reading?
  109. Civic Engine Turbo with DSM parts?D16v1 european engine?
  110. I read and kind of got it, but not really lol
  111. Thinking of changing my mind on turbo.
  112. ECU Check engine light
  113. What is this??
  114. horn broken?
  115. help with engine
  116. would EK rear control arms bolt onto EG??
  117. Need help with rev limiter
  118. Fix your main relay
  119. 94 Civic won't start
  120. how to reset maintenance required light?
  121. AC Compressor
  122. my 2003 civic
  123. Need A CARFAX...Please Help...
  124. IACV question
  125. QQ. Spark plug socket measurement?
  126. 2002 bumper removal?
  127. Power-Steering, possible?
  128. :( prollem
  129. Type R (B18C5) Swap on EG ?????
  130. need help here with a brake prob guys....please help me.
  131. my door is busted?
  132. Acura 1.6EL???
  133. Sneek peek ver. 2.0 ( FMIC - Custom bumper fit )
  134. turbo fuel management Q
  135. itr conversion started
  136. looking for 2004 civic parts
  137. P28 ECU Question Need Really Fast answer Please Quick
  138. Sneek peek ver. 1.0 ( car mods )
  139. Need help with 2 things
  140. Tires
  141. Timing Belt Replacement help
  142. licenseplate light
  143. Tune up
  144. Well, i dun it. Made purchase last night
  145. Best dealership in houston area
  146. Engine Serial
  147. Stage 3 Mods: New Parts (With Pics!)
  148. 94 civic hood wont open
  149. What brakes do you run?
  150. wrecked my dx need some advise
  151. jdm sir fogs part 1
  152. Eibach Pro Kit Backwards?
  153. Found a del sol!
  154. how much will it do
  155. Cam Gears...do they help that much??
  156. FREE 6qt of Valvoline SynPower
  157. Help W/Buying a 93 Si
  158. It's been a year...
  159. Problems with clutch
  160. lookin for j's racing style intake for 96-00 ex
  161. What adhesive...
  162. Air bag suspension.......
  163. cluster and heater control lights are out...
  164. 96 Civic Questions
  165. nice
  166. Car is broke. Won't Move. Help please.
  167. New toys, soon to be installed.
  168. Low voltage to TPS, HELP!
  169. Street Legal
  170. Lowering spring problems!!!
  171. Im about to respray my stock bumper and i have a qustion...
  172. I got bored after I did my buddies clutch soo....(pics)
  173. does this header look like crap... or does it look alright..
  174. My first problem with my civic.
  175. 1995 Honda Civic LX Statement-Questions
  176. Hesitation when warm
  177. swap & turbo
  178. SRS light on?
  179. My Car starts but It doesnt run good
  180. Civic starts, but won't run
  181. Speedometer dead, need help to troubleshoots
  182. Engines That fit in a 93 Del Sol si.
  183. Dropzone Coilovers with the Dropzone shocks ?
  184. rad support
  185. does acura integra seats fit on 98 civic ex coupe?
  186. Clutch/Flywheel DIY is up
  187. Motor Mount problem
  188. got diagnosed at autozone
  189. How Much????
  190. Turbo Kit or Engine Swap?
  191. Struts, Please recommend....
  192. hey you know what they say...
  193. My car troubles - Honda Civic
  194. *Noob ?'s* Exhaust, springs & almost broken elec. window...
  195. Caliper reset on 2000 Civic si
  196. MiX N' Match Coilovers ?
  197. KYB GR-2 SHOCKS for Del Sol
  198. HID + projectors?
  199. VERY old pictures of my car
  200. Kosei TS lightweight wheel - SWEET!
  201. Best place to find front clip????
  202. Check Engine Light CEL error 41 help
  203. engine
  204. transmission housing removal
  205. power steering rack to non power
  206. Rear Leather Seats
  207. 2006 Honda Civic, No pics just an article.....
  208. My DIY on JDM knockoff mirrors
  209. JDM/OEM insanity
  210. lower springs and shocks...
  211. I got a dent in my gas tank
  212. engine codes
  213. I can't get the pin out
  214. Clutch installation
  215. 95 Civic EX Master Cylinder
  216. clutch and transmission
  217. ac help
  218. Last Spring's Road Trip!
  219. just purchase a '95 del sol
  220. Stage 2 of Mods: New Parts (56k Beware)
  221. My civic video!!!!
  222. 5g civic seats into 6th gen?
  223. 98 Civic Coupe.. jerkin a bit
  224. Doing my own oil change + antifreeze change..tips
  225. jdm headlights and corners eg
  226. ahh... much better.
  227. Okay so call me a ricer.
  228. Will EX auto tranny work on DX auto
  229. Battery replacement - which one is best?
  230. anyone have problems installing this steering wheel?
  231. Terminology? what do you call that part!!
  232. JDM Civic EK9 power folding mirrors
  233. how low before camber kit?
  234. Transmission Q, 03 civic
  235. Tire ballancing problem
  236. b18 or b16
  237. wiring diagram needed
  238. B pipe options
  239. SRR Goodies!
  240. D-I-Y smoke a headlight
  241. Wiring to ECU-need to know how to connect it
  242. Honda performance package wheels?
  243. New Hatchback Purchased
  244. car wont start
  245. Again:wire ignition referençe for d-series
  246. Quick spring question...
  247. bumper interchangability
  248. wiring?
  249. Octane boosters
  250. Scrapage
go
