View Full Version : '92+ Civic/EL & Del Sol
  1. BRAKe Question....
  2. front rotor removal.
  3. turn signal blinkin fast
  4. will springs from an 88 civic fit my 99 civic HB??
  5. need turbo info
  6. tein suspension?
  7. how low should i go?
  8. obd help!!1
  9. oooh, i'm so 'essited
  10. ES Master Bushing Set Question
  11. Q on clutch
  12. new tranny!
  13. Hells ya! :woowoo:
  14. Some Please Help With An Ek Hatch Pic
  15. Chevron Supreme vs Valvoline All Climate
  16. guage bezel swap on CX??
  17. air conditioning unit
  18. Difference in Cat-Convertor
  19. Best Swap?
  20. Back from the shop
  21. i need help!! rsx rear seats in ek coupe?
  22. quick question
  23. Front LCA bushing install help
  24. What is this for?
  25. solenoid location
  26. when do 2006's come out?
  27. type r wheels
  28. Spoon ECU Chip
  29. 2004 Honda Civic...Needs Help Souping Up...
  30. What to do....Mugen vs. VIS
  31. 450cc Fuel Injectors
  32. is this price as good as possible on 2004 EX?
  33. Hey I need a car fax!
  34. Took off indiglow gauges from 99 Civic DX and I have an extra cable?
  35. Uberdata - Write Up
  36. D-Series Camshaft and Valve Spring Install Write-Up
  37. HOWTO: Timing Belt/Water Pump Change on a D16Z6
  38. Which B-Series?
  39. Which type of B-series engine in the 98 Civic LX
  40. Engine swap for a 98 Civic LX
  41. headlight clips?
  42. Pulling a ecu pin?
  43. suspension + bowl cruising
  44. 1.7EL missing at 3500rpms
  45. Mwahaha... rebuild on Greddy 15g
  46. question about a rear disk swap
  47. Need help to get a exact answer *i've already searched*
  48. Civic Radios
  49. Looking at a Civic.
  50. To Do List on Your Car...
  51. Front rotors on CX
  52. It's time to get lower...
  53. Brake booster question
  54. Looking for CTR Wing
  55. Rear drum maintenance
  56. What could be wrong?
  57. Quick Exhaust Question
  58. 75 shot safe on a d16y8
  59. Online ship for Del Sol seats?
  60. What should I do? N/A vs. Turbo
  61. SRS & ABS Light on ??
  62. SRS system??
  63. dx's cluster read rpms?
  64. Fried connector
  65. Tried to do a tune-up today
  66. I just installed my SilverStar headlights
  67. 92=95 Civic Cluster
  68. Exhaust/muffler pops and black fumes
  69. swap tranny help
  70. I'm back! Brief update.
  71. oem exhaust
  72. tar gone, ready for carpet
  73. autometer oil pressure gauge (electric)
  74. Front End Rattle.
  75. Can I Do It Myself??
  76. 04 seats in a 2000?
  77. 03 GTI VS 94 DEL SOL si
  78. Paint in So Cal (619)
  79. carfax please!
  80. CEL after swap
  81. looking for motorz
  82. Crappy Gas Mileage
  83. Anybody running XM Radio in their Civic?
  84. muffler
  85. Tachometer Installation
  86. ----opinion---
  87. One touch down
  88. Lock Cylinder removal
  89. Steering Rack Help
  90. Ac low pressure outlet
  91. help: anti Sway Bar EK9 on EK4?
  92. hood won't open
  93. new civic coupe ex HP
  94. Car is shaking when I brake
  95. gasoline smell
  96. What can cause pungent exhaust?
  97. Hatch Story Vol.1 w/pics
  98. 95 Coupe Light Problems
  99. PCV valve on 98 civiv HX
  100. question. regarding ceramic
  101. electrical problem.....
  102. reposts,ebay,mulit posts
  103. Valve Cover
  104. Should I buy this Del Sol?
  105. Its done... (56K find something to do)
  106. already searched...if car is on E, does it take longer to start?
  107. new engine
  108. Backpressure questions
  109. Sleeper... ?
  110. What's your favorite mod (currently)
  111. Brake Bleeding/Clutch Bleeding
  112. Best for 00 Civic Ex ... ?
  113. anyone riding on tein s-tech springs?
  114. JDM B18C Swap
  115. trouble reading codes HELP!!!!
  116. I need brighter headlights
  117. Where to dyno in chicago area?
  118. 98 Civic coupe power window problem
  119. JDM fog light button
  120. My Swap Quote
  121. coilover question
  122. Exhaust question....
  123. Location of radiator drain plug?
  124. 98 Civic LX - noise around 3k and above
  125. HELP! 1993 Civic LX Won't start/Weird noise
  126. Need help with an intake
  127. single or dual
  128. Door latch issues
  129. After alot of blood, sweat and tears - my 5 point harness is in.
  130. car is no longer alive
  131. Anybody ever add remote door locking/unlocking?
  132. black face reverse glow gauge for the Civic !!
  133. Help with motor mount
  134. basic question about 6gen civic front seats
  135. Whaddya guys think?
  136. LS/VTEC Dynos?
  137. Fuel Sender Switch
  138. how do i change rev limiter?
  139. Greddy Turbo Manifold / Turbo Q's
  140. alignment time
  141. Getting Ready to Start LS/VTEC
  142. gear grinds when shifting
  143. Good price on brake+drum replacement?
  144. Linkage and axles???
  145. distributor
  146. sup brothas and sistas
  147. Hatch Problem
  148. info
  149. Camber Kit install
  150. another shift linkage question
  151. projector adjustments?? civic
  152. skunk 2 or ground control coilovers
  153. Need help removing engine coolant drain plug
  154. Strut Bars
  155. Running Rich
  156. Got my car running BUT.......
  157. Good Bye RWD, Hello B18 Civic *56K*
  158. What about RC Injectors?
  159. BOV noise
  160. alignment after wheel upgrade?
  161. 99-00 Front Bumper
  162. Biggest Wheels and Tires Without Rubbing?
  163. bad vibrations
  164. Eg A/c
  165. Yaaaaaaaaaaaaaaaaaaaaaaaaaaaaay!!!
  166. trailing arm bushing question
  167. Your opinion on a soon to be bought civic, what would you do?
  168. Some swap problems...
  169. exhaust fitment
  170. buy a bearing and seal for distributor (del Sol 93)
  171. thought about it and change my mind again...
  172. 1998 Civic DX wont start now
  173. Couple Quick Questions
  174. Please help figure out what its worth
  175. code reading
  176. Car Won't Start
  177. what's cheapest place for Beaks or BSQ SRK?
  178. Headlight adjustments?
  179. HELP!!! Can't Put it in gear!!
  180. will this work plz read
  181. gasoline capacity*
  182. Will it fit?
  183. K series in a Civic?????
  184. Need Some Help Finding Parts.
  185. Car Problems
  186. Shock absorbers,replaçe for which?
  187. Rear disc conversion
  188. Need help on a 01 civic
  189. Fuel Pump
  190. what size ???????
  191. Fuel Pump
  192. Woot!
  193. 92 LX Maintanence
  194. Cracked Exhaust Manifold?
  195. yet another suspension question
  196. Cross model suspension upgrade?
  197. rear lca's on 97 dx
  198. oil line for turbo
  199. fuel line Q
  200. check engine light on. help.
  201. can anyone show me how too.....
  202. 2nd gear grind/crunch! d16y8 trans. HELP!
  203. suspension packages
  204. wax as you dry any good?......
  205. how to tell what kind of transmission
  206. more help
  207. Upper control, shock, spring Q's
  208. Help!! 2003 Acura EL 17" Rims/Tires
  209. Found 91 Lude-swap?
  210. Civic Headlight tilt?
  211. help removing bottom cushion of rear seats in 97 civic
  212. Definitive Rear Speaker DIY
  213. window problems
  214. teg engine - civic tranny
  215. Engine Trouble on '92 DX
  216. A/C hot then cold then...
  217. Renew engine oil and filter,how long?
  218. Help With 99 Civic Rear Speakers!!!!
  219. JRSC on LS Hatch?
  220. Pics
  221. Black Smoke?? :-(
  222. Tranny Question
  223. Y8 vs. Z6?
  224. Shift lock related to brake lights not working?
  225. Shocks and Springs Install- Feedback appreciated!!!
  226. Sequential turbo help!?!?!?!??
  227. tires
  228. McGard Splinedrive
  229. Swirly steering
  230. Suspension
  231. need help, car stalled on highway.
  232. Fogs for 96-98 Civic
  233. 96-00 Center Console / Armrest in 92-95
  234. 99-00 rear bumpers fit on 96-98 civics?
  235. '00 Stereo Question
  236. CF Lips..
  237. rear tower brace
  238. should i keep em?
  239. Ok, I ordered my B16A2 but....
  240. Fog Lights
  241. OBD1 to OBD2?
  242. Trying so hard!
  243. A small update :rick:
  244. selling a car
  245. d15b tranny ...
  246. wheel shaking ater brake job
  247. high amp alternator for a b16a
  248. Edelbrock Turbo Help - Urgent!
  249. CEL Code 41 - New Info - Reward for fix
  250. Struts...places to find struts...
go
