View Full Version : '92+ Civic/EL & Del Sol
  1. Clutch or tranny??
  2. Front brake conversion
  3. Woot me.
  4. Pre Swap Research
  5. what color is my ugly car?
  6. motor swaping
  7. Time For A New Car
  8. 98 Civic LX
  9. About to buy brake conversion parts...
  10. Civic Help
  11. 96-98 OEM CD player
  12. Questions about B18 with turbo swap?
  13. condenser fan removal
  14. a few exhaustand suspension q's about my stock 95 cx hatch
  15. can't find through search....
  16. Need Help With Accident
  17. quick suspension question
  18. Good write up for power steering delete?
  19. complete swap or new car?
  20. Stock Tail lights
  21. Compression #'s for a B16?
  22. more pics of my EK
  23. Flame Suit ON. I need your opinions on this mod
  24. w00t..my buddy got his Sir-G motor today..which means...
  25. where did the power go!?!?
  26. Suspension suggestions for my 94 Ex coupe
  27. Problem with my Del sol..
  28. Beaks Kit EG QuickSwap ITR sway bar clearance issues
  29. wats wrong with my exhaust
  30. what do ya think
  31. 92 Si, worth it??
  32. Mirrors
  33. First Post...
  34. i did it woot!!! rsx seats in my ek
  35. D series boys help! (jafro, bakeoff, white n slow)
  36. distributor going bad?
  37. BOOST teaser shots...(Precision, Revhard, Greddy) :rick:
  38. engine popping?
  39. Clutch fade?
  40. Headlight Question on 5th gen
  41. Gimme a brake... some advice, that is.
  42. any good write-ups on clutch replacement?
  43. Fog Lights
  44. Auto Guage Cluster in a Manual?
  45. cleared headlights????
  46. buy a 92 cx or a 92 si????????
  47. spw guages any good?
  48. strut assembly Q
  49. rear disc brake swap and possible engine swap from 91' integ
  50. Shifter question
  51. w00t for successful turbo install!!
  52. help!?!?!???!!?
  53. Fuel injector plug retainer clips
  54. Seat installation
  55. PLEASE HELP- cant figure out the problem (O2 sensor wiring) (att anyone with a vx)
  56. Pics of yo civic V.798668gojfg784bwf7!
  57. So... hit the dyno yesterday :rick: - video added
  58. 94 civic- DS window problem
  59. bolt pattern on '04 Si
  60. new pads... and now this??? :wtf:
  61. just a quick question.
  62. which civics have knock sensorS?
  63. Help! Power Steering
  64. Short Throw Shifter For 03 Civic?
  65. idle problem, timing problem, or vacuum leak?
  66. code 67
  67. Integra suspension on Del Sol??
  68. Pics!
  69. Door panel thread
  70. Whatever happened to JDMfan??
  71. prob. with 93 dx
  72. Front-mount intakes
  73. install a horn
  74. guage cluster swap
  75. redline for all the civics?
  76. A/C condensor replacement
  77. have to sell my car because I cant pass smog
  78. Changing Auto Tranny Gears
  79. Swap Question...
  80. Some cool incar Civic videos.
  81. Broken shock?
  82. need serious help
  83. Need help asap - Electrical gremlins?
  84. OEM Honda ATF fluid $6.07
  85. helms 92-95 civic
  86. Exhaust Install
  87. Picture thread. Post your pics! <but read guidelines>
  88. My car finally complete...
  89. d-15b ECU in an EG b-16?
  90. HELP- OBD2 B18c1 in OBD1 car w/ OBD1 ecu
  91. It Finally happened.....accident!
  92. Xm
  93. Endlink-exhaust question
  94. Sup Peeps... =]
  95. Cleaning halogen lights?
  96. my car is in the garage
  97. 97 Honda SOHC Non VTEC
  98. Mount accel coil on 5thgen?
  99. Best low priced non-autometer guages?
  100. code help
  101. What Are The Color Codes For The JDM SiR EG6 Hatch
  102. I Need Jdm Parts For My Car!!!
  103. 95 Civic with type R motor question
  104. Max EGT anyone?
  105. doesnt wanna start when cool
  106. finally got motorswap!!
  107. Civic broke down!
  108. headlight bulb removal
  109. idel problems
  110. neone know: mounting sedan oem 3-point wing on coupe?
  111. Will 2000 hatchback rear seats fit 2000 coupe rear seats?
  112. Looking for "Door maplight" for delsol
  113. motor problem
  114. so sad :(
  115. new springs... spring rate
  116. reverse lights
  117. fire wall flex
  118. Building up a D16Y5? Worth it?
  119. Engine support stiffener
  120. How to replace dead D4 shift indicator bulb
  121. Jdm D15b Ecu?
  122. Make a list of what i need....
  123. ABS really standard??
  124. REar discs from a 90-93 integra on eg??
  125. ECU help
  126. Cooling problem?
  127. vtec controller
  128. instructions
  129. engine stals with ac
  130. 1991 EF b16a/cable swap
  131. Aftermarket Clutches??
  132. '96 Civic CX throttle body question
  133. Q for anyone running an integra ECU
  134. Cams, cams, cams!! Which is which..
  135. A/C system parts
  136. Grille question
  137. What ECU...
  138. help
  139. D16Z6 from civic any diff than from del sol?
  140. Official Civic/Del Sol picture thrend
  141. [RANT] removing climate control
  142. Short shifter
  143. Why is there no Del Sol / Civic Picture Thread ?
  144. Idle...wierd
  145. VTEC question
  146. Car keeps dieing
  147. Critique my custom LS turbo setup thus far!
  148. What shocks w/sportline springs??!! urgent
  149. where to buy oem muffler for 00 si
  150. New Coilovers, but how much drop?
  151. replaced primary 02 sensor, light still on
  152. B18C1 Civics... times?
  153. Where to get Brake line tubing at?
  154. ***help! Car wont start***
  155. Rear Brakes Locking Up
  156. what works when engine swaping
  157. New Guy w/ 04 Civic Coupe
  158. seriously thinkin bout an Si....
  159. Paint
  160. Does this intake system fit on D16z6??
  161. Looking for the previous owner of the car I just bought
  162. curios... how much fuel to drag
  163. 1994 Del Sol Coupe Vtec Good deal???????
  164. swap for my 95 cx hb?
  165. Leather Seats......
  166. screeching noise coming from...
  167. Electron Blue Pearl in spray can form???
  168. Looking For 02 Civic Si
  169. civic tons of mod's what now?
  170. Well tues or wed is the day I'll find out if I get the civic.
  171. D16 vs D15 intake mani?
  172. What to run in my EG/EH?
  173. Street Imports 2" Race Radiator for 92-95 Civics Review
  174. Help, I just became a Honda Salesman
  175. del sol w/issues
  176. Integra LS fuel filter fit 92 CX?
  177. Why is my car this slow?
  178. Clutch Question?
  179. Clutch noob question
  180. Boston Area "Honda" Junkyards?
  181. Del Sol AC Belt!?!?!?
  182. Cam Gears Tuned
  183. 00 si turbo help
  184. strange problem?
  185. Car power turns off and on!?
  186. Del Sol Seat Question
  187. So my buddy totaled my Honda Civic
  188. Spoon Type-One Header
  189. stupid ass window
  190. What prices to expet? How to get off?
  191. O2 sensor help with 98 B18c1, P72 ecu
  192. Need Code Help ASAP
  193. i need head
  194. WoW....First for me...
  195. Whats a fair trade to ask for?
  196. number 1
  197. civic hatch: rear seat delete kit???
  198. Teg LCAs?
  199. short vid of my car . nothing special
  200. Can Del Sol seats swap rails with 92-95 civic?
  201. newbee questions bout a 1999 civic ex
  202. where to get and how much for a rear bumper for a 97 civic coupe.
  203. good body kit for a 97 civic coupe?
  204. I got my springs..
  205. Timing!
  206. d16y8 timing belt tensioner question
  207. Just did a Compression Test
  208. Any experience with D series Cams?
  209. GSR Crank confusion???
  210. Want to race out a '90 Civic Wagon AWD
  211. Low coolant
  212. i gotta 95 hatchback cx what can i do?
  213. 96 civic springs?
  214. Redline on 99 civic hatchback DX...
  215. clutch question
  216. Lets take the dumb-ass Vinyl Graphics off my ride!
  217. Exhaust Question / Apexi N1
  218. Do all 96-00 civic auto tranny jerk at times?
  219. Ran my Civic last night, pretty disapointed.
  220. Question on 96-98 civic Headlights with pic?
  221. Need help with finding a header for D16Y7
  222. 'been gone for a while...
  223. D16Z6 with Garret turbo
  224. D16z6 Axles?
  225. Building a D15?
  226. My k20a R into EG pics
  227. anyone know where to get the molding for jdm back bumpers?
  228. alright, ALRIGHT! pics
  229. replacements??
  230. gauges ?
  231. 96-98 jdm headlights
  232. To Turbo? or To not to Turbo?
  233. B-16b piston in a B-16a block??
  234. Intake Manifold Question Help!!!
  235. $$$$$ ?????????
  236. ignition question
  237. Acg (s)
  238. aftermarket headlights - plastic or glass?
  239. RPM problem
  240. New 98Civic EX owner and she is running hot...
  241. ES Master Bushing Set
  242. Well, it's ALMOST done
  243. 92-95 Red and Clears Questions
  244. I hate my passenger door window
  245. 94 D16Z6 Chip?
  246. Which AEM intake fits a '97 HX
  247. revs too high
  248. greddy kit
  249. need help ASAP!
  250. Fuel running to rich CEL
go
