View Full Version : '92+ Civic/EL & Del Sol
  1. Yeah it's in. I think now I will buy stocks in Comptech :)
  2. Where to find a stall...
  3. Wheels Walking
  4. distributor wiring!?
  5. Vac Guage
  6. ok so i went to the junkyard and took a cat converter out of a civic...
  7. Sugestions?
  8. ?'s about 95 hatch
  9. Crank Sensor
  10. Need help and Input
  11. is the downpipe on the 5th gen hatch the same size as the 2dr coupe
  12. rear disc brake assembly from 91 gs teg into my 5th gen hatch?
  13. clutch sounds like its going to blow up :thinking:
  14. Question about Guage clusters
  15. Stainless steel cat-back piping pre bent?
  16. 93si HB.
  17. d16z6 head swap
  18. Tranny Blew up
  19. Looking for hood
  20. help w/ del Sol brake upgrade
  21. Clanging/ticking noise?
  22. Need a solution to stop snaping belts at 9k rpm
  23. 5th gen hatch rear brake swap and exhaust q's
  24. Need some help.
  25. header caused rod snappage says mechanic
  26. engine starts then dies
  27. Fuel Pressure Regulator
  28. TPS sensor
  29. Still having problem with idling.
  30. Just got LS Front and Rear
  31. A/C turns off and on
  32. I need help with my Civic Hybrid
  33. Will Type R sway bars fit
  34. Exhaust temp light on.......anyone?
  35. 00 Center Console
  36. Torque Wrench
  37. WTF is a Max Power?!
  38. What's the normal idle range?
  39. plastic models?
  40. b18b loping in idle
  41. what cat-back?
  42. Favor to ask of Del Sol owners
  43. OK cuz of people not watching where they are going...
  44. Front end conversion 92-95 hatch?
  45. Car revving in neutral
  46. 97 Hatch Conversion?
  47. Collision repair
  48. will a 95 teg sedan interior fit in a 92 eg sedan ???
  49. My car prob
  50. hey some help. please
  51. NGK sparkplugs for d-series engines.
  52. A/C Drainage Hose for CIVIC LX '99
  53. resinator keep or trash??
  54. question about pulley belts
  55. Type-R sway bar problem
  56. need help with a new project
  57. Oil in coolent
  58. AEM V2 Intake?
  59. Yeah Comptech Ice Box in and almost lost my mind.
  60. What's the best place to buy oem parts?
  61. need specs
  62. Change bushings and bearings in brake swap?
  63. Decision help - giving up the car?
  64. whats cracken everyone
  65. Aeroturbine
  66. new gauge cluster?
  67. AC Problem
  68. Fuel Pressure Regulator
  69. Dirty Headlights
  70. Not Sure What To Do With My 01' Lx
  71. whats up everyone
  72. Rick Case Acura>Phantom Grip STR Giveaways
  73. please help 98 civic dx...did i make a mistake?
  74. Ecu diagram?
  75. Tranny gears question....
  76. h-brace bar?!?
  77. My Pizza Delivery car. Updates!
  78. Del Sol door handles/locks
  79. bye bye engine :-(
  80. squeaky shocks/springs
  81. i need help a/c line
  82. Omni Power
  83. G5 Clocks?
  84. taking off the stock intake tubing?!?!
  85. Got the new suspension stuff on -- with pics
  86. Integra DC ITR Brake Master Cylinder w/Booster
  87. CEL 72 and 74 code help please
  88. exhaust stuff
  89. is this good?
  90. Bleeding Clutch Hydraulics
  91. Power Sunroof.. motor works but...
  92. what should i do?
  93. where can i find an engine?
  94. Alternator Problem or something else?
  95. Integra Center Console and Arm Rest into a 5th Gen Hatch
  96. Help me with an ECU problem
  97. JDM parts for 7th Gen Civ
  98. Projector headlights for a Del Sol
  99. anybody know what this is? *see pic*
  100. sylvania silverstar question
  101. help....Vtec
  102. question
  103. Can I replace starter and distributor myself?
  104. Fuel problems....help?
  105. Thinking About starting a new ProjecT!
  106. sidemarker location?
  107. Exhaust Question..
  108. 6th gen auto to manual help plz fast
  109. Door doesnt lock w/o the key...
  110. A costly day... clutch, tranny, linkage???
  111. Hey everyone!
  112. 99 parts on my 97 EX
  113. This Civic...
  114. will my car get any lower??
  115. Alignment Shop NYC Area
  116. need some advice guys
  117. ok b18b is in
  118. Transformation of my car to date...with pics
  119. electronic boost controller
  120. racing seatbelt harnesses
  121. question about price on civic EX
  122. 2004 civic
  123. wheel tire help
  124. valve cover gasket leaking?
  125. crank pulley chatter
  126. Urgent help needed
  127. changing lock cylinder on an EX ?
  128. trying to find a cat for a 4-1 jdm header?!?!
  129. strut tower flexing?
  130. Bad Distributor housing on Civic VX
  131. s2000 seats in a civic ???
  132. ACT or CLUTCHMASTERS?
  133. Relocating Ignition
  134. header how-to
  135. Engine Swap
  136. Anyone ever install an Auto-Dimming mirror?
  137. Busted CV boot - help me out here
  138. radiator support
  139. Window seals
  140. Automatic Transaxle: Harsh Upshifts
  141. any 1 have access to acura's radio code database?
  142. Mes
  143. How the hell has everybody been?
  144. ls vtec?
  145. What transmission is best for ls engine?
  146. silverstar question
  147. Keyless entry fuse 98 Civic
  148. Battery dying?
  149. MSD Cap/Coil Question?
  150. where'd it go?
  151. 2005 Civic Changes if any?
  152. HId installation problem
  153. Buddy CLub in 42mm or 40mm offset?
  154. Best Motor for 94 Civic EX?
  155. is it just me? or...
  156. POS Window :oh:
  157. Anyone want a D16Z6 while doing a favor
  158. OBX is terrible, heres my experience **pics**
  159. bumper reinforcement removal
  160. good deal on motor?
  161. Quick 7th gen question
  162. Motor trashed in my 95 civic, replacement ideas???
  163. Tranny question
  164. Is an engine really that heavy?
  165. might be gettin a hatch for free or very cheap
  166. Just bought a Beaks Quickswap for my EG
  167. The Joys of Alternators
  168. timing belt tensioner question d16y8
  169. Which tranny is best for turbo B16?
  170. What's the best place to buy NGK spark plug wires?
  171. How can you tell if an ECU is bad??
  172. d16y8 stock rods,are they strong enough?
  173. 04 Civic LX, turbo?
  174. heelllppppp!
  175. man this sucks
  176. 02-04 Si seats fit in a 99-00
  177. Need bright headlights ? suggestions
  178. quick question
  179. 01+ valve cover interchangability?
  180. need price range for a OEM catalytic converter ?
  181. Installing A New Headgasket
  182. fan problem
  183. Lowering springs
  184. need help 95 civic
  185. Books Are GOOD. Also Ignition Question...
  186. ECU question??
  187. help...trunk light not working
  188. Silver Xtreme bulbs to replace signals?
  189. idle air control valve
  190. vtec question
  191. 00' Si engine swap question
  192. need 2 get code for civic stereo????
  193. Encountered an engine problem today - any ideas?
  194. switching dash trims
  195. Getting Integra Seats
  196. question about Z3 fenders
  197. Price sound right for a built b16a
  198. needin a new motor...
  199. dash and interior parts
  200. I HATE jacking up my car.. i think i bent my subframe!!!!!!!
  201. 90-91 Civic Si Seats in 93 DX?
  202. dash pocket
  203. need help, 5th gear keep popping out!!!!
  204. Whats a good way to Build...
  205. Turbo fixed...
  206. newbie here
  207. Help
  208. 93 del sol headlights
  209. ITR EJ DISTRIBUTOR, help!!!!!!!!!!!!!!!!
  210. Quiet Exhaust for Del Sol
  211. Took my car to the shop today.. YAY!!!!
  212. Civic swap
  213. Block Guard Cooling ?
  214. Engine electrics
  215. Accord V-tec in an EG?
  216. Apexi World Sport Coilover
  217. H&R Sport Springs OR TEIN S.Tech Springs
  218. headers for all civic?
  219. Newbie questions.. re: 97 Civic EX
  220. reverse noise
  221. Turbocharging a '01 Civic EX
  222. anybody heard of SCAT
  223. finished up my swap and stuff *pics*
  224. 96 exhaust
  225. how do i install side mirrors?
  226. is it my gasket???
  227. Second Battery/Isolator
  228. grr... gear wont go into gear!
  229. 2004 Civic Si??
  230. Nu_b!
  231. Del Sol Wrecked by drunk driver LOOK
  232. Cleaning up the engine bay
  233. metal noise under car
  234. Gauge cluster needles jumpy
  235. GSR with LS tranny
  236. uh-oh! i broke trailing arm- lca bolt
  237. Falken Azenis performence
  238. 94 vx + b18b swap question
  239. BLOCKPOSTING on homemadeturbo.com
  240. Engine Idles but won't rev - help plz!!
  241. Honda and Horsepower???
  242. my car broke. :(
  243. air bypass valve & hydrolock
  244. '93 Del Sol check engine light?
  245. a few issues with my beater 1990 civic hatch. help me out.
  246. PDA Dyno
  247. del sol rear drum brakes conversion
  248. Beetle GLS 2.0 vs. 2004 Honda Civic EX
  249. B18C-R Fuel Filter
  250. power mirror swap
go
