View Full Version : '92+ Civic/EL & Del Sol
  1. Car wont crank after sitting a month? Help
  2. 95 civic need suggestions
  3. DOHC VTEC Del Sol.. How rare?
  4. head gasket change
  5. New Member
  6. non vtec to vtec
  7. Genuine Italian leather shift boots - custom made for your car!
  8. Spun a rod bearing... now what?
  9. No Spark or Signal To Coil: 96 Civic EX
  10. Just looking for some opinions
  11. Oem 99 00 Civic Si Springs and Shocks
  12. Strut/Springs questions regarding 2001 Civic
  13. EG-Sunroof window flew off on the freeway...
  14. Starting issues
  15. 06 civic shifting issues
  16. 95 civic interior redo customization
  17. want to make my ek look like a touring car
  18. S4C Transmition
  19. ITR Exhaust on 96 Civic Coupe?
  20. RH CV axle not clicking into position
  21. About to hit 90K, maint?
  22. 99 Civic, should it have a light alarm?
  23. Cleaning the pipes
  24. ,...
  25. 06 civic price question
  26. Can I put a P28 ECU to a OBDII engine?
  27. Ground Control Coilovers.
  28. Crappy day yesterday
  29. shift linkage question
  30. rear disk brake question
  31. Oxygen Sensor Question
  32. Fuse location for side mirrors 96 civic ex
  33. Buddy Club N+ Damper opinions
  34. Front strut replacement on a Civic
  35. Question related to timing belt change on Civic.
  36. Is this true regarding recommended fluids for Civic?
  37. where did I mess up?
  38. 2006 Civic Wiper Replacement...
  39. Wanted: Honda enthusiast in Tucson area to help w t-belt
  40. 2001 Civic Coupe Hub Cap Removal Help
  41. 96 Civic DX woes
  42. lower ball joint
  43. 98 Civic...won't start, will start, won't start, etc.
  44. 94 civic body going price
  45. 1999 civic grille
  46. Skunk2 vs Koni yellow ground controls
  47. d15b jdm vtec specs
  48. honda trailing arm bushing xtractor
  49. How to install Cold Air intake for Civic 2000 ex
  50. obd1 civic throwing 41 and 16
  51. Im lookin 4 help about buyin a 92 civic, im sellin a 99 integ SE, swappin technically
  52. 94 civic HB CX- What do I need to get these things fixed?
  53. 1995 honda civic hatch
  54. Skunk2 COil covers....help
  55. 03 Civic Transmission HELP!
  56. Help with Skunk2 coil covers!...for 04 civic lx
  57. 95 Honda Civic installation help
  58. Wide body
  59. 00 SI stolen...
  60. H22 Swap Help!!!
  61. Integra brake swap question . . .
  62. 99 Front End
  63. Suspension
  64. SI Front sways NEED HELP!!!!
  65. 1993 eg6 electrical problem
  66. 1999 civic si
  67. Thinking of a used Del Sol - what to look for ?
  68. EL door
  69. 01 civic ex sedan factory alarm no sound?
  70. swapping 01 civic LX to EL front bumper
  71. b18(turbo)/b18(2ltr stroke & turbo)/k20(toda)
  72. 99 Civic Si Idle Problems
  73. San Diego: Thinking of buying a 2007 Civic. need owner advice!
  74. HELP please. obd1 engine into obd2 car
  75. Del Sol Civic Transmission Help
  76. would rsx coilovers fit on a 99 civic??
  77. Headlight issues
  78. 98 Civic type R Grill....
  79. Mysterious vibrating noise! help!
  80. CEL on
  81. Del Sol handbook re dash warning lights
  82. Resister box install
  83. changing from 14x5 to 14x5.5 rims.. tire q?
  84. Basic parts
  85. b20vtec (semi build) sparkplugs
  86. Cold Air Intake
  87. Coilovers
  88. Hood latch problems...
  89. Falken Ziex ZE912 tires
  90. MAP Sensor for 96 civic
  91. 1995 Civc DX 4DR MPG & O2 Sensor(s)
  92. Greetings from Mexico City
  93. does nobody know how to erase this code??
  94. 95 si
  95. TWM Performance Del Sol short shifter
  96. d16 engine overhaul vs. swap
  97. d16 engine overhaul vs. swap
  98. Power Lock not working after power window conversion!!!
  99. interior question
  100. 95 civic coupe suspension rebuild
  101. dash light question
  102. Distributor for B16 in EG
  103. Any ideas?
  104. HELP 97 Civic Won't start no more :(
  105. CarFax
  106. power loss 95 civic EX
  107. CEL or Check Water Pump?
  108. Del Sol warning light
  109. Aftermarket Radio/Keyless
  110. 95 civic questions fiberglass work interior
  111. Help please!?
  112. front grill help...99 civic
  113. 95 civic interior painting questions
  114. clutch is to the floor. help
  115. Spring Rate
  116. turbo, all motor or, nos??
  117. 98 strut bar question
  118. 94 Civic Headling Not Working
  119. 93 Honda civic axle help
  120. my 98 civic is overheating
  121. RHD CONVERSION QUESTIONS for 95 civic coupe
  122. E Brake Questions HELPPP
  123. cant unlock doors from outside
  124. trouble starting my sol
  125. '02 Civic EX 4dr. w/AT - need motor mounts?
  126. del sol warning lights
  127. del sol warning lights
  128. Catback
  129. Cracked exhaust manifold help.
  130. iac valve help
  131. 95 Civic CX to EX Questions
  132. Quick fuel prime, kinda?
  133. motor mounts
  134. New Project!
  135. brake set up swap from teg to civic... NEED HELP...PLEASE!!!
  136. Alarm Help
  137. Powder Coating: first try
  138. hammer question
  139. 98 Civic HtchBk with Hi Pitch Squeal
  140. Exhaust System
  141. 99 Civic Si with B18C Swap Questions
  142. tonites after work project pics inside :D
  143. Close/Open end tuner lugs
  144. DC5 rear seats - help?
  145. GSR Disk Brake Conversion; PADS uneven ware
  146. sputtering 97hx, burnt oil smell, CEL
  147. Help
  148. 93 Civic won't do anything.
  149. 2004 Honda Civic won't start . . .
  150. GAB Springs and struts -vs- SKUNK2 Pro Series
  151. finally got done cleaning this up..........pics inside
  152. Hate Sears (read about stupidity!)
  153. bouncing idle...
  154. lowering with tie rod issues......
  155. 98 Civic LX Unknown Problem
  156. My LSD came, W00T!!
  157. 1990 Civic DX Oil Leak and check engine light
  158. 1990 Civic DX Ignition Lock Cylinder
  159. 5 lug hub on 4 Lug spindle (rear)
  160. B18c1 Del-sol
  161. Auto-Starter not working properly and preventing 95 Civic from starting.
  162. 06+ civic question about front end
  163. Wheel hub, lug nut question for anyone?
  164. OBD2 Code P1632- 98CivicEx
  165. recomended tire size????
  166. mother trucker axe licking bilky balls
  167. Torque Struts For Engine Mount
  168. Will Prelude si seats bolt right in?????
  169. 95 civic
  170. I wanna enter my ride in the upcoming HIN...
  171. Honda guys convince me of why to buy... (novel-length)
  172. Radio power problem
  173. lowering gone wrong
  174. Tach Help
  175. dash lights dead????
  176. Sunroof problem - 95ex
  177. Key Fob
  178. question about tein struts
  179. My 94 Del Sol is Slow
  180. EK Power Window Conversion Question???
  181. Speed Sensor/97 honda civic LX
  182. HOW IS the clutch from EBAY?
  183. Exhaust Manifold Stud
  184. 95 civic problem?
  185. b18b stutters, searching barely helped
  186. tune up
  187. 2001 15,000 Honda Civic transmission Disaster!
  188. getting the civic
  189. removing fronts seats
  190. Help Installing Halo Headlights
  191. H22 Motor Swap
  192. Help me troubleshoot. Brake booster or MC?
  193. axle reinstallation question
  194. 95 civic DX suspention
  195. installing tail lights
  196. 96-00 Civic Engine...
  197. Drive plate torque
  198. how to check O2 prob
  199. 2000 civic si ECU probs
  200. P300, P301-P304 codes....random missfires
  201. hi
  202. short throw makes funny sounds
  203. Removing 96 civc axle nut
  204. replacing headlight bulb for 95 civic
  205. turbo questions
  206. Help?????
  207. what do you get for mpg?
  208. reinstalling transmission on a d16y8 - pls help
  209. change wheel stud on 98 civic ex?
  210. D16y8 question please help???
  211. Finally some updated pics to post... 95 civic integra front end
  212. What code am I reading?
  213. 95 civic questions
  214. rebuild kits
  215. 1994 Civic HB 1.5 vtec bogs out at low rpm's HELP PLEASE???
  216. Insurance cost
  217. can I fit a D16y8 engine on a Honda civic??
  218. Need a new header quick
  219. OBX LSD Install
  220. Manual a/c to climate control; what to do?
  221. fixed starter, connected batt and shorted out?!
  222. 99 civic ex intermittent heating system failure
  223. Small tuneup for cap,rotor,plugs,wires?
  224. 99 Civic Si maintanence light question
  225. Front end for Del sol
  226. acceleration
  227. front wheel bearing - 1992 Civic DX
  228. '92 Civic vx (D15Z1) turns, won't start...
  229. Do I need special tool to Remove Silencer?
  230. 89 civic wont start
  231. engine bogs/sputters at high RPM! Need help!
  232. 96-98 Civic manual in pdf form!!
  233. noobie question
  234. Older knock sensor on 97 engine?
  235. Header Q.
  236. What your fuel miliage?
  237. Removing rear oil seal on a d16y8 - pls help
  238. Ca. Smog Failure
  239. new here, got me an eg.
  240. What your miliage?
  241. 91 seats in 94 eg
  242. Scheduled Maintenance Months vs. Mileage
  243. ATI Race Damper
  244. retiming civic help
  245. Help Changing starter on 97?
  246. Rear Disc Conversion
  247. I NEED HELP!!! tranny problems on my 95 EG
  248. humming noise as speed goes up...wheel bearing?
  249. Jdm D15???
  250. 1995 civic
go
