View Full Version : '92+ Civic/EL & Del Sol
  1. brake upgrade
  2. Type-R pistons?????
  3. Gas Mileage
  4. Once again!
  5. SoCal Honda Cruise
  6. usdm vs jdm foglight switch
  7. 95 Civic EX (vtec) motor mounts?
  8. shaking at 70 mph?
  9. Parents Dont think
  10. hood latch cable relocate
  11. suspension question urgent help needed
  12. How much would I get for this?
  13. tranny question
  14. help please!
  15. Should I use a b18a1 in my 95 civic
  16. how to increse hp??? help!!
  17. clutch question
  18. Header question.
  19. Which Spings
  20. Racing seat question
  21. S2000 motor in EG? (insert hating here)
  22. 04 civic problem
  23. I just came to the conclusion that...
  24. just a question
  25. Cheap Turbo/supercharger?
  26. i need part help
  27. From noise
  28. B18B1 Turbo Install
  29. Installing an SRI on a 6th gen coupe
  30. Help! d16z6 Engine noises...
  31. OEM Shifter
  32. 2006 Civic pics?
  33. What turbo kit for a b18c in a 93 civic?
  34. wiring my city lights..
  35. Best(cheapest) place to buy a B18c complete swap from!
  36. Civic- Timing Belt pints...
  37. fuse question, help[!!!
  38. Engine Block Heater
  39. 94 Del Sol Dome Light Question
  40. exhaust decisions
  41. this may help most of you...
  42. this will help most of you out
  43. Vvvvvvvvteeeec!!!!!!!!!!hhh!!!!1-``~!
  44. couple exhaust ?'s
  45. coilovers installations?
  46. Transmission swap question?
  47. swapping manuals?
  48. Mild B20 build up
  49. EK Struts fit EG????
  50. other Honda wheels
  51. my cluster is a weirdo! *video*
  52. Decided to take some new pics today(before i clean it)
  53. First civic
  54. *PicS*Cooling system goin in tonite...*PicS*
  55. good trade???????
  56. Electronic drain Module?
  57. Rev Hard stage 3 turbo
  58. Idle question
  59. I was bored in my stock civic
  60. radiator for civic ls swap
  61. coilover question
  62. Best exhaust..for the money!
  63. which ITR axel back?
  64. Radiator Replacement
  65. front end conversion
  66. 99-00 si grille
  67. most powerful honda engine?
  68. Clutch Replacement on 94 Civic EX D16Z6
  69. Need some serious help. Videos included
  70. suspension repair
  71. Power steering question......
  72. 00 TypeR tranny with LSD
  73. dealership swap
  74. friends Civic
  75. Need power window/lock harness from under dash
  76. photoshoot with new look
  77. Ported Dohc Zc Head Honda Civic D16??
  78. Interior!!!
  79. 99 gsr engine tranny ecu etc...
  80. Del Sol Break in.....
  81. a quieter exhaust
  82. Why?
  83. Can't adjust my sound....
  84. Change of plans
  85. need help
  86. Motor Harness
  87. Some pics of Cat, my Sol...
  88. Pictures of my weekend mini-projects
  89. Civic exhaust fit on del sol?
  90. Help removing 97 ex door panels
  91. Pics of my Civic hatch , up for comments.
  92. Crankshaft pulley wearing out
  93. Anyone using Bilstein Tourings?
  94. ECU codes 9, 41 and 43 civicEX 92 115K miles
  95. Glowing Needles
  96. Switch from 10w30 to 5w30 Mobil 1 Synthetic oil
  97. enkei wheels
  98. Best short throw shifter
  99. IACV help please
  100. Horn & wipers dont work, fuse diagram?
  101. I Need Help Fast!!!!!
  102. Question about Header...
  103. Distributor stolen!?!?
  104. Redo suspension...
  105. 99 civic dx engine swap
  106. d16y8 HP mods
  107. H22 Swap
  108. Who has done a H22 Swap?
  109. 95 LS enigne in 96 EK
  110. del sol help
  111. del sol modifications
  112. d16a6 intake manifold..
  113. WTB: Front EG2 Bumper
  114. Obd conversion help
  115. Autocross video from Northeast Divisionals 2004.
  116. f**kin' Rip Off's
  117. A new Steering wheel and new pics...
  118. Can't shake my CEL
  119. I found a tranny
  120. Tranny Swap
  121. My (modest) mod plan. Is it achieveable?
  122. Help! no injectors on crank
  123. 03 civic headlight dont come on
  124. My car, what do you think? Silver or black rims?
  125. painting valve cover?
  126. How do I get these off/out?
  127. 94 EX Brake Conversion: Why not use parts from 94 Civic with disc?
  128. heads up on eg parts fs
  129. 97 Hatch: Motor Jump
  130. cleaning headers
  131. hp question
  132. The A.C. mount on 92-95s
  133. Gsr Block with Ls Crank and Rods OPINIONS and HELP NEEDED
  134. And another new mod.... wheels.
  135. servicing tips needed
  136. *plethora of JDM, OEM, USDM, and TDM parts* (56k semi otay)
  137. 99 civic dx best parts
  138. Mount for Corner Lens?
  139. Possible Dumb Question
  140. Clearence Question with Apexi N1
  141. New Parts !!pics Pics Pic!!!
  142. Need help with mirrors
  143. WTF is this exhaust???
  144. Ghost in my Civic!
  145. Want to do a swap but HELP IS NEEDED
  146. popupar places online to buy performance parts?
  147. Removing the A/C
  148. cooling system?
  149. *non-jdm cupholders!!* pix (56k OTAY)
  150. Wire colors on IAT connector 92-95 civic 1.5 DX??
  151. Motor Mounts
  152. super afc tuning question
  153. Del sol engine swap question.
  154. Will B18C Fit Del Sol?
  155. D16A6 Head Clearance
  156. Whats the lowest price you guys have seen/bought a Civic EX or LX?
  157. 1998 civic dx check engine
  158. smoke.....please help
  159. what is the chassis code for my 96 hatch?
  160. Looking at new wheels
  161. I/H/E shopping by facts + figures, not brand! all your suggestions plz
  162. I/H/E shopping by facts + figures, not brand. Gimme your suggestions!
  163. This is a list of all civics and integras ecu codes
  164. Turbo? what will fit?
  165. ATTN: 6g civic, bseries swap pros, question....(technical)
  166. Labor for tranny swap?
  167. My 'theory' on intakes--correct me!
  168. help with headlights
  169. CAI Install Help
  170. Torque mods
  171. RSX seats into my '00 civic si
  172. rear speakers on a 98' Civic DX
  173. EP3 steering wheel into EK
  174. 2 suspension questions
  175. Some questions about changing oil...
  176. Help with brakes
  177. usa fuel... what octane
  178. Header Gasket
  179. Key gets stuck in ignition!!! Please help!!!
  180. need carfax report
  181. 5th injector?
  182. What car what turbo?
  183. 2002 Civic Backup Light Wiring
  184. Vacuum hose to fuel reg?
  185. Preload upper control arms?
  186. Not enough power :(
  187. short shifter?????
  188. anyone in OC wanna help with 90-120k service on my civic (will pay)
  189. Looking for transmission
  190. You gain some (clearance) you loose some.
  191. rimages
  192. water temp question
  193. alternator or battery or...?
  194. Ls Motor
  195. 2000 Honda Civic EX Mugen style lip
  196. Is My D16z Worth Keeping ? (rookie)
  197. first honda
  198. service connector location in 92 civic ex jdm p28 ecu
  199. HELP! I need a JDM Honda part number quick...
  200. Falken Zeix 512s
  201. Theory is sound, but in practice? (Air intake idea)
  202. Question about Si wheels?
  203. 97 hatch question
  204. AEM Pulley Question?
  205. ON the market for a Honda
  206. Waaah they beat me to it (my car was "played with")
  207. HELP!! Dripping Noises...
  208. UPS guy brought me a gift today :yay:
  209. 1995 Honda Civic LX Exhaust system
  210. engine before and after
  211. got my car back
  212. Ek,eg,ferio?
  213. Coilover ????????????
  214. Final Decision? Help
  215. Del Sol Amber Corners
  216. Switching suspension pieces
  217. Water damage to sensors on my 95 civic DX
  218. 1994 Honda Civic Del Sol--
  219. Swap Question
  220. Read Disc Conversion
  221. Will a B18c-r integra type r motor work?
  222. HOW-TO?-Alarm installed, use OEM lock acuators.
  223. 0-60 times?
  224. would this be a good susp. setup?
  225. Will this work
  226. 350hp civic hatch
  227. Prelude axels fit 5th gen civic..?
  228. B16a in a 5thgen civic coupe?
  229. my civic pics .
  230. anyone remember civic on 19's ????
  231. Large Radiator?
  232. B18b Throttle Body
  233. Thought i would stop by and say hi...been a real long time
  234. Best fit in 93' civic dx? motor!
  235. Should I?
  236. HELP! Where to get suspension bushings for '95 Civic EX
  237. PnP Intake manifold
  238. Stock Springs Help!
  239. 96-00 Civic FrontEnd Conversion for Del Sol
  240. Climate Control
  241. Gettin the car painted
  242. Front Bumper
  243. 99 coupe vs sedan muffler the same?
  244. 94 civic lx..motor swap?
  245. OBD2 Wiring Diagram..Need it badly
  246. Best rims in your opinion...
  247. Suggestions?
  248. Anyone tried the sage tower strut bar?
  249. Cooling Fan switch burnt out
  250. Intake Manifold replacement?
go
