View Full Version : '92+ Civic/EL & Del Sol
  1. grinding sounds
  2. hit pothole - steering fuct
  3. EK foglights
  4. Throttle Body ??
  5. Help! I just broke off my door lock!
  6. quick ?? bout valve cover
  7. Finally some real pics of "our" car....
  8. car vibrates when braking
  9. gas needle
  10. Best Header
  11. eBay Rims <_</?
  12. question about engine.
  13. ZEX kit?
  14. got vtec!!!!!!
  15. Back on the road : )
  16. Question about installing....
  17. HELP!!!! 98 civic wierd problem
  18. Civic sputtering when cold..
  19. Street Styler.com - theives
  20. 97 Civic Manual Trans. Vibrates
  21. Is upgrading my engine now useless?
  22. wiring question
  23. TPS loose, how to fix.........
  24. Need some clutch/fly suggestions...
  25. Axel maybe?
  26. lower ball joints
  27. new stance
  28. how do i remove my aftermarket cd player out of my 94 civic...i just bought the car
  29. water pump rattle? wandering idle?
  30. wiring harness question
  31. where to buy windshield
  32. problem with ls/vtec in del sol
  33. AEM CAI and the car loves 85 mph.
  34. shift linkage leak help!
  35. Shock Questions....
  36. axles
  37. Shocks/Springs on....what's that noise?
  38. How to prevent many electrical problems.
  39. im still having a problem
  40. Just got an Alarm what do you think?
  41. research
  42. honda releases new b15 motor rated at 145hp!
  43. G48 retainers?
  44. 92 4 dr power window
  45. Where to buy......
  46. T-belt change or Swap?
  47. Does this seem like a deal?
  48. Sellers on Ebay are kinda fishy
  49. Gx20?
  50. Please be on the look out for my car in the Sac/Davis Area
  51. so this civic mite go bye bye
  52. D15b or D16z6???
  53. Reinstalling Door Panel
  54. 96-2000 Honda Civic Ex Gauge Cluster
  55. Performance and looks
  56. Checking CEL Codes?
  57. Power Steering for Civic 96
  58. Tired and Frustrated!!! Help before I give up!
  59. Happy Happy!
  60. ECU code 11
  61. leak coming from water pump i think?? 93 civic D16Z6
  62. basics
  63. OBD1&2 issues
  64. Need help about Bseries halfshafts.
  65. Installing new electrical
  66. Popular Free Stuff
  67. the fine line between OEM and performance.
  68. what kind of brakes you guys have ?
  69. Quick help w/ Distributor Rotor...
  70. Purge Valve Broke? Do I need it?
  71. Hard Wiring Inverter
  72. engine bay
  73. Trunk Braces
  74. stock springs...how many inches?
  75. amp wiring w/o remote wire?
  76. 95 Civic Motor mount replacement - my experience.
  77. Interior dome light not bright enough
  78. What are you guys paying for bearings and half shafts?
  79. quick question
  80. New civic Si Steerign wheel into a 94 EX?
  81. How to turn My 94 EX into a Si...?
  82. To Those who have changed their dash lighting
  83. Question about Wiring?
  84. del Sol Sweatshirts/Hoodys
  85. New updated pics of the WHIP
  86. I'd like to welcome the newest member!!
  87. cheapesthondaparts.com
  88. 1993 Civic ESI (UK model) whats its US name?
  89. Cast Rims
  90. shocks..
  91. CTR Intake Cam Part #
  92. Exhaust ???
  93. Lower my del sol
  94. a couple questions
  95. ecu problem?
  96. B-series Cam specs
  97. D16a6 to a b18c1 or typeR swap???? in a rover tho!
  98. transmission swap problem?
  99. Installing a S2k Antenna on a Del Sol
  100. Stalling after valve adjustment
  101. Del Sol Black / Clear Corners Pics
  102. What KYB told me about GR-2 and AGX shocks struts
  103. Daily driving tire pressure
  104. Smog Fail Help!
  105. What Stock Wheels will fit?
  106. D15b Vtec
  107. Pep Boys Clutch ??!!
  108. sylvania silverstars question
  109. Rotating Crankshaft Pulley
  110. Check Engine Light Help
  111. weight of rims on del sol..!!
  112. 97 Civic HX Check Engine Light
  113. one peace headlights for eg's
  114. new springs and shocks
  115. SOHC/DOHC VTEC...sticker
  116. rim question
  117. would 00 ex shocks fit 98 ex? control arm too
  118. does anybody know AccordinglyDone?
  119. 2000 Si Owner's Manual
  120. 99 HB exhaust ideas
  121. Problum with gauge console
  122. Sell the 97 to buy a 92-95 HB..?
  123. "How To" build a street racer
  124. replacing rear speakers
  125. help with power window conversion?
  126. Tires for a 2000 Civic Si?
  127. help identifying this rim
  128. engine trouble
  129. Help with Primary o2 sensor
  130. Maybe someone can answer my question
  131. Temp, Sensor Modification?
  132. Custom Turbo Questions.....
  133. Best deal for decent wheels?
  134. car shakes
  135. car pis
  136. What steering wheel fits?
  137. Stock Springs with KYB shocks?
  138. Help? D16z6 Del sol Valve Adjustment
  139. Need Some Help...
  140. How about these coilovers?
  141. Seeking parts place for gauge faces
  142. optima battery
  143. More and more problems!!!!
  144. turn signal
  145. Newbie...ELD wiring question
  146. Just some feedback please
  147. Tein S.tech Springs??????
  148. Del Sol Aux Control Bulbs
  149. NEED HELP! Car stalls when I slow down
  150. o2 Sensor
  151. radio code
  152. can u put a h22 ecu on a SOHC
  153. Tilted car... suspension?
  154. 04 SI seats in an EK?
  155. Civic Gauge Cluster Question???
  156. Whoa... 8500 for stock suspension :O
  157. short ram intake help :confused:
  158. I dont feel like making my own harness
  159. Odd sound..
  160. are my shocks blown out?
  161. Fuel Pump Cutoff Switch
  162. greddy and trust exhaust?
  163. suspension question
  164. Trying to find the bracket for Console
  165. springs
  166. Fuel rail?
  167. odometer question
  168. 6sp?
  169. Turbo with Self Contained Oiling System?
  170. EK type r rear sway
  171. B18A1 trade for D16Z6?
  172. Fan heater burning smell & sparking - how much is this going to hurt??
  173. exhaust help needed
  174. ?'s about swapping GSR dash into EG6
  175. Need power not sound.....
  176. your thoughts! what would you do?
  177. '00 Civic EX coupe STEERING wheel vibration!
  178. :ohnoes: part 2
  179. do i need a new axle?
  180. 3rd Del sol eats it...?
  181. Riceburners still suck
  182. Buzzkill........aarrgg
  183. Random Vacuum Line
  184. Riceburners suck
  185. should i get my car checked?
  186. Si Gauge Cluster
  187. replacement tires
  188. Here she is take a look!!!!!!!!!!
  189. What to look for in a used Civic...
  190. Gauges
  191. 96-98 dash swap to 99-00 walkthrough
  192. Rear suspension bushes
  193. brake setup
  194. *PicS*HIDs in h4h jdm housings*PicS*
  195. Website anyone?
  196. Locked
  197. Rust!
  198. 99-00 rear defroster wiring diagram please.
  199. Quick ?!!!
  200. omnipower coilovers
  201. Boosted question
  202. i replaced my d16z6 and it won't rev over 3 grand
  203. D-16 Fuel pressure ?
  204. civic radiator inlet/outlet too small
  205. 96-98 to 99-00 TAIL LIGHTS CONVERSION??
  206. ALIGNMENT and WHEELS PROBLEMS!!! HELP!!!
  207. Suspension question...
  208. Guess my alignment problem
  209. Cheapest gsr swap?
  210. Civic I just bought!!
  211. ?'s on 94 Del Sol please
  212. door lock problem
  213. Dot 3 or Dot 4? Brake and Clutch?
  214. Post your favorite 01-03 civic body kits you have seen::::::::
  215. Del Sol Performance Questions
  216. Wierd Idle on 95 Civic
  217. NEX SS Suspension
  218. cant get wheel hub off
  219. quick questions reguarding my d16y7
  220. New to thread a few ?'s
  221. next little project.
  222. bulb size
  223. where to buy ITR 5 lug conversion?
  224. new exhaust pics, JDM Yo! :p
  225. Shocks/struts ever need replacing on '95 Civic EX?
  226. Some pics from 2004 SCCA NAtionals.
  227. GSR SI EX ecu's
  228. Top Dead Center Sensor
  229. winshield wipers
  230. Turbo D16 or N/A B16
  231. I searched couldnt find the site for piping...
  232. A'pexi N1 Muffler and Lowering
  233. :ohnoes:
  234. thermal r&d exhaust
  235. those w/ 16" wheels
  236. Polk DB650 compatability with 6th gen Civic 96 97 98 99 00
  237. Replacing Coolant
  238. Need Advise Asap
  239. Under hood mirrors.
  240. Civic 92-00 hood question. Need your help.
  241. ATTN:ppl w/ B-Series using Hondata im gasket
  242. Good deal?
  243. speaker question?
  244. Muffler is filled with black stuff??
  245. wheel help
  246. battery in backwards
  247. Energy suspension shifter stablizer Bushings
  248. Bseries tranny decision problem
  249. bolt?
  250. buying a del sol - what to look for?
go
