- HID HB series help!!!
- Intake Air Temperature (IAT) "Code 10" help
- Alarm Problems
- bolt that holds lug nuts on
- 96 ex 5 spd what tranny fluid to use
- Energy Suspension Mount Inserts
- Lx Vs. Dx
- Turbo Emissions??
- newbe questions
- 1995 civic 3 dr hatch
- Where to buy front bumper cheap
- Suspension?
- I need the pinout locations on a vx
- Stainless Muffler a Good Idea?
- cam gears work?
- Clunking noise from front end
- I !#$%ing broke my side mirror.. how to fix it?
- honda civic 2002
- Stereo!!!!
- Civic Gx vs...
- Civic hit 190,000 today
- Bought 95 Civic LX Sedan (107k miles) for $1,600
- rims for 04 civic
- Denji Projectors
- HELP, i want to swap drums for dics on a 97 Civic LX sedan??
- Power Steering fluid?
- short throw shifter for an 01
- New Swap!!!
- B-series Motor mount question
- questions regarding type r wheels
- Remote stoped working...
- hard start ups
- Whats the most an eg can be lowered without coilovers
- 01 civic:: How to reset maintenance light
- Where is a good place to get OEM parts?
- south florida honda engines
- motor and alarm
- bouncing idle on gsr
- Pics Of Shock Mounts?
- Loud civic!!
- just bought a 93 si what motor?
- HID immitation bulbs....
- Need Help - Honda Civic 94 - valve cover gasket bolts
- 96 EJ6 exhaust upgrade
- Turbo a stock JDM SOHC ZC
- torque specs for spark plugs 98 Honda Civic Dx
- Is this nice or what?
- Tires
- Steel rim
- post your HID installs...
- motor swap?
- civic bogging down on highway
- MINI ME HELP-- z6 or y8???
- Where to buy a engine??
- Just wanted to say hi..
- ? bout exhaust
- my eg6 got smashed up
- Locating a 12V source
- Magnaflow Muffler
- Ground Control Coilovers
- New Jersey Car Owners!!! Please Help!
- d16 SOHC non VTEC to b16 DOHC VTEC swap
- 98 Honda civic problems
- Oil Capacity
- My Exhaust Emissions Test Results
- short shifter question
- My 95 Civic LX seems to have consume too much gas
- exhaust question
- manual conversion, wiring up reverse lights (selling an automatic tranny too)
- Happy Holidays
- eg9 with full dc2 spec
- could i swap in an RSX motor
- 95 Civic Hatch Engine issue?
- AEM Ems
- My 95 Civic RPM is 3000 between 70-75MPH
- del Sol door panel problem
- Spark Plug Installation
- Little help with front brake dianosis
- need help! a'pexi super suction kit?
- safe to remove these two bolts for strut bar?
- Emissions Warranty
- MSD Coil in stock cap?
- 97 Civic front brake rotors..
- Are the 04 trunk lids the same as 01-03's?
- Help
- 04 Civic
- JDM 4 door integra spoiler suggestion
- rebuild d16z6
- please tell me that this can be dun
- engine swap can it be dune 92 to a 96
- quick exhaust question...
- Does anyone make an intake like this for the civic?
- Speaker Cone repair
- Positive and Negative Leads
- quickie about exhaust
- Nice eg9 with mugen kit
- Ignition with a switch
- HELP!! My reverse gauges dont light up.
- DX mods
- Umm...oops? Broken distributor
- Need help with 3rd brake light
- Maximum wheel offset for del sol ?!
- Help a 94 DELSOL V-tec dohc w/ generics
- '02 Civic Coupe rear speakers
- Install new headlights on 97 Civic 2 door
- turbo D-series reliability?
- Some help with swap
- Temp sensor... HELP meh's out
- Driving that stick
- help in Modesto area!
- Turbo piping
- HELP: Quiet exhaust?
- ZMAX actually work?
- Rear lower tie bar install - an easier way
- Turbo D, and Swap into B in summer?
- reverse light install on auto to manual conversion
- Trouble understanding turbo's/kit's.
- CTR rear sway bar help...
- cable to hydrolic conversion questions
- 1998 Civic Problems...Help!!!!
- Problem with 02 Civic LX sedan
- diagnostic mode?
- How to reset "maint reqd" light on dash? 01 EX
- CD Changer
- Clutch not engaging
- She's sprung a leak, Captain!
- Compression question
- New to Honda's a few Q's?
- ABS Plastic or Urethane front Lip?
- Performance D16 parts
- newbie have a CAI question
- b16 install questions and answers
- ...Trannys...
- Cheap mods from ebay
- Need Help with Wiper Motors
- gt spec Exhaust
- Tach jumping back and forth.
- Manifold Suggestion???
- Need a new D16Z6 Tranny
- Big install day for me....
- lowering my EJ...
- Engine mount question.
- honda seats and induction kit
- *PicS*new seats and some beat*PicS*
- What Cat-back should I get
- Civic tranny in a Teg?
- Need Turbo Help
- need help with d16 question!!!
- V-AFC question
- Wideband o2 Sensor
- 2005 Civic special edition
- second guessing doing the mini-me
- cold weather idle?
- what brand brake pads
- Cooling system woes..help!!
- Tire Pressure!!!!
- 16" Sparco Tarmac's on my 94 EX?
- EK Civic Type R
- power windows falling off track
- B series accessories
- Strut bars interchangeable?
- piston choices
- need some help on 98 hatch
- stupoid question.. but... where's my fuel filter.. :af:
- I'm New!!!! 05 Civic EX Special Edition - LUV IT!!!!!!
- Before and After pics.. did I get screwed??
- Strange recurring rpm problem 95 del Sol VTEC
- Trade '95 CX for '97 DX
- 2000 honda civic/SE
- 96 civic turn signals don't retract!
- How to install 96 Civic rear speakers?
- 5th gen dx heater problem
- Idle PROBLEM
- '93 Del Sol - Lowering Questions
- Hi, everyone. I'm new!
- engine ground
- timing adjustment
- rear disc break conversion on 95 civic dx
- Cel
- 4 door 2 door thrend
- 98 hatch door
- any way to clear up headlights?
- Headlights?
- Problem with something?
- Help, Clutch problems in a del sol...
- Pebbles on tires
- Switching AFC's
- Need assistance with a swap
- Suspension help is needed
- Speedchip question!
- Shitty gas mileage....??
- need help!
- would u make this trade....
- timing belt setup
- Radiator question
- ...92-95 Civic Hatchback Question...
- gas mileage
- trim levels for 96 civic
- Need Intake
- questions about the vafc 2..
- Turbo Problem
- Headlight adjustment on 92-95 civic coupe??
- need help on pwr windows !
- b16 vtec
- alternator ?
- UberData
- Question about a short shifter
- Wheel well
- how can i check the tranny?
- Lots O Help!
- Dead battery and alarm...
- Who wants to help with some n00bish questions?
- do the japs try and copy our car's looks
- B16A2 into 95 civic dx! Need Advise!
- MSD Ignition
- inspection
- Unsprung disk!
- Dong, Where is my Car?
- Problem with clutch
- B18C or B18C Type R
- trying to trade 17inch momo gt2 rims
- Serious Overheating Issues NEED HELP ASAP
- LEDs in driving lights!!!!
- How to reset cel on 99 civic?
- Car is smoking...n e 1 no y?
- Turbo D series motor
- Mounting a BG?
- question for 92-95 civic guys
- newbie
- how much boost?
- should i change my oil to 10w
- H22 Swap Into A Del Sol
- They Took My EG
- How I got F****d up with the swap.....
- Difference between Us Civic SI and Canadian SIR?
- havent been here for a while
- just bought a Civc EX
- CTR cams
- so how many solers are still here?
- ...b16a2 Need help...
- Honda Civic Rear Tail Lights
- Oh how I miss thee...
- Interior Upkeep?
- looking for a hatch
- B18C1 in 93 Civic CX
- Civic 98 keyless entry
- Si '93
- door
- Speedometer Sticks
- 97 civic ex exhaust
