View Full Version : '92+ Civic/EL & Del Sol
  1. A few things.........
  2. '95 Civic losing water out of rad.
  3. what should i do
  4. 1994 Honda Civic CX ECU Question
  5. Which spark plug do i buy?
  6. Will the low fuel light work from a new instrument panel?
  7. Someone answer please?
  8. All individual wrenches and sockets 50% OFF at Sears!!
  9. Civic Suspension problem!!!
  10. thought i would post these aswell. rsx rears
  11. Intake Manifold Crackage!
  12. What are these unused wire connectors for?
  13. What's most likely to be damaged when accelerating fast in a Civic without Vtec?
  14. Weird Issue
  15. GSR Tranny BROKEN, housing cracked, B16a2 housing fit?
  16. need opinions
  17. hookups on shifter bushings
  18. sohc vtec??????
  19. motors
  20. Straight braking has a right side bias
  21. to boldly go...
  22. 94 Civic Door Handle
  23. camber kit
  24. engine swap
  25. ac filter
  26. hitting rev lim. at 5500 rpm
  27. ek looking for ecu compatiblity
  28. Need Help Decidin?
  29. OBD2a to OBD1 conversion question
  30. auto to manual
  31. Cracked Distributor Cap
  32. 99 Civic Idling Problems... getting closer???
  33. curious...
  34. Opinions on Skunk2 lowering springs
  35. tapping into wires
  36. 1990 Honda Civic EX Squeek and Squeal behind Dash..intermittant stall and search
  37. Kosei K1 Racing rims would be ok for non racer ? lol
  38. Old Exhaust Question
  39. weird noise!!!!
  40. how to remove d16y8 pilot bearing?
  41. Where can i get a blow off valve
  42. Question about airing tires.
  43. Civic fender fit del sol?
  44. repair prices
  45. 01-05 civic hx's good?
  46. Civic DX 97 front passenger window problem
  47. d15b7 -> d16y7 direct swap?
  48. InlinePro
  49. Type R Shifter DUal or SIngle?
  50. 99 Conversion
  51. Fuel Return
  52. '00 Acura 1.6EL. Rear defrost half works, but wierd.
  53. adding smaller tires than stock can change ur MPG?
  54. EG auto ~> manual tranny swap
  55. ceramic or ss
  56. Del Sol custom interior
  57. Are all d-series tranny's compatible??
  58. What Next?
  59. Rattling hood
  60. can i fix this?
  61. So... went to change my clutch today and...
  62. Econoline vs. Civic -- Deathmatch
  63. ? bout fog lights...
  64. My baby, finally back on the ground
  65. Best turbo/ kit for a D16Z6?
  66. swapping odometer?
  67. Inside fuse panel question?
  68. Omnipower???? control arms
  69. Kyb AGX
  70. Kyb AGX Question?
  71. Maint. Req light Red
  72. Finally got a civic..so happy
  73. People that can't drive!!
  74. my buddys car (ferio w/ jdm f22b and other JDM goodies)
  75. '95 Civic DX Problem
  76. F20C 2.0 16V DOHC VTEC for civic?
  77. Oil Pan Gasket change '92 civic
  78. Paint Code
  79. Accident!!
  80. 99-00 Fog Lights on EG
  81. My car blew up!
  82. im lost need help on engine
  83. hey was up im new
  84. Honda Fog light switch
  85. b16a2 or h22a in 93 civic ex
  86. Fog Light Problem???
  87. thought this was funny
  88. Help: Lower control arm
  89. Should this Del Sol be fast? 1.8 acura LS motor.
  90. So my turn signal "click, click" thingey is going
  91. 94 civic lx engine help
  92. B16 into 93 Del Sol s need help
  93. Fog Light Question?
  94. totalled?
  95. what should i do?
  96. water in interrior of hondas????????
  97. Any idea on what could be causing this noise?
  98. sohc to dohc????
  99. t4 or t3 turbo on 93 ex b16A2 2gen
  100. When did your honda engine die?
  101. More EG buying advise please
  102. Pedals on 2000 LX
  103. Where is the ABS computer- 98 civic LX
  104. Changing inner door hanels for EK
  105. '92 Civic-Fuel Pump Relay Problem???
  106. 16's or 17's 4 my civic
  107. My Rim is Looken ugly
  108. Tenzo big rotor...opinions
  109. custom radiator for swap
  110. Camber Kit help
  111. advice needed on 93 Del Sol S
  112. Disc Brakes in the Rear on a 93 civic DX
  113. how much...
  114. Regaining lost mileage
  115. Funny 1.6L vs 2.0L picture
  116. buy brand new 1999 civic si now?
  117. where are the 2004 Civic parts?
  118. IACV Idle Air Control Valve location
  119. Civics don't have anything that prevents outside stuff from getting into the engine?
  120. What do you think of this?
  121. stuck moonroof
  122. questions about b16a2 swap into 93 ex?
  123. strut Question?
  124. shifter problem. Help??
  125. [pictures] what is this for? (inside door)
  126. tach lead
  127. 95 civic gauge cluster
  128. oil problem
  129. Del sol catback Exhaust ?!
  130. 4 Pt Harness
  131. Ricer???
  132. Strange problems!
  133. Anybody A Have Picture Of Seibon Front Lip?
  134. Help: Where's a good shop to get a windshield replaced in S.F.?
  135. Tail Light replacement
  136. engine oil
  137. Question about wiper switches. (5th gen civic)
  138. Is it bad when....
  139. How to take out rear seats
  140. Hondata
  141. how to install skunk2 camber kit into a 95 civic
  142. transmission oil change....
  143. how to distinguish 'genuine' clutch components?
  144. Wide Tire question!
  145. suspension help
  146. good deal?? need advice on buildin motor
  147. I need suggestions for performance parts on a 2005 Honda Civic.
  148. Flush Mount Exhaust Tip?
  149. Timing belt
  150. what head do i need
  151. glueing bumper
  152. c/f front lips
  153. Instrument Guage Cluster Question
  154. 13th DOHC Del Sol Ever Made Restore Project
  155. tein s-tech question
  156. Paint code for the 2000 honda civic SI???
  157. Pics of my Turbo Del Sol
  158. Need info on suspension.
  159. Is there any cabin air filter for 01 Civic DX?
  160. Del Sol lip Question?
  161. wrecked 96 civic coupe
  162. What's on the bottom of a Civic to protect it?
  163. help with 99 civic sedan door
  164. Valve adjustment - Needed?
  165. just did a comp. test....
  166. best exhuast for 98ex
  167. Any problems changing the interior design on my civic?
  168. you guys like the 5 door hatchback civic?
  169. Advise needed
  170. Can I get an InDash DVD player for my Del Sol?
  171. 99 civic turn signal help
  172. OEM bumpers
  173. NE1 replace the axle bearing?
  174. Running axle without dynamic damper Q..
  175. what should i get?
  176. Rough running problem
  177. 99-00 Civic SI spindle knuckle assembly
  178. automatic to manual tranny swap
  179. Does the heat suck in your car?
  180. Already searched: size of interior dome light bulb, 95 Civic
  181. Del Sol Interior Help...
  182. Performance: Falken Azenis Sport in rain
  183. How many miles does you D15 have?
  184. I have a cracked manifold on my civic and bad ball bearing on A/C
  185. '99 civic hatch accel problems...
  186. Wheel Hop Questioin
  187. civic 97 radiator
  188. Lowering/Suspention question
  189. coilover question
  190. Couple of paranoia questions about an '05 Civic.
  191. Need New Bumper
  192. Speaker sizes:Civic
  193. jdm gauges
  194. Possible Spark Issue...
  195. Sloppy Clutch Problem
  196. belt broke--now what need options
  197. Should I Replace My Hatchies Internal Coil?
  198. Braking Problems
  199. Which water pump & timing belt to use?
  200. Fuel filter on 96 Civic
  201. Cant seem to figure this out??
  202. Springs and struts never match
  203. good price for civic engine
  204. RsR Exmag for a Del Sol Si?
  205. 5g Civic Tachometer cluster tech
  206. Signs for new engine mounts
  207. Busted Seat
  208. radiator support
  209. Opening Heat Vent
  210. MagnaFlow Cat-Back Exhaust System
  211. Hood shaking and front end vibrating
  212. Civic EX 96
  213. planning to change stock rims, need assistance with size.
  214. car wont start,timing problem?
  215. how to reset 2002 civic maintain light?
  216. Help Me Decide
  217. Oil Pressure question
  218. Loose Steering on Hatch?
  219. Armrest and longer shifter ok on the hatchbacks?
  220. when you hit bumps on the road the car pushes to the side.
  221. Oh noes! Mileage dropped off & loss of power on the highway :(
  222. Wheels
  223. Alignment Kit?
  224. timing belt tensioner problems!!!!!! arghh!
  225. fog lights
  226. Exhaust question (help!)
  227. LCA Question?
  228. help! muffler problem?
  229. *Power Steering Boot Ripped/Leaking Problem*
  230. Can I replace my cluster for one with a Tach?
  231. Shortshifters
  232. Tie Rod Ends
  233. misfire detected?????
  234. INstallin a Faze Electrical Water Temp Gauge
  235. Poject Del sol fix up
  236. Help with struts
  237. What MTF to use?
  238. How are the 96 civic hatchback CX?
  239. Rota C8's
  240. Who knows how to fix this CEL code?
  241. Need to pull CEL codes off a 96 Civic
  242. H22a or B16a
  243. 92 - 95 Civic Vtec O2 Sensor
  244. Cheap brake upgrades
  245. Question about 92-95 JDM headlights
  246. Low pressure in brake system?
  247. 96 civic lower engine mount-help!
  248. good painting deals???
  249. how to install spoiler?
  250. Installation of Horn covers ... help!
go
