View Full Version : '92+ Civic/EL & Del Sol
  1. B16a trouble??
  2. Cool Air intake ?
  3. starter confusion
  4. Which bulbs should I get?
  5. Temp is all screwed up
  6. who makes these?
  7. coilovers ?
  8. At idle my car keeps going up and down from 1k rpm to 2k.
  9. hgf
  10. Corner Lenses
  11. PROB: Starter Fixed. Now Car Isnt Idling Right. Look.
  12. 99 si wheels
  13. HID question???
  14. What is better?
  15. HAHAH Can't BAN ME CAN YOU
  16. Is a wire harness needed with this HID kit???
  17. Gauge Cluster Question
  18. How do you clean engine bay?
  19. which intake to choose for my civic 04??
  20. electric turbo???
  21. can someone help me pick which one?
  22. Tell me what to do. Just keep it "G"
  23. get horn to work
  24. Thank You HAN
  25. 99 CIVIC SIR - Broken sway bar DONT TAKE TURNS!!!
  26. Anyone seen this video???
  27. CTR Gauge bezel question???
  28. Car loves to die...
  29. I backed up and hit my muffler into the curb
  30. DIY KYB GR-2's on a civic???
  31. d16z6
  32. i'm having problems steering
  33. zc motors how do you konw
  34. Rims to fit my EK Civic Coupe
  35. ---Red EK's need HAVE A PIC REQUEST----
  36. Bodystyling....JDM Style
  37. Fuse for the Dome Light?
  38. Changing Head Hasket
  39. Civic gauge question???
  40. A/C Control problem
  41. Daytime running lights
  42. new 'round here
  43. shiftings screwey
  44. Falken Tires
  45. Angel Eyes,, whats the dealio ?/
  46. high flow or straight
  47. amber gauge cluster
  48. Door strip thing removal
  49. leaky roof on sol
  50. Difference between Apexi N1 and GT-spec exhaust
  51. Compressor Questions
  52. removing damper fork bolt?
  53. difficulty of changin a cv axle
  54. Crank Pulley Came Off......Again
  55. Suspension on a 94 EX?
  56. locating main relay
  57. April 2005 Korbach Frame Locks group buy
  58. OBD-1 Injector Limit
  59. Cant Get Starter To Start. Please Look.
  60. Tach Install
  61. Hondata or Neptune?
  62. They were wrong; Polk DB650 do fit 6th gen civic
  63. Whats is the plastic guard between me and ....
  64. Civic seat question?
  65. Longer crank times
  66. H4 Bulb question?
  67. EM2 and EP3.....
  68. 02 Civic si
  69. Plastic clips/fastners
  70. Liscense Plate Back area Removal on Trunk?
  71. Side rear window Removal on 6th gen Coupe?
  72. Gauge Upgrade Finally Done - Check these Pics
  73. is this a good deal???
  74. want to paint door handles and mirrors
  75. 98 4dr honda civic sites...
  76. turbos for a b16a II
  77. Need Body Shop - Help!
  78. Interior kits for 92-95 civic
  79. gauge pod question
  80. 05 Civic parts
  81. Need Some Help Overheating!!
  82. So, are those valve covers I see usable?
  83. TPS or ecu problem!! help!!!
  84. 92-95 civic LX, what type of headlights should i get?
  85. used turbos???
  86. boggs on acceleration
  87. gauge
  88. =help= A/f Gauge =help=
  89. spark plugs do that??
  90. How much PSi from a turbo can engine from 96 cx hatch can take?
  91. Fixing rims
  92. Just bought 98 Civic
  93. JDM ITR front end coversion on EG?
  94. Tokiko Shocks
  95. comptech intake questions
  96. clutch stuff
  97. Battery Stabilizer
  98. Installing "Auto-gage" Tachometer
  99. dashbored
  100. Greddy Evo2 or Apexi Exhaust?
  101. Turbo Del Sol Dyno
  102. I searched and got kind of confused on adding wires for v-tec.
  103. Camber Question
  104. Help Required...
  105. 01 civic ex faster than 96-00 civic ex???
  106. 99 Civic lip question???
  107. 99 Civic Mirrors??
  108. JDM Swap Websites
  109. Need help finding sedan body parts
  110. Whats the problem here???
  111. Skunk2 taller coil in front or rear?
  112. turboed sohc vtec d16, or all motor b16
  113. My New Car
  114. 2000 EX without Vtec?
  115. Smokage! Smoke & Go Go Gadget Smoke machine!
  116. $ to spend, what to spend it on?
  117. Brakes go out randomly....
  118. Need help...Please identify what this is...
  119. Need Help Please Look
  120. ITR Tranny Swap
  121. Honda Civic 2000 Muffler
  122. dx hatch cluster options
  123. SOHC VTEC modification?????what to do???
  124. Sol Question
  125. Del Sol Group Buy: Ameripol Glass top
  126. hood dampers
  127. Leaking coolant
  128. Oil Seals
  129. 03 civic radio removal
  130. 2 Ex doors
  131. STR now BDL, what's the deal?
  132. Headlight Help
  133. A-Pillar Gauges
  134. Is this right??? (westcoaststyles)
  135. Radiator Fan circuit
  136. Full detail!!!!
  137. is there any paint
  138. D16A details
  139. bye bye front lip :wtc:
  140. Starter grind while trying to start car
  141. 00 Civic Si seats in 93 hatch?
  142. Chirping sound. Belt maybe?
  143. t-belt cahnge time?
  144. 03+ EL gauge cluster (5speed)
  145. Changing over gauge cluster
  146. code 22
  147. headers
  148. Need peoples testaments.
  149. b16
  150. Headlight lens?
  151. Im Back!!!!!!!!!!!
  152. electronic boost controller
  153. im still having an electrical issue
  154. Timming Belt Ques
  155. brightest and whitest H4 bulb???
  156. Motor swap queston
  157. I have a trunk leak
  158. Omnipower coilovers: Need help!
  159. 97 civic front bumper lip
  160. Swap axles?
  161. Battery indicator light
  162. gas mileage?
  163. Battery indicator light
  164. -wat are g0od 95 gsr compression results???
  165. cant find it
  166. removing hub
  167. header rattle
  168. how do you like your B20?
  169. 99 Civic gauge cluster question???
  170. exhaust sounds different...
  171. thanks
  172. Need Your Help In Arizona
  173. AEM fuel rail
  174. Fuel Gauge
  175. 92-95 Civic projection halo pics
  176. replace drain plug and washers on transmossion?
  177. 4 Speed on a manual
  178. What to do for better handling/cornering?
  179. Gauge cluster problem??? Maybe
  180. are there any big differences between these 2 exhausts?
  181. Split-Fire for Civics?
  182. AEM V2 Intake
  183. problems with KYB AGX install done myself...
  184. '97 civic lx change drawer and lighter
  185. muffler question?
  186. 95 civic instrument cluster trim removal
  187. handling question on a 93 civic
  188. Questions Re: Lowered Del Sol
  189. Skunk2 camber kit
  190. exhaust
  191. Headlight/Windshield Wiper Problem
  192. How fast can I expect '93 civic Dx hatch gsr swap?
  193. G-force on del sol?
  194. My Emergency Light Wont Work!
  195. Guage Face Alternative
  196. Charging system is dead :(
  197. Gear oil or Motor oil for Tranny
  198. custom trunk light?
  199. What Seats will fit in My EG?
  200. Muffler Installation!!
  201. Muffler help!
  202. Lower Ball Joint
  203. Engine wont warm up?
  204. spark plug wires
  205. Lowering Springs
  206. b16 tranny advantage over gsr tranny?
  207. Replace CV boot, axel, and OEM/aftermarket?
  208. d16 tranny
  209. D16 - Weird Idling?
  210. How do you take out window crank???
  211. Vtec controller
  212. recommended tyre
  213. need help wiring sidemarkers ASAP
  214. I need help with buying wheels.
  215. Pedal Assembly
  216. buying a honda
  217. axle replacement
  218. B16a2 in 1992 hatch form JapanStarMotor???
  219. cannot get the black gauge holder off
  220. European Civic Brochure
  221. D16Y7 Intake Manifold Swap
  222. Cluster to match the B16A
  223. The right way to remove the crank bolt
  224. Spark Plug Issue......
  225. Another EG gone :sad:
  226. Unexpected problems, gotta move to a B16A
  227. Need instructions for KYB AGX gas shocks asap
  228. civic to acura question??
  229. Alright,other thread died, new questions: b18c
  230. finding all clear/crystal tail lights for 96-98 4dr civic
  231. '99 Civic Si...should I buy?
  232. my honda wont run when it warms up
  233. out of gas
  234. IS my head cracked.
  235. Throttle Body/Intake Question
  236. My civic is over heating.
  237. Advantages/Disadvantages to lowering
  238. idler pulley
  239. 00 civic tweater removal
  240. Checking Timing on D16Y8
  241. Engine noise
  242. air fuel ratio
  243. might get this car
  244. HELP: i need help opening cover to replace 98 4dr civic factory speakers
  245. dashboard gauges wired to stay on all the time?
  246. exhaust rattle
  247. Umm whats this???
  248. How long did it take you to swap?
  249. sc pulley or bearing needed?
  250. Car Detail
go
