- valve cover paint?
- need a new look
- Radiator fan still isn't coming on...
- What do you think about these headlights?
- ECU help
- Will these wheels fit my car?
- Faded Plastic Door Moulding Trim
- Messed up paint...
- Some kind of grease all over the inside of the wheel.
- Need MUGEN RNR center caps (15'')
- Noob wants your opinion
- 00 civic interior
- need a quik favor from b18c owner
- 99 Ls in ek?
- honda newb question
- Can't get the pin out now, its about 1/2way through.
- Civic Reverb 2005 - Opinion
- List of options for that damn axle nut...
- 02 Civic Trunk Problem
- Electrical problem???
- Starter problem
- lightweight Flywheel ?
- How important is the ring around the pin on shift linkage?
- HID kit question
- Will a 3”deep X 6”tall X 22”long Spearco intercooler fit civic hatch?
- My new headlights
- Honda dealer sucks! My car is making a click sound when making a slow left turn!
- Turbo Deals
- replace valve cover gasket?
- Need help locating speed sensor wire IN cabin & reverse switch...
- dent in car
- preventing rust???
- 95 Civic DX Faded Plastic Door Trim
- shaving molding
- Type R Sway bar
- Turbo and Cams Question
- which exhaust turns sideways?
- Need more info on A'pexi world sport catback
- look at em
- The all mighty harness..
- mini me swap???
- BUDDY CLUB COILOVER:Clunk Sound
- Want to improve my Civic's grip/handling
- Hatch!!
- BSA 282 Rims
- step-by step replacing passenger axle civic 95
- Brake and rotor change in 00 civic EX...
- Can and should I do this?
- acura legend brakes on a rex?
- 93 hatch
- bulbs in 96 headlights?
- Distributor q
- Civic Type R (CTR) Front Strut Bar Install?
- vtec solenoid question
- back dash of the 2002 honda civic
- ame cai sound
- mufffler silencer removal
- need help// dont know wat to do??
- Axle and LCA bolts being unpersuasive.
- headers..
- Article Notification: Further Information Regarding Honda's New Engine Line-up Uncovered
- [QUESTION] New Exhuast.. New Engine
- 98 civic stock grill removal?
- soooo pissed!!!!
- Help w/ the name of this (boot?) on 95 civic
- Questions about a 97 hx...
- 4door handles on my hatch?
- power window 99 civic EX
- 1.6L SOHC CXi - worth doing these things?
- Strut mount top nut help!!
- civic keyless entry install
- Quick Help! buddies civic ex
- Hardest Mod. Ever.
- how much do stock 14" steelies weigh?
- Rim offset ????
- intake manifold..
- 99 00 civic ecu????
- 98 Civic Gauges
- 98 Civic Gauges
- Question about high mileage and turbo?
- Weird sound coming from engine bay?
- Windshield Sprayers
- power out of a d16z6
- electrical wires for lighting
- 3 Bar Map?
- 1995 civic si coupe
- Eclipse manifold fit d15/d16?
- OBX HEADERS FOR 99 SiR ????
- What Would You Consider Ricey?
- which clutch kit should i get?
- Normal Idle
- Gauge cluster mileage
- Engine Temp sensor
- DEL SOL logging software?
- stalls while driving??
- Buy rims now and tires later?
- Acceleration Problem
- So my transmission is slippin
- 96 teg gsr swap
- Lube/anti-seize for front brake sliders
- 97 dx head for a 95 vtec head. Will it work?
- power mirror help
- do I need a second o2 sensor???
- KYB AGX help needed!!!!
- Another "What should I do next?" d16y8
- Motor for my 93 civic dx
- JDM 94 B16a timing belt is loose
- DIY A/C Removal?
- Car overheats bad - won't stay running... help!!
- y8 head on a d16z6 block..what ya think
- [OPINION] New Engine or Upgrade?
- rear right window started blowing fuses
- 96-00 headlights
- do these things really work?
- Will my header fit my new B16A?
- Can't find A/C mount bolts.
- door panels 01 ex coupe
- resonator
- Sway bar shifting side to side
- Wierd tire wear; looks like camber but it's not!
- skunk 2 coilovers or eibach springs???
- need help!! wont start
- 1992 Honda civic Alternator removal HELP
- what does this bolt do????
- D Series Trans
- Building a c1
- Front left shock problem!Need Help!!!
- rwd turbo eg
- -_- I can't figure this out for the life of me.
- mid range power
- Cleaner Brakes
- Valve cover bolt stripped
- newb ?
- Will94 GSR Gauge cluster fit 2000 Civic Ex?
- Can anybody do this...???
- re lowered my civic tonight
- Leaking gas
- 01+ Civic "Maintenance Required" light
- best cams for b-16a ?
- Buy A Body Kit?
- Camshaft Pulley Question??
- '97 Civic DX: alternator or some other problem...
- Civic VTI
- o2 sensor problem
- Persistent fuel gage problem
- Thank You Han!!!
- rebuilding my engine need help
- speedometer problem...
- o2 sensor problem...Help...
- installing springs on 05 civic.
- clearing 96 HB tailight?
- removing OEM side skirts
- Pads and Rotors
- Need help w/ some problems
- my car and some q's on my exterior
- Ok, almost ready to yank engine out, but what about this?
- Man I miss Hawaii
- Mini-Me swap
- Valve Job
- EK Civic Coupe exhaust question.
- EK Civic Coupe suspension question
- How do u preload the coilovers b4 installing
- Disabling that annoying door chime?
- centering rings
- Anybody bought from 1A Auto before?
- changing rotors
- Anyone experienced in hydrolocked cars?
- whistle goes the cheap intake
- Bouncing Speedometer needle
- 800 WHP Civic!!
- Subwoofer question
- Modifying standard grille
- Garages are evil I tell you.
- 2000 EX vs. 2001 EX
- Please help with my tail lights...civic 04
- 01 Civic Head Identification
- high idle
- Is it normal to idle at 1500rpm? and 3500rpm going 70?
- can i drive with just the turbo manifold and downpipe?
- short shift
- Which color HID to get???
- My new Grille (pic) WOOT
- 98 civic 4dr speaker wire confusion
- reducing NVH (noise), and bushings
- Headers: Ceramic vs Stainless/Brushed
- 94 Civic EX coupe HO Alternator?
- Question about bulb wattage
- headlights
- Question about Si C/C bulbs
- 94 Del Sol - Part # for door handle clips?
- obd performance
- How can I find where my car is shorting out?
- Injectors?
- got my clutch
- B16 (98 Ex) Head installation question (post gasket failure)
- need some quick help PLEASE
- Garrett T3/T4 57 trim turbo too big for a civic?
- Wiring harness
- speedometer off
- 98 Civic Grille Question
- cleaning fuel injectors
- What body kit is this?
- new parts and new look for this summer
- 2 major problems in 1 day, PLEASE HELP
- 93 Del sol....92 civic hatch compatability questions?
- Which motor?
- 1992 honda civic cx wont start
- Grill Install Questions...
- o2 sensor on intake question
- Do you have a 96-98 civic coupe OEM grill (black) sitting around?
- How do you adjust speedometer with new wheel size?
- compression on my civic check it out
- Cable Clutch Question?
- Anyone In The Salt LAke Area?
- Wtc...... B18...b20...b16...
- Need help from all of you
- Replace my 98 civic seat with ??
- Finish my D series build *PICS*
- tail light conversion
- relieving fuel pressure??
- Couple of swap questions need answers. 97 b18b1 into 94 civic
- Push Button Start
- climate control help
- Help - Weird Tach Reading
- Disable DRL
- best foglight..
- Improve my Civic's performance?
- Torque of Valve Cover bolts (in.lbs)?
- Help!!!ashtray, Please!!!
- My idle prob again...
- Whining - Power loss in Steering
- turbo lsvtec or turbo H22
- what OEM rims look good on my car?
- 2002 civic ex
- spark plug gap: b15b7: help
- Budget bodystyling
- What's on the left side?
- is Turbocalculator safe to buy manifold and turbo's?
- DC seats in an EK
- Question on big brake kit!
- My Car Got Stolen!!! Pls. Read!!!
- Question about CTR's and HID's???
- New Wipers for my Sol?
- Broken Bolt, searched forum but still need help
- another squeeky suspension!!!
- Del Sol Trunk
- Red/Clear Tails?
- B16a trouble??
