View Full Version : '92+ Civic/EL & Del Sol
  1. RIP hatch
  2. Hows this setup?
  3. headlight condensation
  4. 100 bux to install oil pan gasket...is that a good deal?
  5. What are some good Headers????
  6. d16y turbo numbers?
  7. d16y8 turbo what injectors??
  8. Will this throttle Body spacer work?
  9. Project 4 Door!
  10. Steering Rack Installed Problems??
  11. upgrade on honda
  12. b18c1 w/turbo swap problem?
  13. Car won't turn over or crank.
  14. Turbo Update..... Problem
  15. ideas for my new civic
  16. Preliminary Dyno Data
  17. cap n rotor
  18. B16A S4C tranny GSR 5th gear
  19. CODES 9 and 14
  20. Need an undercar pic of an apexi n1 exhaust....PLZZZZ
  21. Torque wrench question for headbolt
  22. Burning VTEC
  23. VTEC head or B16 tranny
  24. D17
  25. 1998 Civic EX (lightly modified)
  26. 1997 civic oil change
  27. Distributor
  28. Rear Sway,Tie, Brace
  29. D16y8 Build
  30. Muffler silencing and install
  31. New shock bushings
  32. gsr power?
  33. HELP !! can a d16z6 tranny fit a d16y8 ?
  34. Rattle under WOT
  35. D16Z6 turbo
  36. 99 civic trouble code
  37. This has been going on for some time I need to take care of it.
  38. Semi Old School Civic deal
  39. adjusting projector beam!!!
  40. That euro hatch I mentioned.
  41. ST Speedtech rear swaybar\tie bar combo
  42. Bleeding Brakes
  43. Suspension
  44. I need your help with me power door lock!
  45. 95 Civic Axel
  46. 2000 Civic Si Foglights
  47. Making my exhaust louder?!?!
  48. Tyre Pressures
  49. Too much for a 96 Civic EX coupe?
  50. 2000 Si Civic head work
  51. First mod in
  52. Civic or integra
  53. Civic 04' Coilovers
  54. Ive searched....
  55. engine trouble
  56. My experience with Korbach Frame Locks
  57. got a cell and speedometer goes up and down
  58. Question about different engines?
  59. head swap on 1.7
  60. eg6 sidemarker installation
  61. location of starter motor in 94 Civic
  62. Would you....?
  63. Integra Interior Swap into 92 Civic Hatch
  64. advance timing
  65. Whats better for '00 Civic Si
  66. gsr intake manifold
  67. Nippon oil Filters?
  68. To those with adjustable rear camber kits
  69. GSR brake swap onto 93 4 door LX
  70. mechanic being dumb
  71. Voltage Stabilizer?
  72. my alignment specs...
  73. When it comes to lube....
  74. Bad temp gauge -or- Si/DX signal different?
  75. help: is typerx.com legit??/finding z3 side skirts
  76. Latest set of mods
  77. Civic lip question???
  78. So, CEL comes on: 21
  79. Are Eibach springs the most comfortable springs?
  80. Koni or Bilstein shocks for a more comfortable ride?
  81. When is the new Civic going on sale?
  82. Does the Civic have good fuel economy?
  83. Immobilizer??
  84. whats it worth
  85. Finnaly geting rid of previus owner mod...
  86. auto to manual transmission?
  87. Can I remove the heat shield?
  88. Sqeaking Sound!!!
  89. Why is she smoking?
  90. Need Help Quickly LS Swap
  91. Nasty squeeking coming from targa top
  92. Adjusting headlights on del sol
  93. How to install LED M3 mirrors ?
  94. 01 Civic Issues
  95. 01' Civic Help!!!
  96. Fixer Upper Civic 4 door
  97. Del Sol (CRX) Gear Problem.
  98. My afternoon of fun, taking apart a d16
  99. Jus Did A Swap...cant Start It...need Help
  100. Paint question!
  101. Wheel/Tire/Hub selection for scratchbuilt
  102. fuel pump question
  103. rim fitting question
  104. Replaced My Civic: A Few Questions
  105. What would you guys consider the best bang/buck tire?
  106. Front strut tower bar
  107. Well I got my parts
  108. motor and 1st upgrade
  109. What is this piece?
  110. Belt for a B16A2 w/CTR N1 crank pulley
  111. Question On Helms Manual
  112. New here and have a question.....
  113. Best suspension set up for 2000 si civic?
  114. ECU question
  115. help..
  116. Canadian and US alternator
  117. Bseries hydro tranny parts compatible?
  118. How much of a difference
  119. Buddy Club Pro spec Exhaust
  120. what's under the rear seat in civic sedan?
  121. Question about engine swap?
  122. Engine kits
  123. can this be done
  124. '00 civic SI turbo question
  125. b18a ls/vtec tranny question
  126. Disc Brakes for 2001-05 Civic
  127. Rear Anti-Roll Bar Options -- 2001-05 Civic
  128. Turbo B18C EG Civic
  129. motor swap
  130. Help
  131. Good shop/mechanic in San Diego
  132. Which Coilovers?
  133. Code 45
  134. PICS OF MY DEL SLOW.. for now. 56K*iller
  135. Aftermarket LCA
  136. My wrap up thread.
  137. The pains of high gas prices...
  138. How do you remove the rear trailing arm?
  139. Are they the same?
  140. Is my carbon fiber hood really carbon fiber...???
  141. Hooptie rattle solved!
  142. Question about Si lip?
  143. Osaka JDM Motors
  144. I want to make my b16a3 fats as shat
  145. How much oil in a b16?
  146. Color Name
  147. engine swap D13b2 for a D16Y8
  148. is this bad
  149. Allmotor B20vtec mildly modded B16 or GSR Tranny mostly for 1/4mile
  150. more swap info
  151. Question about gutted catalytic converter?
  152. What type of Throttle Cable?
  153. help me
  154. Hondarust on quarter panel, any help in chicago?
  155. JDM tailights VS US taillights
  156. clutch slave
  157. Which filter?
  158. Pics and mod list
  159. where to buy engine swaps?
  160. More CEL's than you can throw a stick at!
  161. I searched through like 10 threads and they didn't help much on the clutch
  162. b16 swap info...
  163. Gas/Engine Question... Newbie...
  164. Lowering 2000 Si
  165. 02 CIVIC EX Intermittem DRL Problem
  166. question about dropzone coil
  167. tires
  168. b16 sir with gsr headers!!
  169. Is this pretty safe?
  170. civic rear seats
  171. civic integra panels
  172. ready to build my motor.
  173. About to by my new motor..
  174. wierd vibration after short shifter install
  175. Engine swap legal stuff
  176. brakes question
  177. RETURN TO FACTORY CLUSTER HELP.... GSR cluster ----> stock 96-00 ek cluster
  178. Which one?
  179. ECU qestion v.1.57
  180. how much hp can be gained by changing stock internals?
  181. new civic
  182. B16 swap problem> into a 92 hatch cx
  183. Top radiator hose misshaps.
  184. Another header question
  185. All motor Civic vs. Stage II SRT4
  186. For those of you who have done the washer trick
  187. IAC problem causing jerking
  188. Vision corner lenses
  189. Um....WTF
  190. Omni power coilovers
  191. Honda Civic lsi 16 valve 1995 N reg Cylinder head problem.
  192. Hubcentric rings & Rota Slipstreams
  193. Final Drive
  194. Motor swap
  195. doors
  196. Header problem
  197. What's the difference between........
  198. '01 Civic rear passenger's door won't open
  199. engine short forms...
  200. Analysis of my plugs !! Help... how's the motor running?
  201. b16 into 95 civic
  202. It's all clear as day now! (VTEC wires)
  203. Where to Get euro-spec rear bumper?
  204. D15 to D16??
  205. Intake Manifold
  206. Del sol parts = civic coupe?
  207. GSR Swapping in 5th gen?, Please?
  208. Koni Yellow Question
  209. b16a2 compression..
  210. reverse light...troubleshoot...
  211. resonator??
  212. Black Widow Fog Light Question
  213. Trading 2003 Mustang GT for 2000 SI
  214. conversion
  215. New Seat for my 95 Honda Civic
  216. Is this a good deal???????? Input needed
  217. 95 civic fog light question, clock not dimming
  218. I need your opinions
  219. Fly wheel cover during clutch/ transaxle removal ???
  220. Help 95 dx wont start, cranks but doesnt turn over
  221. Help please dumb ass water leak
  222. help - painting entire car
  223. 93 civic dx weight? what u think?
  224. No Rpm Gauge On My Dash!
  225. 96 hatch rims
  226. CV shaft
  227. Looking for a used del Sol - feedback plz.
  228. oil pump gear
  229. 231 whp 1992 Civic All motor with tsx stock block/k20a R head
  230. '94 Civic SI -- break light switch?
  231. Help replacing antenna/pulling out of mast...
  232. UPgrading ECU help
  233. Factory Speakers on a 99 civic?????
  234. best 2-5/8" gauges to get?
  235. question on intake
  236. what is needed to install a short shifter?
  237. will this lip fit my hatch?
  238. Lighting/harness question -- please help!
  239. Intake experiment
  240. Coolent Resivor empty
  241. B20 Build Q?
  242. New Car
  243. Eibach or Tein
  244. 98 Civic Pix
  245. 2000 Civic Si Guage Cluster Malfunctions
  246. proper torque for crankshaft pulley bolt
  247. Dam halos are dimming
  248. How should I go about this?
  249. Anyone seen this car?
  250. wheel stud
go
