- Need help on installing engine mount inserts!
- What Honda seats bolt on to 96-00 Civic
- exhaust ....
- squeeky wheels
- Now and later
- Blow Off Valve Flanges?
- P. window problem and SRS light stays on....
- Tranny or Synchro's?
- OBD II /Systems not ready
- Can I use cruise control with JDM ITR steering wheel?
- Motegi Dp12 Rims!!! Need Help
- 93 Civic DX body problems...
- Bought bilstein shocks, which springs to match with it?
- 17s on a 95 civic sedan
- Comments on "GREDDY EVO 2" exhaust
- JR Supercharger Fitment
- How to save the steering wheel?
- new clutch
- ethenol alcohol
- turbo setup list + a bunch of questions
- Misc. Engine Stuff
- B16a Tuning / Timing problems
- Mpg
- Oil Drain plug and Tranny washer size?
- check this E-bay kit out!!!
- Resistor wiring?
- what do I need...???
- 97 DX calipers
- walbro 255 fuel pump for 92-00 civic fit 93 delsol?
- Racing Seats and Stock Seat Belt Questions
- fan not working
- D15b7 To D16y8..
- EG Hatch lower radiator support?
- my new suspension....thoughts, opinions?
- Shift extender bar
- Clutch Alignment.....
- Experiences with TurboCalculator.com?
- Rev Problem
- Lights for my 90 Civic LX
- civic 92 4 door whole dashboard dissasemble
- Anyone know this person?
- odometer
- Question about wheel width??
- Camber kit?
- Bumper change
- Redline question
- bolt pattern for t3 super 60???
- Stereo thieves, Honda locks, Broken windows, etc
- thumping noise after suspension install
- FWD Traction
- oem civic foglight switch breakdown
- How does this sound....
- What are the best shocks & springs combo?
- Installing power door locks and windows
- Tokico coilovers "frozen", help pls?
- I know this is rediculous,but look!!!
- Freekin Traffic Island!!!
- Update on my car :-(
- oem spec muffler without oem look
- Disabling ABS on 2000 Civic
- Changing Spark Plugs, Wires, etc
- long block vs short block?
- Arc Induction Box for ek4
- How can I identify Civic OEM Stock 92-95 Springs?
- bolt on performance mods?
- Honda civic 2001 - whining clutch
- dun dun dun another one bites the dust!
- Where to buy this steering wheel?
- Check this t3 "custom" setup out!!!
- need help piecing turbo kit together....
- '98 Civic Service Manual
- 96-98 OEM trunk spoiler brake light
- Aftermarket E-Brake handle/boot pics!
- squeekin noise from wheels..
- just charged my a/c
- .50
- know anything about this t3/t04e???
- f*cked up day...
- Help with gas gauge
- Have $6K to spend on engine, help me out!
- how to empyt a/c system
- What is a honda civic VTI?
- RSX leather seats and side moldings
- Josh is missing!
- 02+ si seats in a eg?
- Going from neuspeed race to skunk2 coilovers?!?
- ACL Bearings
- Shifting problem
- Tein S-tech springs
- Will this fit....???
- Completed Motor swap project (pics)
- accord motor
- B18 Crank Question?
- headlights.
- Some moron stuck a flyer on my driver's side window...
- Anyone know the owner...?
- Whats next?
- D16Z6 Intake port+ polish?
- need gelp!Where to put holes in oil pan....??
- DIY gone wrong, help...
- Honda Paint Colors
- Best muffler for my setup
- first raping on the car
- need help identifying engine
- euro r/civic
- My Trunk Is Leaking
- Check this setup out!!!
- 96 civic fog light install. help
- installing coilovers on Honda civic
- My new valve cover & cam cut
- seat fitment
- Need some info on EL's
- Motor Swap: Day 4
- Got 450cc Injectors from DSM, Can I put them on now?
- OPDS Unit location
- b18c1 92+ hatch civic
- Very old into new?
- Easy Question
- 97 B18b1 Pinging?
- My Car Is Hurt!!
- Need Advice!!!
- help, o2 sensor, going crazy.....
- Can someone carfax the vin # for me thanks.
- 4-wheel alignment
- CTR jdm front lip in urathane
- Cat Converter, TPS, Main Relay
- A/C Components for Del Sol Si
- ES Muffler
- Custom ITBs!
- torque wrench
- D-series suggestions?
- buying a turbo kit :-)
- i wanna build a frankenstein
- Squeeks when letting OFF brakes.
- B18C swap, what else?
- Which Harness And Ecu?
- anyone with 98 civic lx
- Engine needs to be Replaced
- valve clearence
- '98 Civic Speedo Intermittent
- aftermarket steering wheels ?
- Electrical Systems Question
- Will this Turbo kit do the job???
- NGK Blue Wire Set buy in Europe
- new guy, couple questions about my 96 hx
- 93 cx hatch swap?
- b18c1'd civic Vtec Cutting out
- DEL SOL Transplant
- Exhaust Advice 4 98 Civic Lx W/d16y7
- CIVIC eg6 auto to manual???
- Car Trouble--please Help.
- Short in cd player?... need help
- Greddy turbo kit potential..????
- D2 Suspension
- normal to lose hi beam when installed HID?
- LX Gearspeed tranny on EX Civic
- checking off the list
- backfiring
- tsb that i passed to tech
- Steps on making your own "Custom Cat-back Exhaust system"
- Civic Coupe - Manual or Auto
- replace tail light bulb
- quick question
- please help me label these mounts
- vtec light
- condensor, or evaporator?
- Broken wheel studs......Hub removal..HELP !
- JDM B16A MAP sensor
- Ecu compatability in a VX engine
- Battery dies after a few days...help!
- Block Guard only.. whats the limitation!
- Need new front lip
- Motor swap today =P
- Changing brake pads.. NEED HELP ASAP!
- N/A D16z6
- Crank Removal
- Its a long shot, but heres my theory on my car troubles...
- CEL on, throwing code 80
- Crower, Crane, Skunk, or Zex Cams?
- Fuse Layout
- Question about tail light bulbs???
- 93 civic dx 1.5L valves
- Burned my clutch a bit and now it's smooth again
- Where to find exhaust gaskets
- '95 civic neuspeed suspension
- sunroof leaking
- Teg front LCAs and Civic front LCAs use same bushings?
- axle seal keeps breaking, just rebuilt transmission, please help!!
- Dashboard Install
- Partially Blown Headgasket, What to do?
- hella squeeking in passenger side front wheel...
- D16Z6 rebuild... pondering
- help, how to adjust the headlight
- curb weight for a 95 ex and 2000 dx
- Tuner Toys Connecting Rods.. RELIABLE?
- /Conversion/ 93' integra "JDM" headlights on a 2000' civic Ex
- Need turbo timer help as well. Cant find it on greddy.com
- Engine Swap Help In San Diego
- 1999 B16A2 Head on D16Y8 Block
- ZEX Nitrous and Crower camshaft....
- I need a Fuse Box Diagram URGENT Civic 96
- 2002 EX fuel filter
- Possible starter problem
- First turbo mock up
- My brother's civic keeps vibrating in a odd way and here is what we've done so far...
- What shifter for B16A in 95 CX?
- oil leak inside distributor
- Car is now unbearable to drive...
- Rough Idle
- compression help!!!
- Brakes
- wet load miss
- Custom Exhaust Questions
- Apexi WS II
- What OBD??
- Exhaust
- Will this solve radio swap issue?
- zex nitrous on a b18b(hatch) yes or no and why
- got inspired today, did a little project
- Octane Boost Additive Causing check engine Light???
- Cluster Swap!!!
- 93' Del Sol S D15B7 Head Swap to Rebuilt D16z6 VTEC Head MINI-ME
- Engine Hesitation
- laptop or motor???
- fart-can syndrome
- Throttle cable ??
- Which motor is better all around?
- my sol came without AC
- Need a new clutch, any suggestions?
- Fuel Managment for b16a
- turbo question
- Will the car pass emissions w/ high flow cat?
- 99 Civic and Black Rims!!!!!!!questions
- 96 civic f/s...ny area..great price
- 98 Civic Lx
- '97 civic-replacing window motor
- Starting Problem
- UR Pulley Issue
- Extra resevoir
- polishing lip on rota slips
- Carbon Fiber Trunk Lid.....
- [Newbie Question]Removing the balancer pulley bolt...
- rear disks?
- 93 SI- stock spring rates
- Busted exhaust system, help
- 95' eg, trying to take the dash out?
- help a noob out, please.
- Whats a Reasonable Price?
- B-Series 6 puck unpruge clutch
